Speed of a mass falling into a star given the mass and radius of the star
TobiasZed
Beginning at rest at an extremely large separation, a ball is released and allowed to fall toward a star of mass 3.90E+30 kg and radius 5.70E+7 m. What is the speed of the ball when it reaches the surface?
square root of (2*G*M)/(r)
I tried the square root of ((2)(6.67*10^-11)(3.90E+30))/(5.70E+7)
I got 1.55*10^-5 and that is wrong. Maybe I am using the wrong equation but this is the one of professor gave me and I don't know what I am doing wrong :-(
Check your calculation.
… and use units!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
