Speeeed's question at Yahoo Answers regarding special integrating factors
In summary, we are given an ODE to solve and we find that it is not exact. By finding the integrating factor, we are able to transform the equation into an exact one. Using integration by parts, we are able to solve the ODE and express the solution implicitly.
MarkFL
MHB
13,288
Here is the question:
Show that the given equation is not exact and find the right integrating factor to make this equation exact?
Show that the given equation is not exact and find the right integrating factor to make this equation exact (Hint : this integrating factor μ(y) is a function of y only).
Then solve the equation (you can leave the constant of integration for ψ under its integral form).
y+(2x−ye^y)y′ =0
Correct answer is μ = y
(y^2)x − integral of (y^2)e^y dy=c
I need a step by step answer please..
Here is a link to the question:
Show that the given equation is not exact and find the right integrating factor to make this equation exact? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Hello speeeed,
We are given to solve:
\(\displaystyle y+\left(2x-ye^y \right)y'=0\)
First, let's express the ODE in the differential form \(\displaystyle M(x,y)\,dx+N(x,y)\,dy=0\):
\(\displaystyle (y)\,dx+\left(2x-ye^y \right)\,dy=0\)
An equation is exact iff \(\displaystyle \frac{\delta M}{\delta y}=\frac{\delta N}{\delta x}\). Checking for exactness, we find:
\(\displaystyle \frac{\delta}{\delta y}(y)=1\)
\(\displaystyle \frac{\delta}{\delta x}\left(2x-ye^y \right)=2\)
Since in this case \(\displaystyle \frac{\delta M}{\delta y}\ne\frac{\delta N}{\delta x}\) we may conclude the ODE is not exact.
Next we want to consider:
\(\displaystyle \frac{\frac{\delta M}{\delta y}-\frac{\delta N}{\delta x}}{N}=-\frac{1}{2x-ye^y}\)
Since this is not a function of just $x$, we next consider:
\(\displaystyle \frac{\frac{\delta N}{\delta x}-\frac{\delta M}{\delta y}}{M}=\frac{1}{y}\)
Since this is a function of just $y$, then an integrating factor is given by:
\(\displaystyle \mu(y)=e^{\int\frac{dy}{y}}=y\)
Multiplying the ODE in differential form by this integrating factor, we get:
\(\displaystyle \left(y^2 \right)\,dx+\left(2xy-y^2e^y \right)\,dy=0\)
Now, we can verify that we have an exact equation as:
\(\displaystyle \frac{\delta}{\delta y}\left(y^2 \right)=\frac{\delta}{\delta x}\left(2xy-y^2e^y \right)=2y\)
Since the equation is exact, then there must be a function $F(x,y)$ satisfying:
\(\displaystyle \frac{\delta F}{\delta x}(x,y)=y^2\)
Integrating with respect to $x$, we find:
\(\displaystyle F(x,y)=\int y^2\,dx=xy^2+g(y)\)
To determine $g(y)$, we now take the partial derivative with respect to $y$ and substitute \(\displaystyle 2xy-y^2e^y=\frac{\delta F}{\delta y}\):
\(\displaystyle 2xy-y^2e^y=2xy+g'(y)\)
\(\displaystyle g'(y)=-y^2e^y\)
Integrating with respect to $y$, we have:
\(\displaystyle g(y)=-\int y^2e^y\,dy\)
And so we have:
\(\displaystyle F(x,y)=xy^2-\int y^2e^y\,dy\)
Since the solution is given implicitly by $F(x,y)=C$, we may give the solution as:
\(\displaystyle xy^2-\int y^2e^y\,dy=C\)
If we wish to evaluate the integral in the result, we may use integration by parts. Let:
\(\displaystyle I=\int y^2e^y\,dy\)
Using:
\(\displaystyle u=y^2\,\therefore\,du=2y\,dy\)
\(\displaystyle dv=e^y\,\therefore\,v=e^y\)
we now have:
\(\displaystyle I=y^2e^y-2\int ye^y\,dy\)
Using IBP again:
\(\displaystyle u=y\,\therefore\,du=\,dy\)
we now have:
\(\displaystyle I=y^2e^y-2\left(ye^y-\int e^y\,dy \right)=e^y\left(y^2-2y+2 \right)+C\)
Since the constant of integration here is not important, and could just be combined with the constant in the solution above, the solution to the ODE can be expressed implicitly as:
\(\displaystyle xy^2-e^y\left(y^2-2y+2 \right)=C\)
To speeeed and any other guests viewing this topic, I invite and encourage you to post other differential equations problems here in our http://www.mathhelpboards.com/f17/ forum.
Best Regards,
Mark.
FAQ: Speeeed's question at Yahoo Answers regarding special integrating factors
What is a special integrating factor?
A special integrating factor is a mathematical tool used in solving differential equations. It is a function that is multiplied to an equation in order to make it easier to solve.
How is a special integrating factor determined?
A special integrating factor can be determined by using a specific formula that depends on the type of differential equation being solved. It involves identifying certain patterns and variables in the equation and manipulating them to find the correct integrating factor.
Why is a special integrating factor important?
A special integrating factor is important because it can simplify the process of solving a differential equation. It can transform a complicated equation into a more manageable one, making it easier to find a solution.
Are there different types of special integrating factors?
Yes, there are different types of special integrating factors based on the type of differential equation being solved. Some common types include linear, Bernoulli, and exact equations.
Can a special integrating factor be used for all types of differential equations?
No, a special integrating factor may not work for all types of differential equations. Some equations may require other methods of solving, such as separation of variables or substitution.
