Spin 3/2 along an arbitrary direction
In summary, the problem involves finding the matrix for the spin component along a unit vector with arbitrary direction, as well as its eigenvalues and eigenvectors. The general spin operator and the unit vector are given, and using the braket notation can simplify the calculation. The eigenvalue problem is then set up and solved for the values of lambda and the coefficients a, b, c, and d for each eigenstate.
Samuel Williams
Consider a particle of spin 3/2. Find the matrix for the component of the spin along a unit vector
with arbitrary direction n. Find its eigenvalues and eigenvectors.
I know that the general spin operator is
\begin{equation}
\widehat{S} = a\cdot \widehat{S}_x + b\cdot \widehat{S}_y + c\cdot \widehat{S}_z
\end{equation}
and that
\begin{equation}
\hat{n} = (\sin{\phi}\cos{\theta},\sin{\phi}\sin{\theta},\cos{\phi})
\end{equation}
Now
\begin{equation}
\widehat{S}_x \stackrel{\cdot}{=} \frac{\hbar}{2}\begin{pmatrix}0 & \sqrt3 & 0 & 0 \\ \sqrt3 & 0 & 2 & 0 \\ 0 & 2 & 0 & \sqrt3 \\ 0 & 0 & \sqrt3 & 0\end{pmatrix}\, ,\
\widehat{S}_y \stackrel{\cdot}{=} \frac{\hbar}{2i}\begin{pmatrix}0 & \sqrt3 & 0 & 0 \\ -\sqrt3 & 0 & 2 & 0 \\ 0 & -2 & 0 & \sqrt3 \\ 0 & 0 & -\sqrt3 & 0\end{pmatrix}\, ,\
\widehat{S}_z \stackrel{\cdot}{=} \hbar\begin{pmatrix}3/2 & 0 & 0 & 0 \\ 0 & 1/2 & 0 & 0 \\ 0 & 0 & -1/2 & 0 \\ 0 & 0 & 0 & -3/2\end{pmatrix}\ .
\end{equation}
So then we get
\begin{equation}
\hat{n}\cdot \widehat{S} \stackrel{\cdot}{=} \frac{\hbar}{2}(\sin{\phi}\cos{\theta})\begin{pmatrix}0 & \sqrt3 & 0 & 0 \\ \sqrt3 & 0 & 2 & 0 \\ 0 & 2 & 0 & \sqrt3 \\ 0 & 0 & \sqrt3 & 0\end{pmatrix}\ + \frac{\hbar}{2i}(\sin{\phi}\sin{\theta})\begin{pmatrix}0 & \sqrt3 & 0 & 0 \\ -\sqrt3 & 0 & 2 & 0 \\ 0 & -2 & 0 & \sqrt3 \\ 0 & 0 & -\sqrt3 & 0\end{pmatrix}\ + \hbar(\cos{\phi})\begin{pmatrix}3/2 & 0 & 0 & 0 \\ 0 & 1/2 & 0 & 0 \\ 0 & 0 & -1/2 & 0 \\ 0 & 0 & 0 & -3/2\end{pmatrix}\ .
\end{equation}
Now, I know I should determine the secular equation (characteristic equation) after adding the matrices and find the eigenvectors and eigenvalues from there, but I keep getting long and complicated equations that don't seem to factor. Is there any shorter method or any other way to do it?
A less space-consuming calculation is done by using the braket notation instead of matrices. In the basis of the eigenstates of ##S_z##, the braket version of ##S## is
S = \sum_{m=-3/2}^{3/2} \sum_{m'=-3/2}^{3/2} |m\rangle \langle m| S |m'\rangle \langle m'|
Write the eigenvalue problem ##S|u_1\rangle = \lambda |u_1\rangle## where ##|u_1\rangle = a|3/2\rangle + b|1/2\rangle + c|-1/2\rangle + d|-3/2\rangle ##. You are then to find ##\lambda##'s and ##a##, ##b##, ##c##, and ##d## for each one value of ##\lambda##.
Related to Spin 3/2 along an arbitrary direction
What does "Spin 3/2 along an arbitrary direction" mean?
"Spin 3/2" refers to the spin quantum number of a particle, which is a measure of its intrinsic angular momentum. "Along an arbitrary direction" means the spin is oriented in a specific direction in space, rather than being aligned with a particular axis.
What is the significance of "Spin 3/2" in quantum mechanics?
Spin 3/2 particles, also known as fermions, have half-integer spin and follow the rules of quantum mechanics. This means they have quantized angular momentum and obey the Pauli exclusion principle, which states that no two fermions can occupy the same quantum state.
How is the spin 3/2 state of a particle described mathematically?
In quantum mechanics, the state of a spin 3/2 particle is described by a mathematical object called a spinor. This is a complex-valued vector with four components, representing the four possible spin orientations of the particle along an arbitrary direction.
What are the possible outcomes when measuring the spin 3/2 of a particle along an arbitrary direction?
When measuring the spin 3/2 of a particle along an arbitrary direction, there are four possible outcomes: +3/2, +1/2, -1/2, and -3/2. These correspond to the four components of the spinor and represent the spin orientations of the particle.
How does the spin 3/2 of a particle affect its behavior and interactions?
The spin 3/2 of a particle is a fundamental property that influences its behavior and interactions with other particles. For example, particles with different spin values may have different energy levels and can interact with each other through spin-dependent forces.
