Speed bump question - Newton's laws
In summary, when driving over a speed bump at a constant speed, the force of inertia causes the driver to feel lifted from their seat. This is due to a reduction in the centrifugal force experienced while in circular motion. The magnitude of force exerted by the seat on the driver can be calculated using the equation F = mv^2/r, with the assumption that the speed bump is shaped like an arc of a circle. This force is typically reduced due to the decrease in spring compression, causing the driver to be lifted up slightly. However, the seat may still exert a force of 700 N upward, depending on the specific circumstances.
feveroffate
You're driving down the road at 8 m/s and go over a speed bump. When you go over the bump, you feel lifted from your seat. Explain why.
I assumed it was because of inertia, but I'm not sure.
You weigh 700 N. If it is approximated that the speed bump is shaped like an arc of a circle, with radius of 10 m, find the magnitude of force the seats exerts on you as you go over the speed bump.
If F = mv^2/r, then would you just plug everything in directly?
The seat normally pushes upward on you with 700 N (because you push down on it with 700 N weight). While in circular motion, though, you experience a centrifugal force upward that reduces the 700 N.
So while in circular motion, you aren't pushing down on the seat with 700 N so you are lifted up?
It is unlikely you will float up off the seat - that would take a terrific speed - but the force pressing you against the springs of the seat will be reduced so the spring compression will be less and you will go up a little bit.
But would the seat still exert 700 N upward? I mean, would I just plug in the numbers into the equation for the second part?
700 - mv^2/r
FAQ: Speed bump question - Newton's laws
What is Newton's first law?
Newton's first law, also known as the law of inertia, states that an object at rest will remain at rest and an object in motion will remain in motion at a constant velocity unless acted upon by an external force.
How does Newton's second law relate to speed bumps?
Newton's second law states that the acceleration of an object is directly proportional to the net force acting on it and inversely proportional to its mass. In the case of a speed bump, the net force acting on a car is increased due to the change in velocity caused by the bump, resulting in a decrease in speed.
What is the relationship between Newton's third law and speed bumps?
Newton's third law states that for every action, there is an equal and opposite reaction. In the case of a speed bump, the car exerts a downward force on the bump, causing it to compress, and the bump exerts an equal and opposite force on the car, resulting in the car being lifted off the ground.
How do speed bumps affect the momentum of a car?
Speed bumps can decrease the momentum of a car by increasing the time it takes for the car to travel over the bump. This decrease in momentum is due to the increase in force and decrease in velocity caused by the bump.
Can Newton's laws be used to design more effective speed bumps?
Yes, Newton's laws can be used to design more effective speed bumps by considering the force and acceleration needed to slow down a car to a desired speed. By adjusting the shape and size of the speed bump, the force and acceleration can be manipulated to achieve the desired effect.
