Speed of stationary wave in a string
In summary, a stationary or standing wave is the result of two traveling waves with equal frequency and speed moving in opposite directions. The speed of the stationary wave is not actually zero, but can be broken down into two traveling waves. This concept can be better understood through the principle of superposition. In some cases, such as in the vibrations of a circular ring, analyzing the motion in terms of traveling waves can provide more insight. The terms "stationary" and "standing" wave are used interchangeably, with "standing wave" being the more commonly used term in the US.
arvindsharma
Dear all,
In my textbook it is written that when a string clamped at both ends oscillates in it's fundamental mode then the frequency of the stationary wave set up in the string is given by f=v/2l .where 'f' means frequency,'v' means speed of wave and 'l' is the length of string.following are my doubts
1.since wave is stationary not traveling so its speed should be zero always?if it is not then what is the meaning of speed in a stationary wave and what is its formula?
2.they used the formula v=square root of T/m.where 'T' is the tension in string and 'm' is the mass per unit length of the string.but as far as i know this formula is derived for a traveling wave not for stationary wave then why did they use it.please explain
Thanks
Arvind
Think of a stationary wave as the sum of two traveling waves. If the two waves move in opposite directions and have the same frequency, the result is a stationary wave. The traveling waves have a well defined speed (or phase velocity).
You're allowed to do this because of the principle of superposition.
I am still not clear that why the speed of stationary wave is not zero.what i think that since energy is not traveling in stationary waves so its speed must be zero.
Nobody's saying it isn't zero. But it can be broken down into two waves with equal speeds traveling in opposite directions, and those speeds can be used in the mathematical formula to get the correct result.
The pattern from two waves is what's stationary and not the waves themselves. It's just a name!
There are two ways to look at this. One is to "do the math" and not bother too much what it means. The other is to "do the physics" and see what it means in reality.
The math is straightforward. Start from the trig identities
##\sin(a-b) = \sin a\cos b - \cos a\sin b##
##\cos(a+b) = \sin a\cos b + \cos a\sin b##
Adding them gives
##\sin(a-b) + \sin(a+b) = 2\sin a\cos b##
Now put ##a = x## and ##b = vt##, and we have
##\sin(x-vt) + \sin(x+vt) = 2\sin x\cos vt##
##\sin(x-vt)## and ##\sin(x+vt)## are traveling waves going in opposite directions with speed ##v##.
##2\sin x\cos vt## is a stationary wave, like the vibration in a string of length ##\pi##.
I don't think the physics gives much insight into what happens to the steady vibrations of a string, because "in real life" the traveling waves are reflected from the ends of the string. You might just as well set up the equations of motion and solve them. To satisfy the boundary conditions, this is an eigenvalue problem and the eigenvalues give you the vibration frequencies of the different modes, with 0, 1, 2, ... nodal positions along the length of the string.
On the other hand there are situations where the traveling waves DO give a lot of insight. For example, think about vibrations of a circular ring of material. There are no "end points," so traveling waves can go around the ring "for ever" in either direction. This gets to be even more fun when the ring is rotating. Whether you think something is a stationary or a traveling wave depends whether you are looking at the rotating disk from a "fixed" point not on the disk, or whether you are on the disk rotating with it...
... and depending on where you are looking from, the two "forwards" and "backwards" traveling waves may appear to have different speeds, and/or different frequencies ...
... and you can get patterns of motion that look similar to the vibration of a non-rotating ring, but the pattern "rotates" around the ring at a different angular speed from the ring's rotation.
Now apply some forces, from ANOTHER object, that is rotating at a yet another different speed ...
... and keeping track of all this in terms of "traveling waves" becomes extremely useful. But you probably won't cover it in the course you are taking right now.
(I didn't just make that up. It's what happens to a vibrating compressor or turbine disk, in a steam turbine or a jet engine).
It's just a name!
Maybe a better name, at least for the string, is "standing wave" not "stationary wave".
Likes 1 person
"Standing wave" is in fact the customary term in the US, at least in all the textbooks that I've used.
Standing wave was used in the UK too, then someone thought they could add 'clarity' to the situation- haha - and started using the term 'stationary'.
Ask any Radio Engineer what SWR means.
Imagine the first oscillation. The wave immediately starts traveling towards the end of the string, and no mistake, the speed is exactly what the formula gives you. When it comes to the end, it bounces back with the same speed. So basically standing wave which doesn't move is like illusion created by two waves moving in opposite direction
Likes 1 person
Related to Speed of stationary wave in a string
What is a stationary wave?
A stationary wave, also known as a standing wave, is a type of wave that appears to be standing still, despite the fact that it is made up of two waves traveling in opposite directions. This occurs when a wave reflects off of a fixed endpoint, creating interference.
How is the speed of a stationary wave in a string determined?
The speed of a stationary wave in a string is determined by the tension of the string and the mass per unit length of the string. This relationship is described by the equation: v = √(T/μ) where v is the speed, T is the tension, and μ is the mass per unit length.
What factors affect the speed of a stationary wave in a string?
The speed of a stationary wave in a string is affected by the tension of the string, the mass per unit length of the string, and the length of the string. Additionally, the speed may also be affected by the properties of the medium through which the wave is traveling, such as temperature or density.
What is the relationship between the wavelength and frequency of a stationary wave in a string?
The wavelength and frequency of a stationary wave in a string are inversely proportional. This means that as the frequency increases, the wavelength decreases, and vice versa. This relationship is described by the equation: λ = 2L/n where λ is the wavelength, L is the length of the string, and n is the number of nodes (points of zero displacement) in the wave.
How is the speed of a stationary wave in a string related to the energy of the wave?
The speed of a stationary wave in a string is directly proportional to the energy of the wave. This means that as the speed increases, so does the energy. This relationship is described by the equation: E = 1/2μv² where E is the energy, μ is the mass per unit length, and v is the speed.
  • Mechanics
