Speed Question: Two bodies are hit/ final momentums?
In summary: I really appreciate it!In summary, when an external force is applied to body 1, causing it to accelerate and then stop, and then the same force is applied to body 2 causing it to accelerate for the same amount of time, the final kinetic energy of body 1 will be less than the final kinetic energy of body 2, and the final momentum of body 1 will be greater than the final momentum of body 2. This is due to the fact that the mass of body 1 is greater than the mass of body 2 and the velocity of body 1 is less than the velocity of body 2.
Const@ntine
285
Two bodies are standing still upon a surface without friction. The mass of body 1 is bigger than the mass of body 2.
i) A constant force is applied to body 1, so it accelerates in a segment to a distance d. The force stops being applied to body 1, and is applied to body 2. When body 2 has done the distance d, which of the following are valid?
ii) When a force is applied to body 1, it accelerates for a time Δt. The force stops being applied to body 1, and is then applied to body 2. Which are valid if body 2 accelerates for Δt?
a) p1 < p2
b) p1 = p2
c) p1 > p2
d) K1 < K2
e) K1 = K2
f) K1 > K2
I = ΣFΔt
Δpf = Δpi
I think I'm done with (ii), but here's a look:
ii) I = FΔt => I1 = I2 => Δp1 = Δp2 => pf1 - pi1 = pf2 -pi2 => pf1 = pf2 (1)
m1 > m2 (2)
(1) & (2): V1 < V2 (3)
K = 1/2*m*V2 (4)
(2) & (3) & (4): K1 < K2
The book has b & d as the answers for (ii), and c & e as the answers for (i).
Now, it's one (i) I have a problem with. I just don't know how to tackle it. ΔP = 0 is for whole isolated systems, and for a very small time-frame. Here, from what I gather, I hit 1, it accelerates, it reaches d, and then the force stops being applied to it (so technically it keeps going on and on since there's no friction). After that, I do the same to 2.
I'm probably missing something (I just got into the chapter, I'm five pages in so I haven't really gotten the hang of it yet), so I'd be grateful for any help!
If there is an applied force - the system is not isolated.
There is a relationship between force and change in momentum you learned a while ago... you need to relate that to the distance d.
Shortcut: you can relate work to momentum via change in kinetic energy.
Yeah, since the F is external, the system is not isolated, but so far, the only thing the book has talked about are forces that one body exerts to the other, and so it desribes the system as isolated to the momentum. In my case, it's different. The only formula I've got at my disposal atm is ΣF = dp/dt. That, plus the usual ΣF = ma and whatnot.
So far, the only exercise I've seen dealt with internal forces, and the usual pf = pi. So I don't really know how to tackle and continue this one.
All I can do is say again what Simon said. With an external force momentum is not conserved: pf does not equal pi. I feel very confident if you look back in your notes or book that they have told you what force x distance is.
Yeah, I got that, I'm just saying what I've gone through with the book thus far. If you're referring to work, then I guess you're talking about this:
W = Fdcos0 = Fd = ΔK1 = ΔK2 <=> Kf1 -Ki1 = Kf2 -Ki1 <=> Kf1 = Kf2 [So that's one question down]
1/2m1Vf12 = 1/m2Vf22 <=> m1Vf12 = m2Vf22 (1)
m1 > m2
so, Vf12 < Vf22 <=> |Vf1| < |Vf2|
(1) p1*Vf1 = p2*Vf2
Vf1 < Vf2 (I guess they're both going towards the same direction, otherwise it'd needlessly complicate things)
so, p1 > p2 [and that's the second one down]
Is that what you mean? I did think about that in the beginning, but I had just gone into the momentum chapter, so I figured it'd be something more to do with that info.
PS: Is my solution for (ii) correct? It's at my first post (attempt at solution).
Yes, that looks good.
Your final step does not quite work, in that it does not follow from the three equations you cite.
You do have the equation you need to use instead.
Is there an equation for that part? It's 00:00 here so I'm probably blanking out, but isn't it more of a "logic problem" at the final step?
m1 > m2
V1 < V2
K = 1/2*m*V2
p1 = p2
So, K1 = 1/2m1V12 = 1/2p1V1
K2 = 1/2m2V22 = 1/2p2V2
And so, since p1 = p2, the only deciding factors are the velocities, and with V1 < V2, K1 < K2
m1 > m2
V1 < V2
K = 1/2*m*V2
p1 = p2
Yes, that's fine. Originally you cited eqns 2, 3 and 4, which omitted the crucial p1=p2.
Oh yeah, my bad. Thanks for the confirmation, and thanks for the help everyone!
No worries ... yes I was thinking like this:
Kinetic energy is ##p^2/2m##, since this is produced by a force acting over a distance you can write ##p^2 = 2mFd##.
When the constant force acts over the same time, can just use: ##p = F\Delta t## from F=dp/dt.
(using ##p_i = 0## and ##p_f=p##.)
You can also do it using the suvat equations, if you've met them.
ie. ##v^2=u^2+2ad## ... if ##p=mv## and ##q=mu##, then ##p^2 = q^2 + 2Fd##
In terms of energy and work, that is ##K = K_0 + W## (check)
That old F=ma and F=dp/dt (if F is constant then ##F = \Delta p / \Delta t## ), those things, are your goto equations for motion. Don't be so quick to dismiss.
Notice that the last one with the ##\Delta##'s in it turns into the law of conservation of momentum when F=0?
No, I haven't come across those equations just yet. But yeah, you're right, my mind should've gone there immediately.
Thanks for the info!
Likes Simon Bridge
FAQ: Speed Question: Two bodies are hit/ final momentums?
1. What is momentum?
Momentum is a measure of an object's mass and velocity. It is a vector quantity, meaning it has both magnitude and direction. In simpler terms, it is the amount of motion an object has.
2. How is momentum calculated?
Momentum is calculated by multiplying an object's mass by its velocity. The formula for momentum is p = m x v, where p is momentum, m is mass, and v is velocity.
3. What happens to momentum when two bodies collide?
When two bodies collide, the total momentum of the system remains constant. This means that the sum of the individual momentums of the bodies before the collision is equal to the sum of their momentums after the collision.
4. How does the mass and velocity of each body affect the final momentum?
The final momentum of a system is affected by the mass and velocity of each body involved in the collision. The greater the mass and velocity of a body, the greater its momentum will be. This can also affect the direction of the final momentum.
5. How can momentum be conserved in a collision?
Momentum can be conserved in a collision by ensuring that the total momentum before the collision is equal to the total momentum after the collision. This can be achieved by taking into account the mass and velocity of each body and the direction of their momentums.
