Specific heat capacity, Q = mcθ
In summary, the conversation discusses a question involving specific heat capacity and the calculation of the final temperature after heat is added to initially 10 °C water and removed from initially 30 °C water. The correct answer, determined to be A, is based on the assumption that there is no heat lost to the surroundings. However, even taking into account the slight decrease in heat capacity with temperature, the final temperature remains close to the originally calculated 23.33 °C. A plot is provided to visualize the calculation and approximation of heat capacity.
a129
Here is the original question (just read the English version).
Q = mcθ
Specific heat capacity of water, c = 4200 J/kg °C
I did Q_(absorbed) = Q_(released)
mcθ = mcθ
mθ = mθ
And I solved for the final temperature, which is 23.33°C. However the correct answer here is A. I'm pretty sure this question is assuming that there is no heat lost to the surroundings.
Thanks!
No it isn't. It is C. (You are correct.)
Thank you!
Note that this is true even if you take into account that the heat capacity of water changes slightly decreases with temperature. (It does not change enough for the final temperature to deviate significantly from 23.33 °C.)
Here is a plot of the heat added to the initially 10 °C water and the heat lost by the initially 30 °C water:
The coloured lines are numerical integrations of the tabulated temperature dependent heat capacity of water. The dotted black lines represent the approximation of the heat capacity being 4.2 kJ/kg K. (I used 500 g and 1 kg masses, but only the proportion is relevant for the intersection point in T)
FAQ: Specific heat capacity, Q = mcθ
What is specific heat capacity?
Specific heat capacity, also known as specific heat, is the amount of heat required to raise the temperature of one unit of mass of a substance by one degree Celsius (or Kelvin).
What is the formula for specific heat capacity?
The formula for specific heat capacity is Q = mcθ, where Q is the amount of heat energy transferred, m is the mass of the substance, c is the specific heat capacity, and θ is the change in temperature.
How is specific heat capacity different from heat capacity?
Specific heat capacity is the amount of heat required to raise the temperature of a specific amount of a substance by a specific amount, while heat capacity is the amount of heat required to raise the temperature of an entire substance by a specific amount. Specific heat capacity takes into account the mass of the substance, while heat capacity does not.
What are some common units for specific heat capacity?
The most common units for specific heat capacity are joules per gram per degree Celsius (J/g°C) and calories per gram per degree Celsius (cal/g°C). Other units include joules per kilogram per Kelvin (J/kgK) and British thermal units per pound per degree Fahrenheit (BTU/lb°F).
How does specific heat capacity affect the heating or cooling of a substance?
Substances with a higher specific heat capacity require more heat energy to increase in temperature compared to substances with a lower specific heat capacity. This means that substances with a higher specific heat capacity will heat up or cool down more slowly than substances with a lower specific heat capacity.
