MattRob
- 211
- 29
Hey,
I've built a Cold Gas Rocket using a Co2 tank that stores liquid C02 at room temperature around 850 psi. (A Cold Gas Rocket is a rocket that uses a pressurized tank to propel the reaction mass instead of combustion, essentially just open a scuba tank and that's a very dangerous (not the one I built) cold gas rocket.)
I suspect the exhaust velocity of the rocket is the speed of sound in the tank (850 +/- 200 psi) minus the speed of sound in the air (14.7 psi).
C02 is at room temperature, tank is half full of liquid, other half is high-pressure C02 at just below liquid pressure (still around ~850 psi).
So,
1) Is the exhaust/exit velocity the speed of sound in the higher pressure area minus the speed of sound in the lower pressure area?
2) What is the speed of sound in the C02 tank?
Information:
Tank Pressure: (800 psi +/- 200 for range of temperatures)
Tank temperature: ~72*F, Room temperature.
Tank state: half liquid, half gas. I'm more concerned with the liquid, calculate for liquid, please. (Since the liquid is forced to the exit when the valve is opened, it's the one that counts.)
Tank density: ? Liquid C02 at room temperature and 850 psi.
Thanks in advance.
So,
Information:
Thanks in advance.
