MHB Specific example of Eisenstein's Theorem using R = Z
Math Amateur
MHB
Eisenstein's Criterion is stated in Dummit and Foote as follows: (see attachment)
Proposition 13 (Eisenstein's Criterion) Let P be a prime ideal of the integral domain R and let
f(x) = x^n + a_{n-1}x^{n-1} + ... ... + a_1x + a_0
be a polynomial in R[x] (here n \ge 1 )
Suppose a_{n-1}, ... ... a_1, a_0 are all elements of P and suppose a_0 is not an element of P^2.
Then f(x) is irreducible in R[x]
The beginning of the proof reads as follows:
Proof: Suppose f(x) were reducible, say f(x) = a(x)b(x) in R[x] where a(x) and b(x) are nonconstant polynomials.
Reducing the equation modulo P and using the assumptions on the coefficients of f(x) we obtain the equation x^n = \overline{a(x)b(x)} in (R/P)[x] where the bar denotes polynomials with coefficients reduced modulo P... .,.. etc. etc.
I will now take a specific example with R= Z as the integral domain concerned and P = (3) as the prime ideal in Z.
Also take (for example) $$ f(x) = x^3 + 9x^2 + 21x + 9 = (x+3) (x^2 +6x + 3) $$
Now as the proof requires, reduce f(x) mod P
Now using D&F Proposition 2 (see attached) - namely $$ R[x]/(I) \cong R/I)[x] $$ we have
$$ Z[x]/(3) \cong (Z/(3))[x]$$
and so we to obtain $$ \overline{f(x)} $$ we simply reduce the coefficients of f(x) by mod 3
Since $$ 9, 21 \in \overline{0} $$
we have $$ \overline{f(x)} = \overline{x^3} $$
The coset $$ \overline{f(x)} $$ would include elements such as $$ x^3 + 3, x^3 + 6x^2 + 24x - 3, ... ... $$ and so on.
Can someone please confirm my working in this particular case of the Eisenstein proof is correct?
Peter
[This post is also on MHF]
To discuss this example in terms of Eisenstein's Criterion, you need to point out that neither the hypothesis nor the conclusion of Eisenstein's theorem is satisfied here. The coefficients $9$ and $21$ are both multiples of $3$, but the constant term $9$ is a multiple of $3^2$ (contrary to Eisenstein's Criterion). And the polynomial $f(x)$ is not irreducible because it factorises as $ (x+3) (x^2 +6x + 3)$.
Opalg said:
To discuss this example in terms of Eisenstein's Criterion, you need to point out that neither the hypothesis nor the conclusion of Eisenstein's theorem is satisfied here. The coefficients $9$ and $21$ are both multiples of $3$, but the constant term $9$ is a multiple of $3^2$ (contrary to Eisenstein's Criterion). And the polynomial $f(x)$ is not irreducible because it factorizes as $ (x+3) (x^2 +6x + 3)$.
Thanks Opalg.
Regarding my specific example, I think that my post was not completely clear in what I was attempting to demonstrate. I was taking a specific example and following the D&F proof on D&F page 310 - see attached - which assumes that f(x) is reducible and then proceeds to reduce f(x) modulo P. So, I took a reducible polynomial that (I thought) followed the Eisenstein rules for coefficients and then was focussed on showing how this led to the equation $$ f(x) = \overline{a(x)b(x)} $$ when f(x) is reduced modulo P.
Mind you as you point out I was wrong in allowing $$ a_0 \in P^2 $$. I am not sure it would really alter my exercise in establishing $$ f(x) = \overline{a(x)b(x)} $$but I probably should have taken (say) $$ f(x) = x^3 + 9x^2 + 24x + 18 = (x +3)(x^2 + 6x + 6) $$ and then moved on (in parallel with or following the steps of D&F's proof to show that $$ f(x) = \overline{a(x)b(x)} $$ - since it is these steps that bother me.
*** Reflecting on the proof, I am confused by the following:
In D&F page 310 (see attached) we find the following:
"Suppose F(x) were reducible, say f(x) = a(x)b(x) in R[x], where a(x) and b(x) are nonconstant polynomials. Reducing the equation modulo P and using the assumptions on the coefficients we obtain the equation $$ f(x) = \overline{a(x)b(x)} $$ in (R/P)[x] ... ... etc
My confusion is as follows:
P is a prime ideal in R (in my specific example P + (3) is a prime ideal in R = Z)
BUT!
P is not an ideal in R[x] --> so how can we reduce the equation f(x) = a(x)b(x) which is in R[x] by an ideal P which is not even in R[x]?
I would be extremely grateful if someone could clarify this situation for me
Peter
The world of 2\times 2 complex matrices is very colorful. They form a Banach-algebra, they act on spinors, they contain the quaternions, SU(2), su(2), SL(2,\mathbb C), sl(2,\mathbb C). Furthermore, with the determinant as Euclidean or pseudo-Euclidean norm, isu(2) is a 3-dimensional Euclidean space, \mathbb RI\oplus isu(2) is a Minkowski space with signature (1,3), i\mathbb RI\oplus su(2) is a Minkowski space with signature (3,1), SU(2) is the double cover of SO(3), sl(2,\mathbb C) is the...
