Spectrophotometry of chromate-dichromate equilibrium
  • Thread starter 24forChromium
  • Tags
    Equilibrium
In summary: Typically, you would select two wavelengths that have different absorbances and measure the absorbances at those two wavelengths.
24forChromium
155
The goal is to determine the relative abundance of the ions using the spectrophotometer. As far as I understand, to determine the relative (or absolute) concentration of a coloured ion in solution, one must have the absorbance/transmittance of the solution at multiple wavelengths.
Once the absorbance/transmittance of a solution over various wavelengths of light is acquired, one should do something with the maximum point of the absorbance/transmittance over frequency graph, which I do not know.
Please explain the following steps, point out any mistakes in my procedure and suggest a wavelength range to examine the chromate-dichromate mixture in.
Chemistry news on Phys.org
No, you select one wavelength for that. Typically we will select the one where absorbance is the highest, as it gives you the highest sensitivity (you can measure lower concentrations).
Google Beer-Lambert law.
Thanks for the reply, so what happens is that, across a certain length of the liquid, the solution will absorb an amount of light that is related to its concentration. Is there a way to find out how much of each ion there is if there is a mixture of two liquids?
Here is what I think: first decide on a certain wavelength, find the total absorbance of the mixture (A_total)
A_total = A_1 + A_2 where A_1 and A_2 represent the absorbance of each chemical at this wavelength
A_total = a_1 * L * C_1 + a_2 * L * C_2 where a represent the absorptivity of each chemical, L is the length of the examined liquid, C represent the concentration of each solute.
Is that right?
OK so far. Now, if you select another wavelength you will have another measurement result. That will yield second equation in the same two unknowns (c1 and c2).
You just have to select such pair of wavelengths that a1/a2 ratios are as different as possible (that will help minimalize errors).
Related to Spectrophotometry of chromate-dichromate equilibrium
1. What is spectrophotometry and how is it used to study the chromate-dichromate equilibrium?
Spectrophotometry is a technique used to measure the amount of light absorbed by a substance at different wavelengths. In the case of the chromate-dichromate equilibrium, this technique is used to measure the absorbance of the solution at different wavelengths, which can then be used to determine the concentration of each species present in the equilibrium.
2. Why is the chromate-dichromate equilibrium important to study?
The chromate-dichromate equilibrium is important because it is a redox reaction that plays a crucial role in many chemical processes, such as corrosion, water treatment, and industrial manufacturing. Understanding the factors that affect this equilibrium can help in controlling and optimizing these processes.
3. What factors can affect the chromate-dichromate equilibrium?
The chromate-dichromate equilibrium can be affected by factors such as pH, temperature, and the concentrations of other ions present in the solution. Changes in these factors can shift the equilibrium towards one direction, causing a change in the ratio of chromate and dichromate ions.
4. How is the concentration of chromate and dichromate ions calculated using spectrophotometry?
The concentration of chromate and dichromate ions can be calculated using the Beer-Lambert Law, which relates the absorbance of a solution to the concentration of the absorbing species. By measuring the absorbance of the solution at different wavelengths, a calibration curve can be created to determine the concentration of each ion at a given absorbance value.
5. What are some potential sources of error in a spectrophotometric analysis of the chromate-dichromate equilibrium?
Potential sources of error in a spectrophotometric analysis of the chromate-dichromate equilibrium include instrument error, contamination of the solution, and improper handling or preparation of the samples. It is important to properly calibrate the instrument, use clean and accurate glassware, and follow standard procedures to minimize these errors.
  • Electrical Engineering
  • Chemistry
  • Other Physics Topics
