Spin direction of quarks in a baryon
In summary, the baryon has a spin of 3/2 when all three quarks have the same flavor and spin in the same direction. In a proton, the two up-quarks can either spin in the same direction or in opposite directions, as they are in a superposition of spin states. However, the lower energy state is favored for the composite baryon and the three quarks are treated as distinguishable particles with respect to their spins. The two spin-1/2 states can be thought of as different colors in a spin singlet, with the remaining spin accounted for by the third quark.
bsaucer
30
If all three quarks in a baryon have the same flavor, they all spin the same direction, causing the baryon to have 3/2 spin. In a proton, do both up-quarks spin in the same direction (with the down-quark spinning opposite)? Or can the two up-quarks spin in opposite directions?
Normally they, as spin 1/2 particles would be in some superposition of correlated and anti-correlated spin combinations. The composite of three spin-1/2 particles would resolve into three irreducible spin representations two with total spin of 1/2 and one with total spin of 3/2. With spin coupling through the magnetic moment the lower spin states for the composite would be lower energy and thus you should see states in the higher total spin state decay into the lower energy state.
Note the total dimension is 2x2x2=8 = 4 + 2 + 2.
And since the baryons must be color neutral the color charge of the three quarks should be distinct and they would be treated statistically as distinguishable particles (M-B statistics) with respect to their spins. The extra variable distinguishing the two spin-1/2 states would be some quantity defined by combining spin and the index variable we use to distinguish the particles (su(3) color here).
You can think of the two spin-1/2 cases as say red and green quark in a spin singlet and all the spin 1/2 is accounted for by the blue quark, times the two other equivalent cases modulo two of those six states being co-opted by the spin 3/2 irrep.
Related to Spin direction of quarks in a baryon
1. What is the spin direction of quarks in a baryon?
The spin direction of quarks in a baryon is determined by their intrinsic spin, which is a fundamental property of particles. It can have a value of either +1/2 or -1/2 along a specified axis.
2. How is the spin direction of quarks in a baryon measured?
The spin direction of quarks in a baryon is measured through experiments using high-energy particle accelerators. By studying the behavior of particles during collisions, scientists can determine their spin direction.
3. Can the spin direction of quarks in a baryon change?
No, the spin direction of quarks is a fundamental property and cannot be changed. However, the orientation of the spin axis can change when the particle interacts with other particles or fields.
4. What is the significance of the spin direction of quarks in a baryon?
The spin direction of quarks plays a crucial role in determining the properties and behavior of baryons, such as their magnetic moments and interactions with other particles. It also helps in understanding the structure of matter and the laws of quantum mechanics.
5. Are there any theories about the spin direction of quarks in a baryon?
Yes, there are various theories and models that try to explain the spin direction of quarks in baryons, such as the Standard Model of particle physics and the Quark Model. However, further research and experiments are still needed to fully understand this phenomenon.
