Sphere of constant density has zero force of attraction
In summary: In spherical coordinates, the force is always directed towards the center of the sphere. However, in cylindrical coordinates, the force is always directed away from the center of the cylinder. In summary, the force of attraction within a spherical shell of constant density is everywhere 0.
Helsinki
Hi all-
I have the following problem that I am trying to understand:1. Problem statement. Show that the force of attraction within a spherical shell of constant density is everywhere [tex]0[/tex].
My understanding of the statement is that, for example, in a gravitational field, the sphere would not 'cave in' on itself because the patches of the sphere are of constant density. I have the solution (below). The problem is presented in the context of advanced calculus (after talking about the implicit function theorem, surfaces and surface area). The integration is easy but I don't understand how the integral for the force is derived.
Solution. Describe the shell by [tex]x = \sin{\phi}\cos{\theta},y = \sin{\theta}\sin{\phi},z = \cos{\phi},0\leq \phi\leq \pi, 0\leq\theta \leq 2 \pi[/tex], and let [tex]P = (0,0,a)[/tex] with [tex]0\leq a \leq 1[/tex]. With [tex]\rho[/tex]=density (mass per unit area), the component of the force at $P$ in the vertical direction is
[tex]\[
F = - \int_0^{2\pi}d\theta\int_0^{\pi}\frac {(\cos\theta - a)(\rho\sin\theta)}{(1 + a^2 - 2a\cos{\theta})^{3/2}} d\phi.
\][/tex]
(This may be integrated easily; for example, put [tex]u^2 = 1 + a^2 - 2a\cos\theta.[/tex] One finds that [tex]F = 0.[/tex])
Also, I'm interested as to why this is an advanced calculus problem. My guess is that it mathematically interesting insofar as it can be generalized to [tex]n -[/tex] spheres and one must be careful with calculus. I would appreciate any help on this, since I have to give a presentation, and I have no idea what is going on!
Thanks in advance,Helsinki
hi Helsinki
it looks like your integral assumes a sphere of density ro, radius 1 and centred at (x,y,z) =(0,0,0).
then, without loss of generality, consider a point at (x,y,z) =(0,0,a). due to the symmetry of the sphere, this effectvely represents any point in the sphere, at distance |a| from the centre. If the offest was not aligned along the z axis, you could rotate the probalem so it is.
In spherical coordinates, this is the point
[tex] \textbf{a} = (r, \theta, \phi) = (a,0,0) [/tex]
First due to the symmetry of the problem, it is clear the horizontal field is zero, so you only need to check the vertical field as the point a = (a,0,0).
can you define the field contribution at a for an infintesimal surface area element at point on the spherical shell [tex] \textbf{r}' = (1, \theta, \phi) [/tex] ?
this should lead you to your integral
as for generalisation to higher dimensions, to be honest, i don't know whether it does or not. However for some insight you could try setting up the same integral for a ring of even mass distribution. Does it still vanish?
Hi lanedance,
Is there a general formula that is used to get [tex]F[/tex]?
start with the gravitational field g, at r from a mass dm
[tex] \textbf{dg} = -\frac{Gdm}{|r|^2}\hat{\textbf{r}} [/tex]
I have realized that the formula given for [tex] F [/tex] above in the original problem statement doesn't even make sense--[tex]F[/tex] ought to be a vector field, and F as given above is certainly not! This is a formula that's given in the back of the book, and I think it's purposefully wrong since it seems way off base.
I think the correct approach is to write the gravitational potential [tex]V[/tex] and then find the gravitational force [tex] F= \nabla V [/tex]. It can be shown (below) that [tex]V[/tex] is constant and so [tex]F=0[/tex], the zero vector. As a basic setup, we have
[tex] -V(0,0,a)=-\int\int\int_W \frac{\delta(x,y,z) dx dy dz}{\sqrt{x^2+y^2+(z-a)^2}} [/tex]
where [tex]\delta[/tex] is =1. Then with spherical coordinates this is
[tex] -V(0,0,a)=-\int\int\int_W \frac{(\rho^2\cdot \sin{\phi}) d\rho d\theta d\phi}{\sqrt{1-2a \cos{\phi}+a^2}} [/tex].
At the end we should have something like
[tex]-V=(Gm)2\pi \rho_{(0,0,a)}[/tex] and so [tex]F=\nabla{V}=0[/tex].
I would appreciate if someone could validate what I have said-naturally I must fill in some work in the integration above. I believe the text is completely wrong--on the other hand I am unwilling to reject its answer since its a textbook, and textbooks are always right (or at least, never this wrong).
Thanks in advance,
Helsinki
The given formula is just the component of the force in the z direction, which is all you need.
This problem is perhaps easier in cylindrical coords.
FAQ: Sphere of constant density has zero force of attraction
What is a sphere of constant density?
A sphere of constant density is a three-dimensional shape that has the same amount of mass distributed evenly throughout its entire volume. This means that the density of the sphere is the same at every point.
How does a sphere of constant density have zero force of attraction?
According to Newton's Law of Gravitation, the force of attraction between two objects is directly proportional to the product of their masses and inversely proportional to the square of the distance between them. Since a sphere of constant density has an even distribution of mass, the force of attraction from any point on its surface will be cancelled out by the force of attraction from the exact opposite point, resulting in a net force of zero.
Can a sphere of constant density have a non-zero force of attraction?
No, a sphere of constant density will always have a net force of zero due to the even distribution of its mass. This is a fundamental property of a sphere with a constant density.
How does the density of a sphere affect its force of attraction?
The density of a sphere does not affect its force of attraction on other objects, as long as the density remains constant. This is because the force of attraction is determined by the total mass of the sphere, not the density of the material it is made of.
Is the force of attraction always zero inside a sphere of constant density?
No, the force of attraction inside a sphere of constant density will vary depending on the distance from the center of the sphere. As you move closer to the center, the force of attraction will increase due to the increased mass of the sphere that is closer to that point. However, the net force of attraction on an object placed inside the sphere will still be zero because the forces from all directions will still cancel out.
