Speed of Light when not in a vacuum?
In summary, the conversation discusses the concept of time dilation and its relationship to the speed of light. It is established that time is relative to one's distance from a mass and the speed of light is constant. However, there are concerns about measuring the speed of light against a variable like time and the potential variability of time in calculations of distance.
Orwell1984
In a vacuum the speed of light is a constant. What if its not in a vacuum?
Okay, as always I'm confused. I'm very interested in physics but am a layman.
Alright, so we know that time is relative to one's distance from a mass, so that as we go further from the Earth, let's say, time moves faster. I take that to mean 1 second on Earth is slower than 1 second outside our solar system. Correct so far?
We also know that the speed of light is 299,792,458 meters per second. Now, since 1 second gets progressively faster as you move away from the Earth, shouldn't the distance that time travels become shorter also as time gets faster? Of course, I'm assuming light does have a constant speed.
Now if the preceding statement is correct, then my real question is why measure the speed of light against a variable like time? Furthermore, when we calculate that a star, for instance, is 10 light years away from us, do we take into account the variability of time such that 10 light years really means, let's say, 9.99999999999999999 light years?
Science news on Phys.org
Then it travels slower than ##c## by a factor of the refractive index, ##n##, of the medium. This speed ##c/n## is also constant (it doesn't change with time - assuming the physical properties of the medium aren't changing), but does depend on your frame of reference (it is not invariant, which is to say that observers in motion with respect to the medium will measure different values) unlike the speed in a vacuum.
For future information, it's worth asking the question you actually want to ask. None of this has anything to do with light traveling in a medium. Note - when I wrote this, post #1 appeared to be just the text quoted in #2. Post #3 has been duplicated in #1 at some point.
It is true that if you get two identical clocks and confirm that they both tick at the same rate, then carry one far from the solar system and look back at the other with a telescope, it will appear to be ticking slightly slowly. However I would not say that this means that one second on Earth is slower than one second outside the solar system. One second is one second is one second.
The underlying physics is closer to the idea that you can take a shorter path round a corner by taking the inside path. One meter is one meter is one meter, but there are fewer meters used if you go round the corner on the inside path. Similarly, there are fewer seconds used on the path through spacetime that you follow deep in a gravitational well.
We don't. The speed of light is defined, as is the second. The meter is a derived unit, following from those two definitions.
When we say a star is ten light years away, we're rounding off to the nearest tenth of a light year, or even coarser. This kind of effect is on the level of fractions of a light second.
In principle, yes, you'd have to decide exactly what you mean by "distance" when reporting distances in curved spacetime. In practice, it makes no measurable difference.
Likes davenn
No
It doesn't ... 1 sec = 1 sec = 1 sec, regardless of where you are in the universe
Likes phinds
The speed of light is slower in any medium other than a vacuum. It's speed depends on the medium
For example, in an optical fibre used for telecommunications, the speed of light is only 70% that of when in a vacuumDave
FAQ: Speed of Light when not in a vacuum?
1. What is the speed of light when not in a vacuum?
The speed of light when not in a vacuum is slower than its speed in a vacuum, which is approximately 299,792,458 meters per second. The exact speed of light in a non-vacuum environment depends on the medium it is traveling through, such as air, water, or glass.
2. How does the speed of light change in different mediums?
The speed of light changes in different mediums due to the properties of the medium. For example, light travels slower in denser mediums because the particles in the medium can absorb and re-emit the light, causing it to slow down. The speed of light is fastest in a vacuum because there are no particles to interact with.
3. Can the speed of light be faster than its speed in a vacuum?
No, the speed of light cannot be faster than its speed in a vacuum. This is because the speed of light is a fundamental constant of the universe and is the maximum speed at which all matter and information can travel. It is impossible for anything to travel faster than the speed of light.
4. How does the speed of light affect our perception of time?
The speed of light is also known as the universal speed limit because it is the fastest speed at which anything can travel. This has implications for our perception of time, as time appears to slow down for objects that are traveling close to the speed of light. This phenomenon, known as time dilation, has been observed in experiments and is a key principle in Einstein's theory of relativity.
5. Can the speed of light be measured in non-vacuum environments?
Yes, the speed of light can be measured in non-vacuum environments using various experimental methods. These methods involve measuring the time it takes for light to travel a known distance through the medium and then using the speed formula (speed = distance/time) to calculate the speed of light in that particular medium. However, due to the complexities of measuring the speed of light in different mediums, the speed of light in a vacuum is often used as a reference point for comparison.
11K
12K
15K
