Speed of Sound Waves: Echoes in a Canyon
In summary, the cowboy hears three echoes that travel in a straight line from the cliffs to where he is standing. The first echo arrives 1.92s after the first and 1.47s before the third. The total distance traveled by all three echoes is 3.47s.
mickellowery
69
A cowboy stands on horizontal ground between two parallel vertical cliffs. He is not midway between the cliffs. He fires a shot and hears it echoes. The second echo arrives 1.92s after the first and 1.47s before the third. Consider only the sound traveling parallel to the ground and reflecting from the cliffs. Take the speed of sound as 340 m/s. What is the distance between the cliffs? If he could hear a fourth echo, how long after the third echo does it arrive?
I was thinking that I could just try multiplying 340m/s by 1.92s, but this isn't correct. I thought it has something to do with the fact that he isn't standing in the center of the two cliffs. Since this didn't work I am now stumped how to get started.
Attack it step by step. Name all the variables: Distance to closer cliff = d1; further cliff = d2. Write expressions for the time it takes to hear all three echoes. Then apply the given info.
OK I have been trying to come up with an expression for time, but I'm having trouble. Would it just be: t1= [tex]\frac{340}{d1}[/tex] t2= [tex]\frac{340}{d2}[/tex]?
What's the total distance the sound has to travel?
(FYI: Don't use 'sub' tags within Latex. Use d_1 and d_2 instead.)
OK so it's d1+d2= (340)t1+(340)t2?
No. Just consider the first echo, which bounces off the near cliff. What total distance does that sound travel? Use that distance to calculate the time for that echo's arrival.
Then do the same for the second and third echoes.
I think what I'm having trouble seeing is whether or not all of these echoes are bouncing off of the closer wall. I see that it should be 2d_1= 340t_1 but then would it be 2d_1= 340t_2?
They don't all bounce off the closer wall. The first one does, but the second one bounces off the far wall.
Right.
No, the second echo has nothing to do with the near wall.
Draw a diagram and trace the path of each echo.
(What about that third echo?)
OK so the first echo which has no time attached to it will be off the close wall and the second echo which is 1.92s is off the far wall. The third echo which is 1.47s should be off the close wall again.
Correct for the first two echoes. Note that those times are really differences in times, not what we're calling t1, t2, t3.
What's the complete path of that third echo? How far does that sound travel?
Alright I think I've got it Doc. Would the second one be 2d2= 340(1.92+t1 ? I'm still thinking about the third one a little, but would it have bounced off both walls?
Sounds good to me.
Exactly.
Tip: Don't think you have to combine these times in your head. I would first write expressions for all three times, and then worry about the time differences. For example:
t1 = 2d1/v
t2 = 2d2/v
Then you can add that t2 - t1 = 1.92, and so on.
Excellent! Thanks so much for all your help again Doc. You're my hero!
Related to Speed of Sound Waves: Echoes in a Canyon
1. What is the speed of sound waves in a canyon?
The speed of sound waves in a canyon can vary depending on the temperature, humidity, and other environmental factors. On average, sound waves travel at a speed of approximately 343 meters per second in air, but in a canyon, they can reach speeds of up to 500 meters per second.
2. Why do sounds echo in a canyon?
Sounds echo in a canyon because of the way the sound waves bounce off the walls of the canyon. When a sound wave hits a surface, it can reflect and bounce back, creating an echo. In a canyon, the sound waves bounce off multiple surfaces, creating multiple echoes.
3. How does the shape of a canyon affect the speed of sound waves?
The shape of a canyon can affect the speed of sound waves in two ways. Firstly, the narrow walls of a canyon can create a funnel-like effect, causing sound waves to travel faster. Secondly, the rough and uneven surfaces of a canyon can cause sound waves to reflect and scatter, which can also affect their speed.
4. Can the speed of sound waves in a canyon change?
Yes, the speed of sound waves in a canyon can change due to various factors such as temperature, humidity, and wind. These environmental factors can affect the density and pressure of the air, which in turn affects the speed of sound waves.
5. How does the speed of sound waves in a canyon compare to the speed of light?
The speed of sound waves in a canyon is much slower than the speed of light. Sound waves can travel at a maximum speed of 500 meters per second in a canyon, while light travels at a speed of approximately 299,792,458 meters per second. This is because sound waves require a medium to travel through, while light can travel through a vacuum.
