Speed of light and the universe
In summary, the speed of light is still the fastest speed because the speed of the universe really doesn't count. There is nothing theoretical about our knowledge of the current expansion even to the point of knowing that the rate of acceleration is decreasing slightly over time. Things that are totally supported by experiments/empirical evidence are way beyond just theoretical. The expansion speed of the universe is still unknown, but theoretical calculations suggest that it may be faster than the speed of light.
Jakecp
50
I have been thinking about light and i have read that the universe expanded faster than speed of light. So , then why people say that the speed of light is the fastest thing known if people know that the universe expanded faster than speed of light . Also , if the universe could have expanded faster than the speed of light , can we make something that can travel faster than speed of light using expansion ?
Space news on Phys.org
Well, let me correct you on one thing- we know almost nothing about how the universe expanded, or even about how it expands now. It is all theoretical. If it is true, however, the speed of light still would be the fastest speed, because the speed of the universe really doesn't count. We will never achieve a speed greater than the speed of light. It is against the laws of physics. I am not sure, but I believe it is addressed in the FAQs why that is. I can kind of explain why, but I am going to let a more experienced person give you a more detailed explanation.
I just want to add, I checked, and there is nothing on the FAQs. (Mentors, I would suggest adding an FAQ about the speed of light, I have noticed a lot of similar questions on here).
this thread isn't to do with the speed of light as such, rather the expansion speed of the universe
which is what the link I provided give lots of info on
there is a FAQ thread on the speed of light ...
https://www.physicsforums.com/threads/why-is-the-speed-of-light-the-same-in-all-frames-of-reference.534862/
Dave
Nonsense. We know quite a lot about the current expansion. For example, we know that the recession of galaxies at the edge of the observable universe is about 3c. There is nothing theoretical about our knowledge of the current expansion even to the point of knowing that the rate of acceleration is decreasing slightly over time. Things that are totally supported by experiments/empirical evidence are way beyond just theoretical.
True. It is not proper motion, just recession.
also true although I hesitate to use the word "never" in such contexts even though I think it applies in this case.
I don't agree , it should count as motion because we are moving space while it expands because when the universe expand it can't be filled with nothing . It must be filled with dark matter or something so it should count as motion and then there is a speed faster than light even though it does not count as motion and we may be able to make some kind of expansion with 3c speed or more . Also , who wrote the rules of the universe? Why c is the fastest speed? Why it should be? It has no Mass right? it should also not count as motion because it is just a wave or nothing as the space expansion. Why space expansion does not count and light does? Light is not motion because nothing at all is moving because light has no mass.
So you have a couple of PHD's hanging on your wall that you can make such unsubstantiated claims ?
it doesn't really matter if your agree or not, studies have been done on the subject by people well above your and my pay-rates and intelligence
Did you even bother to read through the link I gave ? did you try and understand any of it ?
I suggest strongly that you take a few steps back and do some learning before arguing against some well established theories
Dave
Jakecp said:
I don't agree ...
Irrelevant. It's not up for a vote. As Dave said, you should learn some basics before spouting nonsense. This stuff is not intuitively obvious but thinking that your opinion trumps facts is not science it's voodoo.
Likes nikkkom
Yes, I shouldn't have added the part about the current expansion. I was just trying to make the point that what happened in the past is impossible to know. I have read many theories about what could have happened. We don't know anything about it for sure.
Ok, then if you want to count it as faster than the speed of light, try recreating the Big Bang. As @phinds said, it is just recession, not proper motion, and light is motion. It just is. It is fact. Many, many expariments have tried to pass the speed of light. None have succeeded. One claimed to have succeeded but it was a bad expariment, and they retracted their results.
If you are thinking about the OPERA experiment it was not (and is not) their physics goal to pass the speed of light. Their neutrino speed measurement was a byproduct, something they could do in addition to their main physics goal (which is measuring neutrino oscillations into tau neutrinos). It is not a bad experiment in itself and it has been successful in its main physics goal. They simply suffered from being a bit too eager to announce their FTL measurement when they probably should have taken a step back and triple-checked everything.
Yes, it is impossible to know what happened in the past with certainty, but that doesn't mean that all ideas are equally relevant. This is why humans have developed science: we can make observations, develop models, and make inferences about the universe -- both past and present -- that can then be tested.
Many historical observations can be well-understood in the context of modern science: if you came across a crater, how much would you bet it was due to a meteorite and not an abandoned excavation project by ancient earth-visiting aliens? Neither can be verified with certainty, but I suspect I know which explanation you're betting on.
The universe does not expand at a given speed. That's misconception number 1. The speed at which objects recede from one another, v, is a function of the expansion rate, H, and their distance apart, r, via Hubble's Law, v = Hr. The more distant an object, the faster it appears to recede from us. This is true no matter what kind of expansion we're talking about. Notice that as long as H is positive, there is always a distance at which objects will recede with a speed greater than light, r = c/H. There is nothing wrong with this since the objects are at rest locally, their relative velocity due solely to the expansion of space. So misconception number 2, which is regrettably pervasive in the popular science arena, is that the universe underwent some kind of superluminal expansion early on. These are references to primordial inflation, which indeed was a unique phase of expansion in the early universe, notable because length scales increased exponentially.
So, no, space does not -- ever -- expand faster than the speed of light because expansion does not occur at a given speed. And, while objects do indeed recede from one another at certain speeds, and if they are far enough apart they will recede form one another at speeds surpassing that of light, this is true always and is not a unique property of inflation or any other type of expansion.
Likes julcab12 and marcus
That's interesting. I was not aware of that, all I knew was the false neutrino speed part.
The OPERA result turned out to have a very mundane explanation eventually.
A fiber optic cable was wrongly connected.
wait , i am not sure of what i am going to write but , galaxies are going apart from each other faster every time right? so you say that they receed at 3c which means that they are moving at 3c further away?
Also , we know almost nothing of dark energy ( i think) what if dark matter and energy can travel faster than C? did Einstein knew of this in his relativity theory?
That is a very garbled sentence so I'm not sure what you are asking. There are objects at the edge of the observable universe that are receding from us at 3c. There are objects that are closer to use that are receding at 2c. There are objects that are closer still that are receding at 1c. Pick a number. You can find an object at the appropriate distance that is receding at the number times c.
This is NOT the "rate of expansion of the universe", its just the recession of objects compared to Earth.
That makes no sense at all.
Dark energy is not a thing that can have a speed and dark energy and dark matter are totally unrelated to each other. Einstein did not know of either one, and that makes no difference to anything at all.
I am sure it has been covered already, but the finite speed of light limits particles speed.
space is not a particle or matter. Matter can not move at the speed of light. Space is not matter.
Well , if he didn't took that in consideration , why can't dark matter or energy travel faster than c? I know that is the rule einstein once said but why? i have not read the relativity theory yet and i know that c is that fast because it has 0 mass , but how did he knew that , that was the fastest speed ? I think light can be slowed down but don't know how. The fact , is there any chance of something beeing faster than light?
If space is not matter , then what is it? How should i imagine the limits of space? What limits the space ? A wall? Nothing? If nothing limits the space , how can it have a limit if the limit is nothing ?
So , another question , the universe is expanding from everywhere? or just from the edges?
Not as far as we know. There are problems involving causality if something could travel faster than c. Note that c is the speed of light in a vacuum. In a medium, such as glass or water, light slows down and we can make things travel faster through these mediums than light does, leading to this effect: https://en.wikipedia.org/wiki/Cherenkov_radiation
Saying that space has no limit does not mean that space has a limit and that that limit 'is nothing'. It means the limit does not exist.
As for what space is, space is, well, space. Literal space. The space between objects. The framework made up of three dimensions in which we can move freely in any of them.
There is no known edge to the universe. Universal expansion means that the distance between all unbound objects increases over time. It does not necessarily mean that there is an expanding edge to the universe, though that is a possibility.
Jakecp said:
... just from the edges?
We know from observation that the observable universe is expanding and all of it expanding except gravitationaly bound matter, (galaxies etc).
So galaxies everywhere are getting more distant from other galaxies, but the galaxies themselves don't expand.
This is what leads to the conclusion of there being a 'big bang', a starting point in time for it.
We don't know if there is more universe beyond what is observable, (or what logically follows from what is observable.)
There could be infinite space beyond what we will ever be able to observe, or maybe the observable universe is all there is.
One possibility is that the universe as a whole is infinite, in which case it always was infinite, yet it is expanding too.
You might say 'wait a minute', how can something infinite get bigger?
Well 'infinite' can do things which finite can't.
https://en.wikipedia.org/wiki/Hilbert's_paradox_of_the_Grand_Hotel
The problem with this point of view is how could you possibly explain the boundary at the edge of the observable universe and how much hubris do you think it takes for us to assume that we are the center of everything? For those reasons, my opinion of the point of view that the OU is all there is is not printable within the forum guidelines :smile:
I am not saying that this is my view, only that we don't know what there may be beyond the observable.
Hence we can't positively rule anything in as being most likely or anything out as being impossible.
I meant that space outside of the observable universe could be any possibility ranging from nothing to infinite.
So you have 2 problems here:
1. Dark mater and dark energy are not the same thing, nor are they dependent on each other. They are completely different. I believe some scientists don't choose to call it dark energy, to avoid this confusion.
2. Scientists are in no position to make any claims about the speed of dark mater or dark energy. As a revision to number 1, they have a large similarity: we bearly know any of the properties of either.
The assumptions of dark energy and dark matter fit to the data we have. From this the dark energy is a vacuum energy which fills the universe homogeneous. So, its density is the same everywhere.
Think of a gas in the corner of a box. The gas (its molecules) will travel until its density is the same everywhere within the box. Once having reached this state of equilibrium the gas will not travel anymore, though the molecules it consists of are still able to move.
In contrast to the gas the dark energy is perfectly homogenous. It has this state from the very beginning, hence it can't travel at any time.
  • #31
i am doing a proyect of this but i don't understand something. Why does the expansion of the universe is not motion and light is? In both nothing is moving , is there?
  • #32
another question .
There is something moving when the universe expand , space and time because without the universe there is no space and time out of it so we can't go out of it because there is nothing , nor space nor time to travel but but when the universe is expanding at 3c+ we have new space matter moving , dark matter filling the gaps into that space at 3c. In light , is there something really moving? If it has 0 mass is it really something? Why? If light is just a wave with no mass which means it can't be touched , smelled or that. It has no mass and for something to exist it has to have mass otherwise it is nothing right?
  • #33
We know with great certainty about what happened in the past, we need only gaze at distant galaxies to see the universe as it was billions of years ago. Reconciling those ancient views with our observations of nearby galaxies is a part of modern cosmology.
  • #34
No. There are several things without mass which exist. Light is just one of them. Another example is the gluon, a massless subatomic particle.
  • #35
and why space does not exist then?
  • Cosmology
  • Cosmology
  • Cosmology
