Speed of light in lossy dielectric medium
In summary, the speed of light in a dielectric medium is ##v=\frac{c}{\sqrt{\epsilon_r}}##, where ##c## is the speed of light in vacuum and ##\epsilon_r## is the relative permittivity.
WhiteHaired
It is usually written that the speed of light in a dielectric medium is ##v=\frac{c}{\sqrt{\epsilon_r}}##, where ##c## is the speed of light in vacuum and ##\epsilon_r## is the relative permittivity. But, how can it be calculated for lossy and not necessarily low-loss dielectrics, i.e. those with a complex permittivity ##\epsilon_r=\epsilon'-j\epsilon"##?
a) ##v=\frac{c}{\sqrt{\epsilon'}}##?
b) ##v=\frac{c}{\sqrt{|\epsilon_r|}}##?
c) None of above?
Related to previous question: If the natural resonance frequency of a resonant mode in an empty (vacuum) microwave cavity is ##f_0##, which is the natural resonance frequency for the same mode, but with the cavity completely-filled with the previous lossy dielectric material?
a) ##f=\frac{f_o}{\sqrt{\epsilon'}}##?
b) ##f=\frac{f_o}{\Re{(\sqrt{\epsilon'-j\epsilon"})}}##?
b) ##f=\frac{f_o}{\sqrt{|\epsilon_r|}}##?
c) None of above?
All of the textbooks and webs (that I've found) about this topic, consider only lossless dielectrics or approximations for low-loss dielectrics, but no general expressions.
It helps to understand the equation, not just know it. Ignoring, for the moment, frequency dependence of permittivity and permeability, electromagnetic wave is described by the following equation.
[tex]\nabla^2 E = \mu \epsilon \frac{\partial^2 E}{\partial t^2}[/tex]
In your case, ##\small \mu = \mu_0## and ##\small \epsilon = \epsilon_r \epsilon_0##. And to make things easier, let's take solution of the form ##E = E_0 e^{i(k\cdot x - \omega t)}##.
[tex]- k^2 E = - \mu_0 \epsilon_r \epsilon_0 \omega^2 E[/tex]
Since ##\small c^2 = 1/\mu_0\epsilon_0##, the above gives you ##k^2 = \frac{\epsilon_r \omega^2}{c^2}##.
Now we can look at velocity. Since you seem to be interested in the phase velocity, we are looking at points in space and time where ##\small E## has same phase as ##\small E_0##. In other words, ##\small k \cdot x - \omega t## is purely imaginary. Realizing that ##\small x## and ##\small t## are always real, that gives you a simple enough formula.
[tex]Re(k)\cdot x = Re(\omega)t[/tex]
Differentiating both sides, we get the equation for phase velocity.
[tex]v = \frac{dx}{dt} = Re\left(\frac{\omega}{k}\right)[/tex]
From earlier, we have ##\frac{\omega^2}{k^2} = \frac{c^2}{\epsilon_r}##. So we have to take the square root here, keeping in mind that we are working with complex numbers.
[tex]v = Re\left(\frac{c}{\sqrt{\epsilon_r}}\right)[/tex]
If ##\small \epsilon_r## is real, that trivially simplifies to your formula. It is, however, not. We need to take square root of a complex number. In other words, we are looking for some ##\small z = a + ib## such that ##\small z^2 = \epsilon_r##.
[tex]a^2 - b^2 + 2iab = \epsilon' + i\epsilon''[/tex]
This is a system of equations with four possible solutions, but only one is physical. It's a bit messy, so I only give the result for a, which is all we need for the real part above.
[tex]a = \frac{\sqrt{\epsilon' + \sqrt{\epsilon'^2 + \epsilon''^2}}}{\sqrt{2}}[/tex]
So the correct formula for phase velocity is as follows.
[tex]v = \frac{\sqrt{2}c}{\sqrt{\epsilon' + \sqrt{\epsilon'^2 + \epsilon''^2}}}[/tex]
Which again simplifies to formula you have whenever ##\small \epsilon'' = 0##.
Thank you very much.
FAQ: Speed of light in lossy dielectric medium
1. What is the speed of light in a lossy dielectric medium?
The speed of light in a lossy dielectric medium is lower than the speed of light in a vacuum. This is due to the interaction between the light and the molecules of the medium, which causes the light to slow down.
2. How is the speed of light affected by the properties of a lossy dielectric medium?
The speed of light in a lossy dielectric medium is affected by the dielectric constant and the conductivity of the medium. A higher dielectric constant or conductivity results in a lower speed of light.
3. What is the relationship between the speed of light and the refractive index of a lossy dielectric medium?
The speed of light is inversely proportional to the refractive index of a lossy dielectric medium. This means that as the refractive index increases, the speed of light decreases.
4. Can the speed of light in a lossy dielectric medium be greater than the speed of light in a vacuum?
No, the speed of light in a lossy dielectric medium can never exceed the speed of light in a vacuum. The speed of light in a vacuum is the maximum possible speed of light.
5. How is the speed of light in a lossy dielectric medium measured?
The speed of light in a lossy dielectric medium can be measured using various experimental methods such as interferometry or time-of-flight measurements. The dielectric constant and conductivity of the medium must also be known in order to calculate the speed of light.
