Speed of processors, does it have a max?
  • Thread starter Thread starter CallMeDirac
    Max Speed
The discussion centers around the misconception that computer processors are reaching the speed of light. In reality, while signals within a CPU travel at about half the speed of light, the clock speed of processors is limited by various physical constraints, including heat generation and quantum effects as transistors shrink. The miniaturization of components is approaching atomic scales, where the Heisenberg uncertainty principle poses additional challenges. Moore's Law, which historically predicted the doubling of transistors on a chip approximately every two years, is facing limitations due to increased costs and technological hurdles. Current advancements focus on increasing the number of processor cores rather than clock speed, as single-core performance has plateaued. Communication latency between different parts of a processor or system is becoming a significant issue, particularly in multi-core and chiplet designs. Overall, while processors continue to evolve, their speed is constrained by fundamental physical principles, and future improvements may rely more on architectural innovations than on simply increasing clock rates.
CallMeDirac
TL;DR
The speed of light is too slow?
I had heard that computer processors are reaching the speed of light. Is this true, and if it is how do we combat this cap?
Computer science news on Phys.org
I am not sure what you mean by 'reaching the speed of light' in processors. Where did you encounter this idea?
As stated, I don't think I could give any kind of meaningful answer.
I forgot where I heard it but basically, The internal clock of the cpu can only tick so fast. And if that speed reaches the speed of light it cannot get faster.
from some website:
So to make computers faster, their components must become smaller. At current rates of miniaturization, the behavior of computer components will hit the atomic scale in a few decades. At the atomic scale, the speed at which information can be processed is limited by Heisenberg's uncertainty principle
The signals in a computer travel at close to the speed of light, that will not change.
The size of the gates has been reducing, so the distances have been reduced, so speed has been increasing.
Building multiple parallel processors will process more data without needing to make things smaller.
Do some googling... Moore's law quickly takes you to MOSFET and under 9. Scaling (Hey ! Same picture! ) click 1616598299885.png
etc etc.
MIT has a nice article on fundamental limits -- dated 2010 :frown:
INTEL roadmap to 2029 (1.4 nm is 12 silicon atoms cross :nb) )
ITRS, IRDS, and on and on ...
Never underestimate human ingenuity and innovation. We simply make the computers do more useful things per one tick of the clock.
Ever since Moore's Law was proposed in 1965, not a month has gone by without someone predicting that it will come to an end real soon now. So far, they have all been wrong.
I don't agree.
To some extent, Moore's Law has ended. The problem with ever-decreasing transistor sizes is that the distance between these features gets smaller and quantum tunneling effects increase, not to mention that the heat generated increases. To combat the increased heat, CPU vendors have decreased the voltage, but there are limits on how low the voltage can go. Moore's Law was in effect from the late 70's/early 80's into the early 2000's, with the number of transistors on a chip and clock speeds doubling about every 18 months. At the moment, the top clock rate I'm aware of is about 5 GHz on one of the AMD Rizen models, I believe. For the past 10 - 15 years, CPU vendors have been able to make CPUs more productive, not by increasing clock speed, but by increasing the number of cores in a processor.
Likes atyy, CalcNerd, russ_watters and 2 others
I'm with @Mark44. Moore's Law is over, partly because of Moore's Second Law, which says that the cost of a CPU factory doubles every four years. Right now, only a half-dozen companies are even able to make a modern CPU. You have Intel, GlobalFoundries, TSMC, and a few others, mostly in China.
Here's Wikipedia's plot on Moore's Law:
My take on this is that the slope is below where it was in say, 1992-2004, and most of the top performing CPUs are a) heavily multicore and b) expensive. The Epyc Rome line tops out at 64 cores and $7000. The K5 was in the $100 ballpark.
Likes CalcNerd, russ_watters and jim mcnamara
Indeed, single core speed has not increased significantly in the past few years. More cores is great but not all problems can be parallelised efficiently.
I suspect the "speed of light" comment refers not to clock speed but to the latency when different part of a processor or a computer needs to communicate. This is not(?) yet so much of an issue for the internal processing inside a processor(because they are relatively small); but is an issue for bigger systems with multiple processors/sub-systems.
Communication latency is one reason why scaling up by simply adding more processors does not always work; and the speed of light does of course limit how quickly different parts of a system can communicate.
Likes atyy and russ_watters
The Intel Xeon Phi 7290 processor (now discontinued) can still be found for $8000+, and has 72 cores and a clock rate of 1.5 GHz, with a turbo rate of 1.7 GHz.
My 7-year-old HP computer, running a Quad Duo-Core (8 cores) processor at 3.4 GHz, has a clock rate that is twice as fast, but lots fewer cores.
Likes russ_watters
Mark44 said:
... decreasing transistor sizes ... the heat generated increases. To combat the increased heat, CPU vendors have decreased the voltage
The speed of a transistor is mostly due to the relative voltage versus the relative size. For typical chips as seen in home or office computers, as sizes decrease, the density increases, reducing the area available for heat dissipation. In the case of the faster Intel processors, there was a 4 GHz "barrier", dating back to 2012 or 2013 for some Core i7 processors. If not using all cores, then speeds faster than 4 GHz were possible, up to 5 GHz. Liquid cooling allows some processors to run overclocked at up to 8 GHz, but I don't know if these speeds are reliable speeds or just done to set speed records.
The liquid cooled IBM zEC12, released in 2012, could run at 5.5 GHz. According to Wikipedia, the fastest base clock rate for a processor for commercial sale.
https://en.wikipedia.org/wiki/IBM_zEC12_(microprocessor)
Already dealt with, but there's enough confusion in the statement above to warrant some more clarification. When people talk about processor speed, they're talking about the clock rate, which is how fast a particular crystal vibrates, and which has nothing to do with the speed of light. The electrons traveling inside a CPU move at about 1/2 the speed of light ( Computers are becoming faster and faster, but their speed is still limited by the physical restrictions of an electron moving through matter. What technologies are emerging to break through this speed barrier? - Scientific American )
Again, you are confusing the clock speed with how fast electrons can move through the processor circuitry.
Mark44 said:
The electrons traveling inside a CPU move at about 1/2 the speed of light...
And you are now confusing the speed an EM wave propagates through a dielectric, with the diffusion of electrons through a conductor.
The signals traveling inside a CPU move at about 1/2 the speed of light...
Likes atyy and BvU
Yes, that's what I meant -- signals, not electrons. I appreciate the correction.
Likes atyy and Baluncore
f95toli said:
...latency ... is not(?) yet so much of an issue for the internal processing inside a processor(because they are relatively small)
As far as I know regarding the cores it's not an issue, but for the internal buses (connecting the cores and other parts together) and such, it already is.
Especially for the newly emerged 'chiplet' designs.
Not so sure about that. At 4 GHz, your maximum one-clock distance is about 40 mm. That's a really, really big chip. The EPYC we were discussing earlier has an edge of 11 mm. How exactly does this work?
I think you need to consider the harmonics of signal edges too.
No, the transmission line will propagate a step and will be impedance matched to prevent ringing.
The 40 mm is the distance between successive edges traveling along the line.
There is no reason why you cannot have many bits on the line at one time, so long as you can receive the data asynchronously.
Baluncore said:
the transmission line...
But it's not simply about transmission, but about having an area where the state changes are in sync (sync enough to have consistent data out of a bus).
If you transmit the data bits and a register load clock signal, along parallel paths, then the clock will be delayed by the same propagation time as the data. The transfer will be synchronous within itself, but asynchronous with respect to some defined master clock.
All things are relatively local in a systolic processor or messaging system.
That's exactly the problem we are discussing. Delay induced asynchronicity between parts of a CPU.
Why do the CPU modules need to be globally synchronous?
It's rather 'they cannot be' instead of 'not need to be'.
Rive said:
latency ... regarding the cores it's not an issue, but for the internal buses (connecting the cores and other parts together) and such, it already is.
That's all.
That assumes that clock and date lines have the same length. This is even important on a PCB layout - one of my last designs incorporated a DRAM and the guy doing the layout had to measure all lines between the DRAM and the processor and adjust them to be within 1mm of each other. That was in 2005!
Likes berkeman
We need a delay. Can you just run a wire around the inside of the case?
If I haven't errored the order of magnitude, it looks like light travels 30 cm in one nanosecond, which should be equivalent to the clock rate of a 1 GHz CPU. For a 5 GHz CPU that would be 6 centimeters. Knowing the size of a motherboard this makes it all too clear how valuable it is to have cache memory located physically on the processor die.
Or that the clock path be very slightly longer in propagation time than any of the data lines.
When a parallel bus was run on a mainframe backpanel, several identical twisted pairs with the same length were used to route the differential signals. Once terminated with wire wrap, the excess length was folded into the gaps between the connector blocks. To modify the back plane required access, carefully unfolding and lifting out the delay lines.
Good old tech.
Actually, for this the distance induced delay is not the main player. The structures on the CPU are really small: you can drive them with small effort - you can drive them really fast. But once you are 'outside', you have more capacitance to fill up and more inductivity to stand in the way: the requirements are stricter and so the speed becomes limited.
In vacuum, that is correct. On a PCB the speed is closer to 20cm/ns.
If you have a relatively new PC motherboard, try to get a glimpse of the traces from the CPU / North bridge to the DRAM. You will see that some of the traces are wiggly - that is due to the fact that they would otherwise be too short relative to the longest traces.
Interesting. Can you recommend me material to read on this?
  • · Replies 30 ·
  • · Replies 38 ·
  • · Replies 21 ·
  • · Replies 16 ·
