Speed at which to hurl a projectile?
In summary, the Archimedes' catapult can launch a 77 kg stone a distance of 180 m. The initial velocity of the stone is > 42 m/s, assuming no wind resistance and an optimal launch angle of 45 degrees. The solution may involve a derivative function.
vabtzeexo
The Archimedes' catapult could hurl a 77 kg stone a distance of 180 m. What was the stone's initial velocity as it left the catapult? The wind resistance is assumed to be insignificant.
[tex]y = v_y0 t - (1/2) g t^2[/tex]
[tex]x = v_x0 t[/tex]
I think the mass of the stone is irrelevant as wind resistance is not taken into account. The problem would be easy if I knew the angle at which the catapult was fired. Here, however, both the angle and the initial velocity of the projectile are unknown. The answer provided by the textbook says the velocity is > 42 m/s. So clearly the 42 m/s is the initial velocity at the optimal angle and if you change the angle, you have to make up for it by launching at a greater initial velocity. I think the solution might have something to do with a derivative function, but other than that, I'm completely lost.
Welcome to Physics Forums.
There is an optimal angle, which gives the maximum range for a projectile launched from ground level. Perhaps your book has a discussion of "range" in the section on projectile motion?
Thanks. I figured it out now. So apparently the optimal angle is always 45 degrees.
Yes. Glad it worked out.
I would first clarify the assumptions and variables of the problem. It is stated that the wind resistance is insignificant, so it can be assumed that the only force acting on the projectile is gravity. The mass of the stone is also given, but as mentioned, it is irrelevant in this case.
To determine the initial velocity of the projectile, we can use the equations of projectile motion. The vertical equation is given by y = v_y0 t - (1/2) g t^2, where v_y0 is the initial velocity in the y-direction (vertical) and g is the acceleration due to gravity. Since the stone is being launched horizontally, the initial velocity in the y-direction is 0. This means that the equation can be simplified to y = -(1/2) g t^2.
The horizontal equation is given by x = v_x0 t, where v_x0 is the initial velocity in the x-direction (horizontal). We can rearrange this equation to v_x0 = x/t.
Plugging in the given values of distance (180 m) and time (unknown), we can solve for the initial horizontal velocity. However, we still need to determine the time of flight.
To find the time of flight, we can use the fact that the projectile reaches its maximum height at the halfway point of its flight. This means that the time of flight is half of the total flight time. Using the vertical equation, we can set y = 0 and solve for t. This gives us t = √(2y/g).
Substituting this value for t into the horizontal equation, we get v_x0 = x/√(2y/g). Plugging in the given values, we get v_x0 = (180 m)/√(2(0.5)(9.8 m/s^2)), which simplifies to v_x0 = 18.41 m/s.
Therefore, the initial velocity of the projectile is 18.41 m/s in the horizontal direction. However, this is not the optimal angle for maximum distance. As stated, the textbook answer is >42 m/s, which means that the initial velocity would have to be increased to achieve this distance. This could be done by increasing the angle at which the catapult is fired, as you mentioned.
In conclusion, the initial velocity of the projectile can be calculated using the equations of projectile motion, but the optimal angle for maximum distance
FAQ: Speed at which to hurl a projectile?
What factors affect the speed at which a projectile is hurled?
The speed at which a projectile is hurled is affected by several factors, including the initial velocity of the projectile, the angle at which it is launched, air resistance, and gravitational pull.
How does air resistance impact the speed of a projectile?
Air resistance, also known as drag, acts against the motion of a projectile, slowing it down as it travels through the air. As the speed of the projectile increases, so does the drag force, causing a decrease in the overall speed.
Can the angle at which a projectile is launched affect its speed?
Yes, the angle at which a projectile is launched can greatly impact its speed. Launching a projectile at a higher angle will result in a longer flight time and a greater distance traveled, but the speed will decrease due to the influence of gravity.
How does the initial velocity of a projectile affect its speed?
The initial velocity, or the speed at which a projectile is launched, is directly related to the final speed of the projectile. The greater the initial velocity, the faster the projectile will travel and the farther it will go before hitting the ground.
What is the ideal speed at which to hurl a projectile?
The ideal speed at which to hurl a projectile depends on the intended purpose of the launch. For maximum distance, a lower launch angle and higher initial velocity are recommended. For accuracy, a lower initial velocity and higher launch angle may be more effective. Ultimately, the desired outcome should be considered when determining the ideal speed.
