Speed of Light in Materials: Explained
In summary: Sherwood writes: In summary, the speed of light in a material is slower than in a vacuum, but this is only an apparent difference.
AndrewGRQTF
27
It is commonly said that the speed of light when traveling inside materials is lower than that of light in vacuum, but I don't understand how this can be true. It is the same light traveling, so how can it act differently? Does light appear to be slower in materials because it is not following a straight line and scatters off of particles and gets emits in many angles?
No. This is a common misconception.
Light is a pattern of electric and magnetic fields that induce each other. That is true both in vacuum and in matter, but the relation how electric fields induce magnetic fields and vice versa changes in matter, slowing light down.
Likes AndrewGRQTF and Ibix
The medium is made up of charged particles which are sources for the electromagnetic field, and you can't understand light in a medium without taking those sources into account. So whether it's the "same light travelling" depends on semantics. If you track a water wave approaching the beach as it begins to break, is it the "same wave travelling"? The shape and behaviour is different nearer the shore because the environment is different, whether you see it as the same wave or not.
Likes nitsuj and AndrewGRQTF
It is the same light, but light interacts with matter, so in the absence of matter that interaction isn't present. That's the reason for the difference.
What is meant at the end is the apparent speed of light. The apparent "slower speed" is the result of the superposition of two radiative electric fields, the incoming radiation and the re-radiation by the atomic electrons inside the materials, both of which travel at the normal speed of light c. On Bruce Sherwood’s homepage (https://brucesherwood.net/) you find an article “Refraction and the speed of light” dealing with this question.
Related to Speed of Light in Materials: Explained
1. What is the speed of light in materials?
The speed of light in materials refers to the speed at which light travels through a particular material. This speed is different for each material and is typically slower than the speed of light in a vacuum, which is approximately 299,792,458 meters per second.
2. Why does the speed of light vary in different materials?
The speed of light in materials is affected by the material's refractive index, which is a measure of how much the material can bend or slow down light. Different materials have different refractive indices, which can cause the speed of light to vary.
3. How is the speed of light in materials measured?
The speed of light in materials is typically measured using a device called a spectrometer. This device measures the time it takes for light to travel through a material and calculates its speed based on the distance and time.
4. Can the speed of light in materials be faster than the speed of light in a vacuum?
No, according to Einstein's theory of relativity, the speed of light in a vacuum is the maximum speed at which anything can travel. Therefore, the speed of light in materials can never be faster than the speed of light in a vacuum.
5. How does the speed of light in materials affect everyday objects?
The speed of light in materials can affect everyday objects in various ways. For example, it can determine the transparency of materials, such as glass, and the colors we see. It also plays a crucial role in technologies such as fiber optics and the development of new materials for communication and transportation.
9K
