Spherical Harmonics Change of Coordinate System
In summary, for part a, you can use Maxwell's equations to solve for the electric field in the area without charges, using the equation $\nabla \times H = -\epsilon_0\frac{\partial E}{\partial t}$.For part b, you can use the addition theorem for spherical harmonics and a transformation matrix for a rotation of 45 degrees about the y axis to express the spherical harmonics in the new coordinate system. Then, substitute these expressions into the addition theorem and solve for the electric and magnetic fields in the new coordinate system.
Yoni V
44
Let $$\vec H = ih_4^{(1)}(kr)\vec X_{40}(\theta,\phi)\cos(\omega t)$$
where ##h## is Hankel function of the first kind and ##\vec X## the vector spherical harmonic.
a) Find the electric field in the area without charges;
b) Find both fields in a spherical coordinate system that is a rotation of 45 deg about the y axis.
Maxwell's equations, addition theorem for spherical harmonics.
For part a I used Maxwell's equations, namely
$$\nabla \times H = -\epsilon_0\frac{\partial E}{\partial t} $$
For part b I want to use the addition theorem, namely
$$P_l(\cos \alpha) = \frac{4\pi}{2l+1}\sum_{m=-l}^lY^{*}_{lm}(\theta ',\phi ')Y_{lm}(\theta,\phi)$$
using the specific transofrmation ##\theta = pi/4,\;\phi=0##, but I can't find a way to isolate ##Y_{lm}## in the old coordinate system and express it in the new because of the terms in the sum. Any directions? Thanks.
For part a, using Maxwell's equations is the correct approach. You can use the equation you mentioned, $$\nabla \times H = -\epsilon_0\frac{\partial E}{\partial t}$$ to solve for the electric field, since the magnetic field is already given in the form of the Hankel function and vector spherical harmonic.
For part b, you are on the right track by using the addition theorem for spherical harmonics. To express the spherical harmonics in the new coordinate system, you can use the transformation matrix for a rotation of 45 degrees about the y axis. This matrix will allow you to express the spherical harmonics in terms of the new coordinate system. Once you have done this, you can substitute the new expressions for the spherical harmonics into the addition theorem and solve for the electric and magnetic fields in the new coordinate system.
I hope this helps. Good luck with your calculations!
Related to Spherical Harmonics Change of Coordinate System
1. What are spherical harmonics and how are they used in change of coordinate systems?
Spherical harmonics are a set of mathematical functions that are used to describe the angular variation of wave-like phenomena in three-dimensional space. They are commonly used in change of coordinate systems to express the transformation of coordinates from one reference frame to another.
2. How do spherical harmonics change when the coordinate system is rotated?
When the coordinate system is rotated, the spherical harmonics undergo a linear transformation. This results in a change in the coefficients of the spherical harmonics, which represent the amplitude and phase of the wave-like function in the new coordinate system.
3. What is the relationship between spherical harmonics and the spherical coordinate system?
Spherical harmonics are closely related to the spherical coordinate system, as they are both based on the spherical geometry. In the spherical coordinate system, the coordinates are expressed in terms of radius, inclination angle, and azimuthal angle. Spherical harmonics, on the other hand, are used to describe the angular variation of a wave-like function in spherical coordinates.
4. Can spherical harmonics be used in any coordinate system?
Yes, spherical harmonics can be used in any coordinate system, as long as the system is based on spherical geometry. This includes both spherical and non-spherical coordinate systems, such as cylindrical and polar coordinates.
5. How are spherical harmonics used in real-world applications?
Spherical harmonics have a wide range of applications in various fields, including physics, chemistry, mathematics, and engineering. They are commonly used in signal processing, image and sound compression, global climate modeling, and quantum mechanics, to name a few. They also play a crucial role in the analysis of spherical data, such as gravitational and magnetic fields, and in the representation of 3D objects and shapes.
