Speed of light and Euler's constant
In summary, the speed of light is a fundamental constant in physics, denoted by 'c', approximately equal to 299,792,458 meters per second in a vacuum. It plays a crucial role in the theory of relativity and various equations in physics. Euler's constant, often represented as 'e', is a mathematical constant approximately equal to 2.71828, which serves as the base for natural logarithms and appears in numerous mathematical contexts, including calculus and complex analysis. Both constants, while originating from different fields, highlight the interplay between mathematics and physics.
hassan23
TL;DR Summary
Does f = nce² have any significance where c is the speed of light and e is Euler's constant and f and n are variables?
I am a newbie and the last time I did physics was in secondary school. I was researching the topic of pi and came across the euler's constant and was wondering about the relationship between euler's constant and the speed of light specifically ce². I think that works out to be one third the speed of light.
hassan23 said:
TL;DR Summary: Does f = nce² have any significance where c is the speed of light and e is Euler's constant and f and n are variables?
No. The easiest way of seeing this is to consider that we can make the speed of light come out to be any arbitrary number just by changing our units.
For example a century ago we would all agree that the speed of light was about 186000 miles/second. As a result of several historical accidents a mile is defined to be 5280 feet. Now we ask what a foot is, and we learn that it is more or less the the length of the foot of some long-deceased English king. So.... If the king had had a different shoe size light would still be moving at the the same speed but we wouldn't call that speed 186000 miles/second. That suggests that relationships between the true constants like pi and e and quantities like the speed of light or sound whose values change with our choice of units must be accidents with no real significance.
On the other hand, there are physically measurable quantities with values that are meaningful because they do not depend on our choice of units. For example, if I am running from a hungry bear, both my speed ##S_N## and the bear's speed ##S_B## will depend on the units we're using. However, the ratio ##S_B/S_N## is the same no matter what units we use because the units cancel - and the outcome depends on whether that ratio is greater than or less than unity without considering the units at all.
A less frivolous example is the fine structure constant (Google for that) which is also a ratio in which all the units cancel. We routinely see questions about "what would happen if the speed of light were something else?"; these questions always turn out to be asking what would happen if the fine structure constant had a different value.
Likes russ_watters, ohwilleke, DeBangis21 and 6 others
Correction e=eulers number which is different from eulers constant (γ).
Likes Delta2, DeBangis21, pinball1970 and 1 other person
We figured that's what you meant :)
But still good to correct
Likes hassan23, DeBangis21, pinball1970 and 1 other person
hassan23 said:
specifically ce².I think that works out to be one third the speed of light.
You think incorrectly. This implies ##e = 1/\sqrt{3}##. This is true neither for Euler's number nor Euler's constant.
Likes hassan23
Thanks everyone for the replies. I have now moved on to learning about the fine structure constant and I see a formula for it that has the speed of light and pi in it. This brought me back to my question here. I wonder if there is a link between Euler's constant and the fine structure constant.
Thread closed temporarily for Moderation...
No and again it's Euler's number, or e, which is different from the e that appears in the fine structure constant.
Per this wikipedia article, https://en.wikipedia.org/wiki/Elementary_charge
##e = \sqrt{4\pi\alpha}\sqrt{\epsilon_0\hbar c}##
In this definition e is the unit of electric charge, not the Euler number.
Thread will remain closed, as the question has been answered.
FAQ: Speed of light and Euler's constant
What is the speed of light?
The speed of light in a vacuum is approximately 299,792,458 meters per second (about 186,282 miles per second). This constant is often denoted by the letter "c" and is a fundamental constant in physics.
Why is the speed of light considered a universal constant?
The speed of light is considered a universal constant because it is the same in all inertial frames of reference, regardless of the motion of the light source or the observer. This invariance is a cornerstone of Einstein's theory of relativity.
What is Euler's constant?
Euler's constant, often denoted by the letter "e," is an irrational number approximately equal to 2.71828. It is the base of the natural logarithm and arises in various mathematical contexts, particularly in calculus and complex analysis.
How are the speed of light and Euler's constant related in physics or mathematics?
While the speed of light and Euler's constant are both fundamental constants, they are not directly related. The speed of light is a physical constant relevant to the theory of relativity and electromagnetic theory, while Euler's constant is a mathematical constant important in exponential growth and complex analysis.
Can the speed of light change under different conditions?
The speed of light in a vacuum is a constant and does not change. However, the speed of light can be slower when it travels through different media such as water, glass, or other transparent materials. This reduction in speed is due to the interaction of light with the atoms in the medium.
15K
