Speed reaction and catalys reaction
In summary, speed reaction and catalyzed reaction are different in that speed reaction is the rate at which a chemical reaction occurs, while catalyzed reaction involves the use of a catalyst to increase the speed of the reaction. Temperature affects the speed of a reaction by providing more energy to reactant molecules, causing them to move faster and collide more frequently. Examples of catalysts in everyday life include enzymes in our bodies, platinum in catalytic converters, and yeast in bread making. A catalyst does not affect the equilibrium of a reaction, but only speeds up the rate at which it reaches equilibrium. The speed of a reaction can be determined by measuring the change in concentration of reactants or products over time, such as changes in color, pH,
taregg
70
what is difference between speed reaction and catalys reaction...like for example nonmetals it will speed up the reaction...and transition metals it will catalys the reaction
I mean what the difference can do nonmetals and transition metals in properties chimcal reaction
FAQ: Speed reaction and catalys reaction
What is the difference between speed reaction and catalyzed reaction?
Speed reaction refers to the rate at which a chemical reaction occurs, while catalyzed reaction involves the use of a catalyst to increase the speed of a reaction. A catalyst is a substance that lowers the activation energy required for a reaction to take place, therefore increasing its speed.
How does temperature affect the speed of a reaction?
As temperature increases, the speed of a reaction also increases. This is because higher temperatures provide more energy to the reactant molecules, allowing them to move faster and collide more frequently, leading to a faster reaction rate.
What are some examples of catalysts in everyday life?
Some common catalysts include enzymes in our bodies that help break down food, platinum in catalytic converters of cars, and yeast in bread making. Other examples include nickel in the production of margarine and iron in the Haber process for producing ammonia.
Can a catalyst affect the equilibrium of a reaction?
No, a catalyst does not affect the equilibrium of a reaction. It only speeds up the rate at which the reaction reaches equilibrium, but does not change the position of the equilibrium itself.
How do you determine the speed of a reaction?
The speed of a reaction can be determined by measuring the change in concentration of reactants or products over time. This can be done by monitoring changes in color, pH, or gas volume. The steeper the slope of the curve, the faster the reaction rate.
