Master1022
- 611
- 117
- Homework Statement
- Air at 290 K is compressed in a steady-flow process between absolute pressures 1 bar and 10 bar. Calculate the work done per kg by an adiabatic & reversible compressor
- Relevant Equations
- ## w = \frac{R}{1-n} (T_2 - T_1) ##
Hi,
A quick question on a conundrum I seem to have encountered. My main question is: why is it wrong to use the formula above instead of the SFEE approach?
My approach:
Use the formula:
$$ w = \frac{R}{1-n} (T_2 - T_1) $$
From the data book, ## R = 0.287 ## kJ/kg K and ## n = \gamma = 1.4 ##
For a reversible adiabatic process, we can find ## T_2 ##:
$$ T_2 = T_1 \left( \frac{p_2}{p_1} \right) ^{\frac{\gamma - 1}{\gamma}} $$
$$ (290) \cdot (10)^{0.4/1.4} = 559.902 \text{K} $$
and thus:
$$ w = \frac{0.287}{1-1.4} (559.902 - 290) = (-) 193.65 \text{kJ/kg} $$
Answer book:
The answer book seems to use the SFEE and does: $$ w = - \Delta h = - c_p (T_2 - T_1) = (-) 270 \text{kJ/kg} $$
(The units were most likely kW/kg for the SFEE problem)
Trying to understand the differences:
- Earlier in the question, we did assume perfect gas behavior to derive a certain formula
- In a later part of this question (for an reversible isothermal compressor), we use a variant of this formula which yields the same answer as the book
The only reason I can think of that the above formula that I used is not applicable to a steady flow process. However, I don't really understand why this is the case?
Any help is greatly appreciated
My approach:
Use the formula:
and thus:
Answer book:
