davidge
- 554
- 21
I found an interesting thing when trying to derive the spherical harmonics of QM by doing what I describe below. I would like to know whether this can be considered a valid derivation or it was just a coincidence getting the correct result at the end.
Starting making a Fundamental Assumption that when dealing with the derivative operators, they will act only on their copies; e.g. ##\partial_{\theta}## acts only on ##\partial_{\theta}##.
Knowing that
I got after working out
where ##C_{lm}## are the coefficients depending only on ##l## and ##m##.
Now comes the crucial point. As by assumption each differential operator acts only on its copy, they will not act on the exponentials. Also, as there is nothing to differentiate w.r.t ##\phi##, there will be no terms left with ##\partial_\phi##. After working out the terms I got (with ##u = Cos(\theta)##)
$$ C_{lm}\ e^{im \phi} \frac{\partial^{l - m}}{\partial u^{l - m}} \sqrt{1-u^2}^l \sqrt{1-u^2}^{\ - m} $$
Now, notice at this point I have worked out all the ##(m-l)## - ##L_{-}## operators. It is as if we were left only with ordinary quantities and therefore, I allowed the "once" differential operators to act on the functions.
If we can use ordinary product rule here, then we have (because the greatest order term for the second term on the right will be of order ##|m|## and the derivatives are of order ##l-m##)
$$C_{lm}\ e^{im \phi} \frac{1}{\sqrt{1-u^2}^m} \frac{\partial^{l - m}}{\partial u^{l - m}} \sqrt{1-u^2}^l$$
as it should be.
If I'm wrong, then this was just a big coincidence!
Knowing that
as it should be.
