Spin 1/2 planced in a magnetic field at x-direction
A spin-1/2 particle placed in a magnetic field pointing in the x-direction has a Hamiltonian defined as H = -B Sx, where Sx is represented by the Pauli x-matrix. The energy eigenvalues of the Hamiltonian are ±(Bh-bar/2), with the lowest energy state corresponding to E = -Bh-bar/2. The eigenstates associated with these eigenvalues are [1, 1] and [1, -1]. When measuring the spin component in the x-direction, the probability of finding the value h-bar/2 is calculated to be 1, indicating certainty in this measurement. This conclusion is reached by normalizing the eigenvector and applying the probability formula for quantum states.
M-st
spin 1/2 placed in a magnetic field at x-direction
Hello guys
I have been a regular reader of this forum. This is my first thread.
A spin-1/2 is place in a magnetic field which points in the x-direction. The Hamiltonian is \hat{H} = - B Sx
where Sx = [STRIKE]h[/STRIKE]/2 * pauli x-matrix. We have absorbed all couplings into an effective magnetic field B>0 so that B has dimension inverse time.
1. Find the energy eigenvalues and corresponding eigenstates of H.
the spin is known to be in its lowest energy state. Then a measurement (M1) of the spin-component in the x-direction is carried out.
2. Calculate the probability of finding the value h-bar /2 in measurement M1.
Many attempts but, don't have a clue where to start from.
To start with: Can you write S_x$ as a matrix? What matrix would it be? Can you find eigenvectors and eigenvalues of this matrix?
yes. the S_x matrix is (h-bar)/2 * pauli x- matrix. I have written it in the question above.
yes. the eigenvalues are +- (h-bar/ 2). and the eigenvectors are [1 1] and [1 -1]
So the eigenvalues of Hamiltonian become :\lambda = \pm \frac{B hbar}{2}
the eigenvectors are the same as written above.
what about the propability now?
So, which will be "the lowest energy eigenstate"?
Since the hamiltonian has two eigenvalues, so the one with lowest energy will be E = (- Hbar*B)/2 ? or is it the plus one. ?
Alright, the minus one is lower. Now, if you want to calculate probabilities, you must normalize the eigenvector. What will be the normalized (norm one) eigenvector?
The normalized eigenvectors: \frac{1}{\sqrt{2}} [1 1]. And the probability for getting hbar/2 is 0?
Now, be careful. You have H=-BSx. Eigenvalues of Sx are hbar/2 and -hbar/2. When Sx has eigenvalue hbar/2, H has eigenvalue -Bhbar/2 - which is the lowest. In general, the probability is given by the expression of the form
|<u|v>|^2
But here |u> and |v> are the same: on your (normalized) eigenvector u=v= <br /> \frac{1}{\sqrt{2}}<br />[1,1] H has the lowest eigenvalue and Sx has eigenvalue hbar/2. So?
i got it now. then the probability is 1. thanks
  • · Replies 0 ·
  • · Replies 19 ·
