Speed dropping to zero when landing during a fall
In summary, the conversation discusses the concept of an object falling in a vacuum and its acceleration due to gravity. It is then questioned why the object's speed drops to zero upon impact, as there seems to be no external force acting on it. The concept of momentum and impulse is brought up, and it is explained that the normal force from the Earth upon impact is greater than the object's weight, causing its speed to drop to zero. This is similar to the concept of a skydiver's parachute opening to slow down their fall.
sgstudent
739
When a box falls in a vacuum, it accelerates at 10m/s^2 and if the mass is 10kg, then it has a net forfeit of 100N. As it falls for 10s, it has a final speed of 100m/s. At the moment of impact, there is a reaction force of 100N acted upon the box by the earth. But since the final speed where net force=0N is 100m/s, then why does the speed drop to 0? Since there is no other force to bring the speed down (decelerate) to 0m/s, so I'm unsure.
Net F=ma
I'm totally not sure what could bring the speed to zero since even if a body has 0 net force, it can have a high speed. And the only way to bring it to zero is if I have a external force to decelerate it to 0 speed first. Thanks for the help!
Hi sgstudent!
Not sure what you mean. There is an external force by the Earth on the block as the impact takes place.
Infinitum said:
Hi sgstudent!
But isn't the external force only the same magnitude as the weight of the object? So in that case won't the object continue at the same speed with no acceleration? Because in a car, if the car is moving at constant speed, that means that the car has no net force. So to stop it, the car must have another additional force to push it in the other direction deceleration it. But in the case of falling, it does not have another additional force to bring its speed down to zero. Thanks for the help Infinitum!
The magnitude of force exerted by the Earth due to impact is given as,
[tex]F = \frac{\Delta mv}{\Delta t} = \frac{mv-0}{\Delta t}[/tex]
And that is not always equal to mg.
I also noticed something in the question
This is not true always.
Oh, so the normal upwards force acting on the object is initially greater than the object's weight to drop its speed to zero? Does it mean that that force is very large as it is almost instantaneous
Yes. This is correct.
If the Earth were totally rigid, the box would have to deform, with the front end of the box coming to a stop first, followed by cross sections higher up. The details of the deformation would depend on whether the box behaves elastically or not. If the deformation were totally elastic, the box would bounce up after the compression wave passed from the bottom to the top, and then got reflected as a tensile wave back down to the bottom again.
Yep! Chet nails it perfectly :smile:
Oh, so we have to incorporate momentum to help us to answer the question? Because sometimes we are given similar questions like to describe a sky diver's falling. When the parachute opens there is a net upwards force in order to slow him down. Until the speed reaches zero which is at the ground. But in this case the ΔT is a lot larger and the upwards force is not constant? But they are also using the same principals? Lastly, what will the ΔT be in thus case? Cos have not learned about momentum yet. Thanks for the help!
That equation above is called the impulse equation, and is generally applicable to impulsive forces(collision). For the parachute problem, the force might be varying as frictional force usually varies proportional to the speed of the object, and so on. You cannot apply the impulse-force equation as this is not a collision situation. You should learn about it soon :smile:
If you are still curious, read up in your text about this and also look at Khanacademy or MIT OCW for a good idea.
Oh how interesting, looks like I only scratched the surface of forces since there's so much relation between momentum and force. Thanks for the help Infinitum!
FAQ: Speed dropping to zero when landing during a fall
Why does speed drop to zero when landing during a fall?
When an object is falling, it is being pulled towards the Earth by the force of gravity. As it approaches the ground, the force of gravity remains constant, but the object's speed decreases due to the opposing force of air resistance. When the object reaches the ground, its speed drops to zero because it has come to a complete stop.
Is it possible for speed to not drop to zero when landing during a fall?
In most cases, speed will drop to zero when landing during a fall because of the forces of gravity and air resistance acting on the object. However, there are certain factors that can affect this, such as the height from which the object is falling, the weight and shape of the object, and the surface it lands on.
Can an object's speed increase when landing during a fall?
In general, an object's speed will decrease when landing during a fall due to the forces of gravity and air resistance. However, in some cases, an object's speed may increase if it is falling from a great height and reaches a terminal velocity, where the force of air resistance equals the force of gravity.
What happens to an object's kinetic energy when its speed drops to zero during a fall?
During a fall, an object's speed and kinetic energy decrease as it approaches the ground. When it reaches the ground and comes to a stop, its kinetic energy is converted into other forms of energy, such as heat and sound.
How does the angle of impact affect the speed when landing during a fall?
The angle of impact can have a significant impact on the speed when landing during a fall. If an object lands on a flat surface, it will experience a greater force of impact, causing its speed to drop to zero faster. However, if an object lands on a sloped surface, it may continue to roll or slide, resulting in a lower impact force and a slower decrease in speed.
