Spherical balloon related rates problem
In summary: V).In summary, when blowing a balloon, the rate of increase is linear and so the rate of increase is equal to the rate of decrease.
s3a
818
You are blowing air into a balloon at a rate of 4*pi/3 cubic inches per second. (The reason for this strange-looking rate is that it will simplify your algebra a little bit.)
Assume the radius of your balloon is zero at time zero.
Let r(t), A(t) and V(t) denote the radius, surface area and the volume of your balloon at time t, respectively. (Assume the thickness of the skin is zero.)
Find:
a) r'(t)
b) A'(t)
c) V'(t)
Differentiation.
Chain rule.
Related rates.
I know that dV/dt = 4*pi/3 and that dV/dt = 4*pi * r^2 dr/dt, and that 4*pi/3 = 4*pi r^2 * dr/dt, which implies that 1/3 = r^2 * dr/dt.
I also found that dA/dt = 8*pi*r * dr/dt.
My issue is that I now have two equations, 1/3 = r^2 * dr/dt and dA/dt = 8*pi*r * dr/dt, but three unknowns, dr/dt, dA/dt and r.
I'm assuming that I need to find a third relationship/equation, but I cannot figure out what it is.
As always, any help would be very much appreciated!
You've derived ##\frac{1}{3}=r^2\frac{dr}{dt}##, so you can express ##\frac{dt}{dr}## as a function of ##r##. Then you can integrate that with respect to ##r## to get ##t## as a function of ##r##. INvert that to get ##r## as a function of ##t## and the rest is just differentiation.
Thanks for the response, andrewkirk, but I'm still stuck after having read what you wrote.
Here is what I understood:
dt/dr = 3r^2
d/dr (dt/dr) = d/dr (3r^2)
d^2 t / dr^2 = 6r
d^2 r / dt^2 = 1/(6r)
dt/dr = 3r^2
d^2 t / dr^2 = 6r
You don't want to differentiate ##\frac{dt}{dr}=3r^2##, you want to write it as ##3r^2dr = 1dt## and integrate both sides to get ##r## as a function of ##t##. Don't forget you are given ##r=0## when ##t=0##.
Thanks for the response LCKurtz, but this is for a calculus course that has yet to cover integrals.
If you can't integrate then you can't expect to get ##r## in terms of ##t##. But you do have ##\frac{dr}{dt}=\frac{1}{3r^2}##. You can plug that into get ##\frac{dA}{dt}## as a function of ##r## just like your ##\frac{dr}{dt}## is. I think that is all you can do in that case.
Also, possibly you are expected to write your equation as ##3r^2\frac{dr}{dt}= 1## and notice that looks like the chain rule from differentiating what?
Find:
a) r'(t)
b) A'(t)
c) V'(t)
Differentiation.
Chain rule.
Related rates.
You know dA/dt = 8πr dr/dt and dV/dt = 4πr2 dr/dt.
Let Q = dr/dt so that dV/dt = 4πr2 * Q = 4π/3. What is Q? What is dA/dt? Now, it's just a problem of algebra.
Thanks guys, I'm no longer confused! :)
To keep it concise and free of any material beyond the first calculus course for any potential future readers:
Because the rate of change is constant, the rate of increase is a linear rate, so we can say that dV/dt = ΔV/Δt and since, at t = 0, r = 0, it follows that at t = 0, V = 0 as well.
Therefore, ΔV = ##V_{final}## - ##V_{initial}## = ##V_{final}## - 0 = ##V##, and Δt = ##t_{final}## - ##t_{initial}## = ##t_{final}## - 0 = ##t##, from which we have the relationship V = 4*pi/3 * t which is equivalent to 4*pi/3 * r^3 = 4*pi/3 * t, and we have t = r^3 as the third equation, and then having 3 equations is enough for solving the 3 unknowns (dA/dt, r and dr/dt).
That looks OK. Do you see where ##r^3 = t## might have been deduced from ##3r^2\frac{dr}{dt} = 1##? Think of it as a "preview of coming attractions" in integral calc.
Yes, I do see how r^3 = t could have been deduced from 3 r^2 * dr/dt = 1, but I honestly prefer noticing that the constant rate of change denotes a linear relationship between change in the volume and time. Having said that, it's nice to see different approaches.
Also, I already took this course, and I was trying to help someone who is taking it now, and it bothered me that I couldn't solve it.
FAQ: Spherical balloon related rates problem
How do I determine the rate of change of a spherical balloon's volume?
To determine the rate of change of a spherical balloon's volume, you will need to use the formula V = (4/3)πr^3, where V represents the volume and r represents the radius. Then, you can use the chain rule to find the derivative of the volume with respect to time, dV/dt.
How do I find the rate at which the radius of a spherical balloon is changing?
To find the rate at which the radius of a spherical balloon is changing, you can use the formula dV/dt = (4/3)π(3r^2)(dr/dt), where dV/dt represents the rate of change of volume, r represents the radius, and dr/dt represents the rate of change of the radius. Rearrange the equation to solve for dr/dt.
What is the significance of the given rate in a spherical balloon related rates problem?
The given rate in a spherical balloon related rates problem represents the rate at which one variable is changing while another variable is held constant. This is known as the constant rate of change and is essential in solving related rates problems.
How do I set up a related rates problem involving a spherical balloon?
To set up a related rates problem involving a spherical balloon, you will need to identify the variables involved and the given rate. Then, use the appropriate formula (such as V = (4/3)πr^3) to relate the variables. Finally, use the chain rule to find the derivative of the related variables with respect to time.
Can I apply the same method to solve any spherical balloon related rates problem?
Yes, you can apply the same method to solve any spherical balloon related rates problem. The key is to identify the variables involved and the given rate, and then use the appropriate formula and the chain rule to find the derivative with respect to time. However, the specific values and units may vary in each problem, so it is important to pay attention to the given information.
