Speed of Water Coming out of Vertical Cylinder
In summary, the problem involves a vertical cylinder with a diameter of 9 cm and an outlet on its side with a diameter of 3 cm. Water is filled to a height of 50 cm and the outlet is 5 cm above the bottom of the cylinder. The task is to calculate the force required to prevent the cylinder from moving when the valve is opened. The solution involves using Toricelli's Law to determine the mass flow rate and momentum of the water coming out of the valve, and therefore the force needed to keep the cylinder still.
slasakai
A vertical cylinder with diameter 9 cm has an outlet on its side with diameter 3cm, water is filled to height 50cm and the outlet is 5 cm above the bottom of the cylinder. the outlet is closed by a valve, calculate the force required to stop the cylinder from moving when the valve is opened.
A1V1=A2V2
Bernoulli's Equation [too long to type!]
I'm struggling as no pressures are provided, and applying Bernoulli's equation isn't straightforward. I'm not sure whether it's possible to interpret it as the fact that the top of the cylinder is open, as this would make the problem simpler. I would really appreciate some insight to this question :)
thanks in advance
How do you find pressure of a liquid at a given depth? (or rather, when the surface of the water is a certain height above where you're desired measurement point)
Likes 1 person
You have water in the cylinder. You are given the height of the water above the bottom of the cylinder and the height of the outlet above the bottom as well. Water is affected by gravity. You can determine the pressure of the water by a few simple calculations. Do you know what the term 'head' means in fluid statics?
Rather than using Bernoulli's equation, how about Toricelli's Law:
http://en.wikipedia.org/wiki/Torricelli's_law
not sure how, as the pressure at the top of the cylinder is not given and the you can't use the equation P=P0+ρgh as the liquid is flowing
To get this cart moving, assume that the top of the cylinder is vented to atmosphere.
ok, so using Toricelli's Law you can get mass flow rate, and therefore the momentum of the water coming out of the valve, and therefore the force needed to keep it still. Thank you for your help!
Related to Speed of Water Coming out of Vertical Cylinder
1. What factors affect the speed of water coming out of a vertical cylinder?
The speed of water coming out of a vertical cylinder can be affected by several factors, such as the height of the water column, the diameter of the cylinder, the pressure at the top of the water column, and the viscosity of the water.
2. How does the height of the water column affect the speed of water coming out of a vertical cylinder?
The height of the water column has a direct relationship with the speed of water coming out of a vertical cylinder. The higher the water column, the greater the pressure at the bottom, resulting in a higher velocity of water coming out.
3. Does the diameter of the cylinder affect the speed of water coming out?
Yes, the diameter of the cylinder also plays a role in the speed of water coming out. A larger diameter cylinder will have a larger cross-sectional area, resulting in a greater volume of water being released, therefore increasing the speed of water coming out.
4. How does the pressure at the top of the water column impact the speed of water coming out of a vertical cylinder?
The pressure at the top of the water column has an inverse relationship with the speed of water coming out. The higher the pressure at the top, the slower the water will come out of the bottom due to increased resistance.
5. Does the viscosity of water affect the speed of water coming out of a vertical cylinder?
Yes, the viscosity of water can impact the speed of water coming out of a vertical cylinder. Higher viscosity water will experience more resistance, resulting in a slower speed of water coming out. This can be seen in thicker liquids like honey compared to water.
