Speed Required to Pass a Truck in 3 Seconds
  • MHB
  • Thread starter bergausstein
  • Tags
    Word problem
In summary, to pass a truck traveling at 45 mph, a car 15 ft. long must travel at a speed of at least 81 ft/sec (or 55⅕ mph) relative to the truck and move a total distance of 45 ft. in 3 seconds.
bergausstein
191
please help set up the equation for this problem,
a car 15 ft.long overtakes a truck 30 ft. long which is traveling at the rate of 45mph. How fast must the car travel to pass the tuck in 3 seconds ?
Mathematics news on Phys.org
How far must the car travel relative to the truck?
the effective speed of the car is 45-x is this correct?
Shouldn't the car be moving faster than the truck?
If you consider my original question, I am trying to guide you to the answer. :D
The car must move a certain distance relative to the truck in 3 seconds. Once you know this distance, you can plug into the relation between distance constant speed and time, to get the speed of the car relative to the truck. Just be mindful of your units, and make sure they match up.
the car must travel 30 ft. relative to the truck?
The car begins the passing maneuver with its front even with the back of the truck.
If the car moves 30 ft. relative to the truck then the front of the car is located where in relation to the truck?
at the back of the truck.
No, that's where the front of the car is at the beginning of the passing maneuver. If it moves 30 ft. relative to the truck, then the front of the car is even with the front of the truck (because the truck is 30 ft. long), but we want the back of the car to be even with the front of the truck. So, how far must the car move relative to the truck to complete the passing maneuver?
the car should travel a total distance of 45 ft.
Correct! (Star)
And we know it must do so in 3 seconds. So, what speed (in mph) is required to move 45 ft. in 3 seconds? Once you find this speed, then add it to that of the truck.
I'm more comfortable using ft/sec
15ft/sec+66ft/sec = 81ft/sec --->>
but I still have question. why do we have to add it to the speed of the truck?
Because that 15 ft/sec is in addition to the speed of the truck. The car has to be moving 15 ft/sec faster than the truck to pass it in 3 seconds. :D
:)(Dance)
Hello, bergausstein!
A car 15 ft. long overtakes a truck 30 ft. long which is
traveling at the rate of 45 mph. How fast must the car
travel to pass the truck in 3 seconds?
At the start, the front of the car
is even with the back of the truck.
Code:
Start
     |   15   | →
              |      30      | →
Three seconds later, the back of the car
is even with the front of the truck.
Code:
Finish
              : - -  30  - - |   15   | →
              |      30      | →
Relative to the truck, the car has moved 45 feet.
Let [tex]x[/tex] = speed of the car (ft/sec).
The truck's speed is: .[tex]45\text{ mph} \,=\,66\text{ ft/sec}[/tex]
Relative to the truck, the car's speed is [tex](x - 66)[/tex] ft/sec.
It is as if the truck is stopped
and the car is passing at [tex](x-66)[/tex] ft/sec.
The car moved 45 feet in 3 seconds at [tex](x-66)[/tex] ft/sec.
. . [tex]3(x-66) \:=\:45 \quad\Rightarrow\quad x \:=\:81[/tex]The speed of the car is [tex]81[/tex] ft/sec
. . or: .[tex]81\cdot\tfrac{60}{88} \,=\,\tfrac{1215}{22} \,=\,55\!\tfrac{5}{22}\text{ mph.}[/tex]
FAQ: Speed Required to Pass a Truck in 3 Seconds
How do I solve distance word problems?
To solve distance word problems, you need to identify the given information such as speed, time, and distance. Then, use the formula distance = speed x time to find the missing value. Make sure to convert the units if necessary and double check your answer.
What is the formula for distance word problems?
The formula for distance word problems is distance = speed x time. It is used to calculate the distance traveled when the speed and time are known.
What are some common units for distance in word problems?
Some common units for distance in word problems include miles, kilometers, meters, and feet. Make sure to use the same units for both speed and time in the formula.
What is the difference between speed and velocity in distance word problems?
Speed and velocity are similar but have a slight difference. Speed is the rate of change of distance, while velocity is the rate of change of displacement. In other words, velocity takes into account the direction of movement, while speed does not.
Can distance word problems be solved using other formulas?
Yes, distance word problems can also be solved using the formula distance = rate x time or distance = average speed x total time. These formulas are equivalent to the distance = speed x time formula and can be used interchangeably.
