Speed of a photon with wavelength = 500nm?
In summary: Indeed, all photons travel at c; however, as has been said previsouly their rate of propogation can vary (depending on the medium).
delongk
What is the speed and momentum of a photon with wavelength 500nm?
I found momentum by wavelength = h/p but how do I find velocity?? Please help. Thanks. I don't know how to do it without a mass.
Kristin
All photons travel at c.
- Warren
Well that makes it easy. Thank you tons for clearing that up... something so simple, you think they'd tell you that in the book. Thanks again!
Are you sure the question was about the speed of the photon and not the frequency? Since it seems rather odd to ask about speed, since as chroot said above all photons travel at c.
- Warren
I laughed when I read this at first, but then I stopped laughing when I remembered that c varies. Quiz question -- why?
And then there's the extreme case that came up in a thread recently with the apparatus that stops photons completely. That was weird.:bugeye:
this is not correct. c does not vary. the apparent speed of photon propagation can vary in materials.
Good point. I misspoke in an effort to be brief. c is indeed a constant, but the speed of photons depends on the medium. Thanks for catching my error. :blushing:
Actually, I think even that's oversimplifying.
The speed of photons is always c. However, they do not always "make headway" equivalent to c when in materials. (the photons lose headway when absorbed and re-emitted).
Indeed, all photons travel at c; however, as has been said previsouly their rate of propogation can vary (depending on the medium). There is a related thread https://www.physicsforums.com/showthread.php?t=128221&highlight=photons+speed".
FAQ: Speed of a photon with wavelength = 500nm?
1. What is the speed of a photon with a wavelength of 500nm?
The speed of a photon with a wavelength of 500nm is approximately 5.98 x 10^14 meters per second. This is equivalent to the speed of light in a vacuum, as all photons travel at the same speed regardless of their wavelength.
2. How is the speed of a photon with a wavelength of 500nm calculated?
The speed of a photon can be calculated using the formula c = λf, where c is the speed of light, λ is the wavelength, and f is the frequency of the photon. For a wavelength of 500nm, the frequency would be approximately 6.0 x 10^14 Hertz.
3. Can the speed of a photon with a wavelength of 500nm change?
No, the speed of a photon is a constant and does not change. It is always equal to the speed of light in a vacuum, regardless of its wavelength or frequency.
4. How does the speed of a photon with a wavelength of 500nm compare to other wavelengths?
The speed of a photon is the same for all wavelengths. However, photons with shorter wavelengths, such as ultraviolet and gamma rays, have higher frequencies and therefore higher energy levels than photons with longer wavelengths, such as radio waves.
5. What is the significance of a photon's speed with a wavelength of 500nm?
The speed of a photon with a wavelength of 500nm is significant because it is the speed at which all electromagnetic radiation travels. This includes visible light, which has a range of wavelengths, with 500nm falling in the green region of the visible spectrum. Understanding the speed of light is essential in many areas of science, including astronomy, optics, and quantum mechanics.
