Speed of particle Galilean relativity
In summary, one particle created in a high-energy particle accelerator has a speed of 0.650 c in the laboratory, while the speed of each particle relative to the other is 0.950 c. Using Galilean relativity, the speed of the second particle can be calculated as 0.300 c. However, using special relativity, the speed is found to be 0.784 c due to the effects of time dilation and length contraction.
j3dwards
32
Two particles are created in a high-energy particle accelerator and move off in opposite directions. The speed of one particle, as measured in the laboratory, is 0.650 c, and the speed of each particle relative to the other is 0.950 c, where c = 3 × 108 m/s is the speed of light in vacuum.
What is the speed of the second particle, as measured in the laboratory? Compare your result to what you would obtain from Galilean relativity.
u' = u - v
So galilean relativity says that the laws of motion are the same in all intertial frames.
So the speed of the second particle is just: 0.950 c - 0.650 c = 0.300 c
correct?
j3dwards said:
So the speed of the second particle is just: 0.950 c - 0.350 c = 0.600 c
Earlier you wrote:
So there's a typo somewhere.
But that's the right idea for Galilean relativity. What about special relativity?
Oh yes sorry, so the speed of the second particle is 0.300c.
And for special relativity: u' = u - v/(1-uv/c2) = (0.950c - 0.650c)/(1-(0.95c x 0.650c)/(c2) = 2.35 x 108 = 0.784c
Is this right?
Is this right?
Looks good to me!
Related to Speed of particle Galilean relativity
1. What is the speed of light according to Galilean relativity?
The speed of light is considered infinite according to Galilean relativity, meaning that it is not limited by any set value. This is because in Galilean relativity, the speed of light is independent of the observer's frame of reference.
2. How does Galilean relativity explain the speed of particles?
In Galilean relativity, the speed of particles is relative to the observer's frame of reference. This means that the speed of particles can appear different depending on the observer's perspective, but it does not change the actual speed of the particles themselves.
3. Can the speed of a particle ever exceed the speed of light in Galilean relativity?
No, according to Galilean relativity, the speed of light is considered infinite and cannot be exceeded. Therefore, the speed of particles can never exceed the speed of light in this theory.
4. How does the speed of particles change in different frames of reference in Galilean relativity?
In Galilean relativity, the speed of particles remains the same in all frames of reference. It is the observer's perception of the speed that may change, but the actual speed of the particles does not.
5. What is the significance of the principle of Galilean relativity?
The principle of Galilean relativity states that the laws of physics are the same for all observers in uniform motion. This means that there is no "preferred" frame of reference, and all observers will measure the same speed of particles, regardless of their own motion.
