Specialy theory of relativity [Answer Check]
In summary, a 30-year old female astronaut leaves her newborn child on Earth and goes on a round-trip voyage to a star that is 40 light-years away in a spaceship traveling at 0.90c. When she returns, the astronaut will be 68 years old and her son will be approximately 88 years old, due to time dilation effects. The equation \Delta t = \frac{\Delta t_o}{\sqrt{1 - \frac{ v^2 }{ c^2 }}} was used to calculate the ages of the astronaut and her son.
AClass
25
a 30-year old female astronaut leaves her newborn child on Earth and goes on a round-trip voyage to a star that is 40light-years away in a spaceship traveling at 0.90c. what will be the ages of the astronaut and her son when she returns?
[tex]\Delta[/tex] t = [tex]\frac{\Delta t_o}{\sqrt{1 - \frac{ v^2 }{ c^2 }}}[/tex]
40 years (2) +(0.20)(40 years)= 88 years
The astronaut will be 30+88 years = 118 years old when she returns
Using the above equation.
[tex]\Delta[/tex] t = 118 years
v=0.90c
Obtained [tex]\Delta t_o[/tex] = 51.44 years
The astronaut's son will be 51 years old when she returns.
Wondering if I did this correct, I don't have any answers to check from It looks right to me.
Ummm, I'm not following you there. :rolleyes:
Something went wrong again. You're not applying the right time to the right person.
You might want to just start in the child's frame of reference. Then use x = vt for that frame.
v=0.90c
No, that's not the right application of the formulas.
For starters, the astronaut will age the slowest.
Means, the parent is on route for 80 years [40 Years there, then 40 years back], plus since she is traveling 10% slower than the speed of light 20% slower since she is going there and back.
I realize where I went wrong. I went to verify my notes.
The child will be 88 years old.
[tex]\Delta[/tex] t = 88 years [Earth Observer]
Using the equation,
Obtained [tex]\Delta t_o[/tex] = 38.36 Years
Therefore the child will be 88 years old, and the parent will be [30 years+38.36 years] 68 years old.
That should be right. Thanks for the help!
That's not the correct math. :rolleyes:
Please, start over. First calculate the total distance (in light years). Then write down the velocity (v = 0.90c). It's also helpful to note that c = 1 ly/y. Now go back to one of your most basic kinematics equations for a uniform velocity, x = vt. Solve for t.
Using the equation,
That's almost right. But you should go back and redo the child's age for better precision. It's not exactly 88 years. :wink:
Your solution is correct. The special theory of relativity states that time is relative and can be affected by the speed of an observer. In this scenario, the astronaut's speed of 0.90c will cause time to slow down for her relative to her son on Earth. This is known as time dilation. Therefore, when she returns after 40 years of her own time, her son will have aged 51 years on Earth. This phenomenon has been observed and confirmed in experiments involving high-speed particles.
Related to Specialy theory of relativity [Answer Check]
1. What is the Special Theory of Relativity?
The Special Theory of Relativity, also known as the Theory of Special Relativity, is a scientific theory developed by Albert Einstein in 1905. It describes the laws of physics in a consistent and unified way for all observers in uniform motion.
2. How does the Special Theory of Relativity differ from the General Theory of Relativity?
The Special Theory of Relativity deals with the behavior of objects and laws of physics in inertial frames of reference, while the General Theory of Relativity includes the effects of gravity and non-inertial frames of reference.
3. What are the key concepts of the Special Theory of Relativity?
The key concepts of the Special Theory of Relativity include the principle of relativity, the constancy of the speed of light, and the equivalence of mass and energy (E=mc²).
4. How does the Special Theory of Relativity explain time dilation and length contraction?
According to the Special Theory of Relativity, time and space are relative and can change depending on the observer's frame of reference. Time dilation refers to the slowing down of time for an observer in motion, while length contraction refers to the shortening of an object's length in the direction of motion.
5. What are some practical applications of the Special Theory of Relativity?
The Special Theory of Relativity has practical applications in various fields such as nuclear energy, particle accelerators, and GPS technology. It also plays a crucial role in our understanding of the laws of the universe, including the behavior of stars and galaxies.
  • Classical Physics
