Spin 1/2 representation of a particle
In summary, when considering both spin and space position of a spin 1/2 particle, the appropriate object to use is a spinor tensor with respect to the SL(2,C) group. The little groups for physically relevant cases are SO(3) for massive particles and ISO(2) for massless particles. The appropriate representation for the latter is restricted to O(2) or its covering group U(1), leading to two physical polarization-degrees of freedom for massless particles with spin ≥ 1/2.
Tio Barnabe
A spin 1/2 particle is represented by a spinor while its position is represented by a three-vector. What object should we use to represent such particle if we want to consider both features? That is, what object should we use if we want to consider both spin and space position?
It seems there's not a obvious way to make a product between a spinor and a three-vector.
There is an obvious way. The tensor product.
Orodruin said:
The tensor product.
Even that spinors are not tensors?
Spinors belong to a vector space.
One can show that, if ##V^{\mu}## are components of a 4-vector, i.e. an object transforming under the fundamental representation of the restricted Lorentz group, then
[tex] \psi_{\alpha\dot{\beta}} =: \eta_{\mu\nu}V^{\mu}\left(\sigma^{\nu}\right)_{\alpha\dot{\beta}} [/tex]
are the components of a spinor tensor with respect to the ##\mbox{SL}(2,\mathbb{C})## group.
Likes vanhees71
As commented above there are finite dimensional spinorial representations of the Lorentz group that relates those objects without any contradiction. Maybe what makes you uneasy and don't know how to pinpoint mathematically is that these finite dimensional representations of the Lorentz group when irreducible are not unitary since the group is not compact. This is why one has to turn to infinite dimensional representations. Still, QFT makes use of the finite dimensional representations in the rest frame(since in the neighbourhood of the identity unitarity is retained) of massive particles and it constructs their invariant mass and spin with its Lie algebra Casimir invariants.
@RockyMarciano: Please read and understand Wigner's paper on the unitary irreps. of the proper orthochronous Poincare group or any good textbook on the subject like, e.g., Weinberg, QT of Fields, Vol. I.
Likes RockyMarciano
Are you referring to this part of my post?:
I saw that it was misleadingly worded when it was late to edit it.
Of course the only unitary irrep used is the infinite dimensional one and the Casimir invariants belong to this infinite dimensional unitary representation. When talking about the finite dimensional rep I was thinking about the rotational group that is the subgroup of the Lorentz group that leaves the subspace rep of vanishing three-momentum invariant. The sentence is not correct as written since I didn't specify I was referring to the rotations subgroup. Apologies.
Now it's correct: The little groups are represented by finite-dimensional unitary representations of the little groups, defined by leaving the standard momentum in the various cases constant.
(So far), physically relevant are the cases with ##m^2>0## (massive particles) and ##m^2=0## (massless particles). For ##m^2>0## the natural choice of the standard momentum is ##\vec{p}=0##, and the little group is the rotation group SO(3), which is substituted by its covering group SU(2), i.e., importantly you include the possibility of half-integer spin.
The case ##m^2=0## is more subtle. Here the standard choice for the standard momenum is ##k^0=\pm |\vec{k}|##, ##\vec{k}=k \vec{e}_3##. The little group is ISO(2), which has no proper finite-dimensional irreps. It's like the group of a non-relativistic particle in a plane, i.e., you have two translation operators with a continuous spectrum, but continuous intrinsic degrees of freedom have not been observed (yet?). Thus one restricts the irreps. to such for which the translations in this abstract ISO(2) are represented trivially, and then the non-trivial subgroup is O(2) (the rotations around the three-axis) or rather its covering group U(1). Since for the full Lorentz group you get also the full rotations as a subgroup the corresponding helicities (angular momentum component in direction of the momentum of the particle) are restricted to the set ##h \in \{0,\pm 1/2,\pm1,\ldots\}##. Thus, massless particles with spin ##\geq 1/2## all have two physical polarization-degrees of freedom (here using the basis of good helicity to construct the irreps).
Related to Spin 1/2 representation of a particle
1. What is the spin 1/2 representation of a particle?
The spin 1/2 representation of a particle describes the intrinsic angular momentum of a particle, which is a fundamental property of all particles. It is represented by a quantum number called spin, and particles with spin 1/2 are called fermions.
2. How is the spin 1/2 representation related to quantum mechanics?
The spin 1/2 representation is an important concept in quantum mechanics as it helps explain the behavior of particles at the subatomic level. It is used to describe the spin of particles and is crucial in predicting their properties and interactions.
3. Can particles have a spin value other than 1/2?
Yes, particles can have spin values of 0, 1, 2, and so on. However, the spin 1/2 representation is unique as it describes the behavior of fermions, which have half-integer spin values. Bosons, on the other hand, have integer spin values.
4. How is the spin 1/2 representation experimentally observed?
The spin 1/2 representation of a particle can be experimentally observed through various techniques, such as scattering experiments and magnetic resonance imaging (MRI). These techniques allow scientists to measure the spin of particles and study their behavior.
5. How does the spin 1/2 representation affect the properties of a particle?
The spin 1/2 representation affects the properties of a particle in several ways. For instance, it determines how a particle interacts with other particles and how it behaves in a magnetic field. The spin also plays a crucial role in determining the stability and energy levels of particles.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
