Spherical thermodynamical chamber
R*TIn summary, the conversation discusses a spherical chamber with a cold surface that causes gas particles to condense on it. The problem is to determine the time it takes for the gas to reach a different pressure, p2, using the ideal gas law and a differential equation. The solution involves setting up a differential equation for pressure as a function of time and solving for the constant using the ideal gas equation.
RingNebula57
56
In a spherical chamber with volume V , which contains a gas with pressure p1, there is a surface that has a much more low temperature than the other surface temperature of the sphere surface( which is kept constant). Because of that the particles that hit the coresponding surface S will condensate on it. We know: molar mass, universal gas constant, and neglate the liquid formation from condensation.
After how much time will the gas have another pressure, let's call it p2?
at solution
The number of molecules that hit the cold surface in a time interval dt is:
dN = n * dV , where dV= v * dt * S, v= root mean square velocity ; n= molcule volumetric concentration ( m^-3)
For that dt we can keep n constant so : n=N/V => dN/N= v* dt* S / V, and here is my problem...
I can't integrate this because I would say that the intitial number of molecules is 0. Any ideas?
Thank you[/B]
You nearly have it. But why do you think that the number of molecules at t=0 is zero?
Really what you want to do is write a differential equation for the pressure as a function of time, P(t) . Use the ideal gas law, and the pressure at t=0, P(0). It should look something like so.
## \frac{dP(t)}{dt} = - \text{const} P(t)##
And you should be able to solve that pretty easily. So can you work out what "const" should be here?
I'm stuck at something...
from ideal gas equation:
dp/dt * V = dN/dt * m/M * R*T ; m-molecule mass; M=molar mass
What is dN/dt? dN/dt = -N * v * S / V ?
yes, I think that's the answer:
so: N = p*V/R*T => dN/dt = - p * v * S/ R * T => const = v*S*m*v / M*V
Related to Spherical thermodynamical chamber
1. What is a spherical thermodynamical chamber?
A spherical thermodynamical chamber is a scientific apparatus used to study the behavior of gases and other substances under controlled temperature and pressure conditions. It is typically a sealed, spherical container with a thermally insulated wall and various sensors and instruments for measuring temperature, pressure, and other parameters.
2. How does a spherical thermodynamical chamber work?
The chamber works by creating a closed system where changes in temperature and pressure can be controlled and measured. A sample of gas or substance is placed inside the chamber, and the temperature and pressure are adjusted using heating or cooling elements and a piston or other mechanism. The changes in these parameters can then be observed and recorded.
3. What are the applications of a spherical thermodynamical chamber?
Spherical thermodynamical chambers are used in various scientific fields, including physics, chemistry, and engineering. They are used to study the properties of gases and other substances, such as phase transitions, chemical reactions, and material properties. They are also used in the development of new materials and processes.
4. How is a spherical thermodynamical chamber different from other types of chambers?
Unlike other types of chambers, such as cylindrical or rectangular ones, a spherical thermodynamical chamber has a more uniform distribution of temperature and pressure. This makes it ideal for studying the behavior of gases and other substances in a more controlled and consistent environment.
5. Can a spherical thermodynamical chamber be used for industrial purposes?
While spherical thermodynamical chambers are primarily used for scientific research, they can also have industrial applications. They can be used for testing and developing new materials and processes, as well as for quality control and production optimization in industries such as pharmaceuticals, food and beverage, and energy production.
