Speed Profile - Numerical Integration
In summary, the problem involves finding the total distance traveled for an object using a speed profile that is the absolute value of the velocity before integrating. The function to be numerically integrated using the Trapezium Rule is given, along with the necessary values of h, N, and total area. The goal is to calculate the total area under the curve for a data set by starting with an h value of 0.1 and decreasing it until the last two calculations are within 0.0005 of each other or h becomes 0.00001. The velocity and speed profiles are defined by three coefficients and the interesting thing about the velocity profile is that it is undefined at x = 0. The necessary equations and attempt at a solution
Hurly
I need to find total distance traveled for an object using the speed profile
which is the absolute value of velocity before integrating. so we finish up with the total distance travelled, rather than the final displacement from the initial position.
And this is the function i need to numerically integrate using the The Trapezium Rule.
Needed Values:
The h Value-
The N Value-
The Total Area-
I Have Data Sets Which is Shown In The Picture Below
http://imageshack.us/f/69/numericalintegration.png/
NOTE:
Calculate the total area under the curve for a data set, starting with an h value of 0.1 and then continuing with h = 0.01, 0.001, etc. until the latest two calculations are within 0.0005of each other, or h becomes 0.00001.
Could Someone Use One of The Data Sets to Show Hows it Done Then i'll Do The Rest of Them
Velocity Profile V(x) = x2+ b. x1+c x0+ d.x-1
defined by the 3 coefficients for the powers of x1, x0, and x-1:
Remember that
x1 = x
x0 = 1
x-1 = [itex]\frac{1}{x}[/itex]
So, the most interesting thing about this velocity profile is that it is undefined when x equals 0.
Speed Profile Sp(x) = |x2+ b. x1+c x0+ d.x-1|
Areai = h [itex]\frac{F(xi)+F(xi+1)}{2}[/itex]
with Xi+1 = x1+h
N = [itex]\frac{(xfinal-xinitial)}{h}[/itex]
Total Area = Sum of the Areai values from 0 to N-1
|x2+ 1. x1+4 x0+ -6.x-1|
Please Help =(
Can Anyone Help me or Point me in the right direction>?
Related to Speed Profile - Numerical Integration
1. What is Speed Profile?
Speed profile is a graph that displays the changes in speed over time for a moving object.
2. How is Speed Profile calculated?
Speed profile can be calculated using numerical integration, which involves dividing the distance traveled into small segments and finding the average speed in each segment. The sum of the average speeds in each segment gives the overall speed profile.
3. Why is numerical integration used for calculating Speed Profile?
Numerical integration is used because it can handle complex and irregular data, as well as provide accurate results. It is also a versatile method that can be applied to a wide range of situations.
4. What are the advantages of using Speed Profile in scientific research?
Speed profile can provide valuable insights into the behavior and performance of moving objects, such as vehicles or particles. It can also help identify patterns and trends in the data, which can be useful for making predictions and improving designs.
5. How can Speed Profile be used in real-world applications?
Speed profile can be used in a variety of fields, such as transportation engineering, sports science, and aerospace engineering. It can help optimize vehicle performance, improve athletic training programs, and analyze the flight paths of aircraft and spacecraft.
