Speed of Light Puzzle: Is c a Localized Value?
In summary: Suppose we have two clocks, one that is set to the standard time in Paris and one that is set to the standard time in London. It's possible that the two clocks are running at the same speed, but because of the difference in the locations of the clocks, the time on the Paris clock is moving more slowly than the time on the London clock. This is analogous to the situation where the speed of light may be constant throughout the universe, but because of the difference in the locations of the observers, the time on their clocks may appear to be moving at different speeds.In summary, the speed of light may be constant throughout the universe, but it may be moving slower in one place than another.
  • #36
jbriggs444 said:
I would disagree mildly. We can infer something about the speed of light [fine structure constant or other property] outside the observable universe. We just can't test that inference.
And therefore any such inference must be unscientific.
I have no objections to people formulating theories about what exists outside the observable universe, but it doesn't constitute "science" as I understand it.
Space news on Phys.org
  • #37
GuyBarry said:
You're getting it back to front.
You are missing @Orodruin's point. A meter is roughly as far as our monkey arms reach. A second is roughly how long it takes our monkey hearts to beat. The invariant speed at which light travels is simply the unit conversion factor between time and length - so in SI units it's roughly the ratio of the length of one monkey heartbeat to one monkey arm length.
What would it mean to change the speed of light? Could be several things.
First, it could mean that light doesn't travel at the invariant speed - i.e. photons aren't massless. I believe the current experimental bound on their mass is around 10-50kg, but it's still possibly non-zero. In that case photons wouldn't have a single defined speed, so this probably isn't what you mean.
Second, it could mean that you want to use different units - maybe you could use so called geometric units such as seconds and light seconds, so c=1. This is obviously trivial and changes nothing, so it probably isn't what you mean either.
Third, it could mean you want to change the ratio of one monkey heartbeat to one monkey arm length. Not just by breeding a longer armed monkey, but by altering fundamental physics so that hearts in general beat slower. It turns out that what you actually want to do is vary the fine structure constant. If you keep that fixed, doubling the speed of light changes other constants to do with electromagnetism such that our monkey arm lengths double and the speed of light remains 3×108monkey arm lengths per monkey heart beat. Varying the fine structure constant let's you change the ratio, and I suspect this is what you actually want to think about.
You are missing the point here too. We construct a model of a homogeneous universe (which turns out to imply finite but unbounded, flat, or open - but flat matches observation best) because it's simpler than any other model and pretty much consistent with what we see. The hypothesis being tested is not "is the universe infinite, flat, and homogeneous" but "is the universe experimentally distinguishable from our model of an infinite, flat, homogeneous one". If it's not distinguishable then our model is good (whatever the truth is about the unobservable stuff). If it is distinguishable then we need to revisit something. So far it works, with a bit of tweaking. Sure we could develop models that do other stuff outside the observable universe, but why bother? We can't test it.
Likes Orodruin and jbriggs444
  • #38
Neither of those is true.
The definition of the second goes back to around 1000 AD. It was based on the theory that the period of the Earth's rotation was constant. That period was divided into 24 hours, each divided into 60 minutes of 60 seconds each. So the original definition of the second was 1/86400 of the period of the Earth's rotation, and this lasted right up until the mid-20th century after it had been demonstrated that the Earth's rotation was slowing down.
The intended definition of the metre - first proposed in the 17th century - was the length of a pendulum with a half-period equal to one second. However it was discovered that this definition was dependent on fluctuations in the Earth's gravity, and so in the late 18th century a definition relating to the Earth's circumference was adopted - one ten-millionth of the distance from the North Pole to the Equator, along the meridian passing through Paris. There have been several redefinitions since then, as I mentioned in an earlier post.
The first quantitative estimate of the speed of light was made by Ole Rømer in 1670, by observation of the periods of one of Jupiter's moons. Since then it's been refined by centuries of experimentation. Michelson's 1926 experiment determining the speed of light between Mount Wilson and Lookout Mountain was probably the original basis for the value we use today, but it took until 1983 until the current standard was adopted.
It's difficult to know. The values of so many other physical constants are related to the speed of light that any change would have huge consequences on the rest of our theories of physics.
I don't actually want to do anything. I am simply saying that if the value of the speed of light - or indeed the fine-structure constant, or anything else - were different outside the observable universe, we'd have no way of gathering any evidence.
The fine-structure constant, being a dimensionless constant, is independent of any system of units, and so I suppose it's in a sense more fundamental than the others; but we're no more able to gather evidence of the value of the fine-structure constant outside the observable universe than of any other value.
Indeed - Occam's razor, as has been mentioned before. That's a philosophical principle though, and not a scientific one.
No we can't. And that's why any theory of what exists outside the observable universe is unscientific.
It may well be that the universe is not experimentally distinguishable from our model of an infinite, flat, homogeneous one, but also that the universe is not infinite, flat, and homogeneous. And there's no way of experimentally falsifying that hypothesis.
Ultimately, there are limits on what we can know about the universe, and any theory outside those limits is not a scientific theory.
  • #39
It depends on what you mean by "theories about what exists outside the observable universe".
If you mean a theory that says something like: "Things are one way within our observable universe, but suddenly change into something completely different as soon as you cross the boundary into the unobservable universe", yes, I would agree that would be unscientific.
If you mean a theory that says something like: "The simplest model of the universe that accounts for what we can observe does not have a boundary at the edge of what we can observe; therefore it is simpler to assume that things just continue on the same way past the boundary", then no, I do not agree that that would be unscientific. The absence of the boundary is not just put in by hand; it emerges from the same theoretical assumptions that you have to make to account for what we do observe.
  • #40
My reach is about a metre. My heartbeat is around sixty per minute. Whether that's the definition of the metre or the second isn't important. Replace every instance of "monkey arms" with "some fraction of the Earth's circumference" and "monkey heartbeat" with "some fraction of a day" if you want. It changes nothing about my argument.
So what? The invariant speed is the scale factor between time and length units. How long it took us to measure this is irrelevant.
Are you basically complaining that popularisations of cosmology don't always distinguish clearly between our models (which make falsifiable predictions about the observable universe and also make non-falsifiable predictions about areas outside the observable universe) and the reality (which may not even exist outside the observable universe)? If so, it's a fair point. I'll just observe that striking the balance between "enough detail" and "not swamping lay readers in pedantry" is tough, and very much an individual taste.
Likes Orodruin
  • #41
GuyBarry said:
You're getting it back to front. The units we use now were conveniently chosen so that they more or less correspond to the ones that were used previously.
I would say you are completely missing the point with this comment. The historical ordering is obvious.
Edit: I see @Ibix has already written two well formulated posts on this theme. Two likes that would be more if I could.
  • #42
Guy, are you here to
  1. Learn something
  2. Teach something
  3. Or just to argue
I'd like to know which in order to better craft my next message
  • #43
  1. Learn something
  2. Teach something
  3. Or just to argue
All three. :-)
No, I'm just being flippant. It's a really interesting discussion but I'm too tired to contribute any more at the moment. Thanks to everyone who's taken part.
  • #44
And with that, this thread can be closed.
Likes jbriggs444
  • Cosmology
  • Cosmology
  • Cosmology
  • Cosmology
