Spectral class temperature range
  • I
  • Thread starter snorkack
In summary, the spectral classes are: L, T, M, K, G, and Y. The O class starts from infinity and has no earlier class. The hottest stars are the compact ones. The temperature range of the spectral classes is: L0-L9, T0-T9, M0-M9, K0-K9, G0-G9, and Y0-Y9.
snorkack
2,225
484
What are the temperature ranges of the spectral classes?
Oh Be A Fine Girl, Kiss Me Like That Y?
Note that L, T and Y are added after M. Nothing is added before O. So O class... The O9-B0 border is somewhere around 30 000 K. Does lack of earlier class mean that O class starts from infinity? What is the temperature of an O0 star? What spectral class are Magnificent 7?
B class spans from about 30 000 K to the B9-A0 border around 10 000 K. This makes a temperature ratio of about 3.
A class starts from 10 000 K and A9-F0 border is around 7300 K. This makes a temperature ratio of about 1,37.
F class starts from 7300 K and F9-G0 border is around 6000 K. This makes a temperature ratio of about 1,22.
G class starts from 6000 K and G9-K0 border is around 5300 K. This makes a temperature ratio of about 1,13.
K class starts from 5300 K and K9-M0 border is around 3900 K. This makes a temperature ratio of about 1,36.
M class starts from 3900 K, and M9-L0 border is around 2300 K. This makes a temperature ratio of about 1,7.
L class starts around 2300 K, and L9-T0 border seems to be around 1500 K. This makes a temperature ratio of about 1,53.
T class starts about 1500 K, and T9-Y0 border seems to be around 620 K. This makes a temperature ratio of about 2,4.
Y class starts about 620 K and goes to where? Zero? What is the temperature of a Y9 object?
Astronomy news on Phys.org
Temp. too low - not a star. Very high temp. - fast burnout.
Is a star-planet boundary defined by temperature or something else, like mass?
It is defined by the ability to fuse hydrogen (protium) in its core, which is dependent on the mass of the body. Objects that cannot fuse anything are planets, those that can fuse deuterium but not protium are brown dwarfs ('failed stars'), those that can fuse protium are stars.
The hottest stars are the compact ones. Which do cool down, but do not burn.
Are you referring to white dwarfs and neutron stars?
Yes.
Hot white dwarfs include the cores of planetary nebulae. And neutron stars include the Magnificent 7 I mentioned - nerby young neutron stars that are not pulsars and are seen in thermal radiation.
Okay. Just trying to avoid confusion with the term 'star'.
Yes, the simple fact is there is no widely accepted definition of the term "star." For example, you should hardly do better than use the glossary of terms in Sky and Telescope, yet this is what you get for star: "A massive ball of gas that generates prodigious amounts of energy (including light) from nuclear fusion in its hot, dense core." It takes two seconds to see the flaws in that definition if it is regarded as a way to distinguish what is a star from what is not a star, like what is a sandwich from what is not a sandwich!
Personally I think we should not think of scientific definitions as strictly inclusive boxes (especially not "star" or "planet"), but instead think of them as signposts, meant to refer to everything close, but the associations simply get more vague farther away, rather than a line in the sand. So a white dwarf is a star, a red giant is a star, a pre-main-sequence star is a star, etc., because they are studied by stellar astronomers in close association with other more obvious examples of stars. (Similarly for planets.) And a brown dwarf is a star when it is studied by people who want to connect it to other stars, and it is a gas giant planet when studied by people who want to connect it with other gas giant planets. That's just how they are going to do it, after all, you really can't stop them!
  • Skeptical
Likes Drakkith and Motore
FAQ: Spectral class temperature range
What is the temperature range for each spectral class?
Spectral classes are categorized by their temperature ranges as follows: O (30,000 K and above), B (10,000 to 30,000 K), A (7,500 to 10,000 K), F (6,000 to 7,500 K), G (5,200 to 6,000 K), K (3,700 to 5,200 K), and M (below 3,700 K).
How are spectral classes determined?
Spectral classes are determined based on the absorption lines in the star's spectrum, which correspond to different elements and ionization states. These lines are influenced by the star's surface temperature, allowing astronomers to categorize stars into spectral classes.
Why are spectral classes important in astronomy?
Spectral classes are important because they provide a way to categorize stars based on their temperature, which is related to their color, luminosity, and size. This classification helps astronomers understand stellar evolution, star formation, and the physical properties of stars.
Can a star change its spectral class over time?
Yes, a star can change its spectral class over time as it evolves. For example, a star may start as a hot, blue O-type star and eventually become a cooler, red M-type star as it ages and goes through different stages of its life cycle, such as the red giant phase.
What is the significance of the temperature range in spectral classes?
The temperature range in spectral classes is significant because it determines the star's color and the types of nuclear reactions occurring in its core. This, in turn, affects the star's luminosity, size, and lifespan, providing insights into the star's current state and future evolution.
