Speed of rocket as viewed from Earth
In summary: I'll leave that for you to do if you want to.In summary, a rocket starting at rest on Earth and accelerating at a rate of 9.8 m/s^2 in the z direction, can be described by the equations z(\tau) = \frac{cosh(g\tau) - 1}{g} and t = \frac{sinh(g\tau)}{g}, where \tau is the rocket's proper time. In the Earth's frame of reference, after 40 years (1.26 x 10^9 seconds), the rocket will be approximately 3.69 x 10^17 meters away from Earth and traveling at a speed of 0.9997 times the speed of
Rococo
67
A rocket starts at rest from the Earth, moving in the z direction so that in its own instantaneous rest frame the acceleration is always g = 9.8 m/s^2. To an observer on Earth, its position is given by
## z(\tau) = \frac{cosh(g\tau) - 1}{g} ##
## t = \frac{sinh(g\tau)}{g} ##
where ##\tau## is the rocket's proper time. Measured in a reference frame at rest on the Earth, how far from the Earth will the rocket be in 40 years? How fast will it be going?
Four-velocity:
## U^\mu = (\gamma, \frac{d\underline{x}}{d \tau}) = (\gamma, 0, 0, sinh(g\tau)) ##
t = 40 years = ##1.26\times10^9 s##
g = ##9.8m/s^2##
##g\tau = sinh^{-1}(gt) = sinh^{-1}((9.8)(1.26\times10^9)) = 23.93##
##z = \frac{cosh(g\tau)-1}{g} = \frac{cosh(23.93)-1}{9.8} = 1.26\times10^9 m##
## U^z = sinh(g\tau) = sinh(23.93) = 1.24\times10^{10} m/s##
But this is greater than the speed of light so it can't be right.
Your formulas for ##z## and ##t## must be assuming units where ##c = 1##. It would be a good idea to insert factors of ##c## so that you can work with meters and seconds.
The z component of the 4-velocity is ##dz/d\tau##. But this is not the velocity you want. In the Earth frame, a time increment would be ##dt##, not ##d \tau##.
There seems to be an error in your calculation of ##\tau##. You have ##\tau## = 2.4 seconds (23.93/g). But for the first several months ##t \approx \tau## because the rocket speed << c.
AM
Yes, I forgot to say the question mentions that the equations ## z(\tau) = \frac{cosh(g\tau) - 1}{g} ## and ## t = \frac{sinh(g\tau)}{g} ## are in units where ##c=1##. So reinserting factors of ##c##, would these equations become:
##gt/c = sinh(g\tau /c)##
##z(\tau) = \frac{cosh(g\tau /c) - 1}{g/c^2} ##?
Then for ##t=40 years=1.26 \times 10^9 s##, we have
##g\tau /c = sinh^{-1}(gt/c) = sinh^{-1}[\frac{(9.8)(1.26 \times 10^9)}{3 \times 10^8}]= 4.41##
Giving a distance measured in the Earth frame:
## z= \frac{cosh(g\tau /c) - 1}{g/c^2} = \frac{(3 \times 10^8)^2}{9.8}[cosh(4.41) -1] = 3.69 \times 10^{17} m##.
The speed in the Earth frame would then be:
##U^z = \frac{dz}{d\tau}\frac{d\tau}{dt}
= c sinh(g\tau /c) \frac{1}{cosh(gt/c)}
= c tanh(gt/c)
= c tanh(4.41)
=0.9997c##
Is this the right way to do it?
That looks correct to me.
It might be nice to express the distance in light-years.
Likes Rococo
Related to Speed of rocket as viewed from Earth
1. What is the speed of a rocket as viewed from Earth?
The speed of a rocket as viewed from Earth can vary depending on various factors such as the type of rocket, its propulsion system, and its distance from Earth. Generally, rockets can reach speeds of up to 17,500 miles per hour in low Earth orbit.
2. Does the speed of a rocket change as it travels further away from Earth?
Yes, the speed of a rocket does change as it travels further away from Earth. This is due to the decrease in Earth's gravitational pull and the rocket's propulsion system, which allows it to accelerate as it moves away from Earth.
3. How is the speed of a rocket as viewed from Earth calculated?
The speed of a rocket as viewed from Earth is calculated using the distance traveled by the rocket and the time it takes to travel that distance. This is known as the average speed or velocity of the rocket.
4. Can the speed of a rocket be faster or slower than the speed of light as viewed from Earth?
No, the speed of a rocket cannot be faster than the speed of light as viewed from Earth. According to the laws of physics, nothing can travel faster than the speed of light, which is approximately 186,282 miles per second.
5. How does the speed of a rocket as viewed from Earth affect its journey?
The speed of a rocket as viewed from Earth plays a crucial role in determining its journey. A faster speed allows the rocket to reach its destination quicker, while a slower speed may result in a longer journey time. Additionally, the speed of a rocket also affects its trajectory and the amount of fuel needed for the journey.
