Spin matrix representation in any arbitrary direction
In summary: Thanks. I have some problem to understand this intuitively. Can you just explain a bit as to why we end up getting this sole matrix when we change our basis and fix it along a...
PhysicsTruth
117
Find the representation in which the component of spin along a direction ##\hat{n}## is diagonal, where ##\hat{n}## is a vector in the ##x-z## plane, making an angle ##\theta## with the ##z## axis.
##\sigma \cdot \hat{n} = \begin{pmatrix} cos(\theta) & sin(\theta)e^{-i\phi} \\ sin(\theta)e^{i\phi} & -cos(\theta) \end{pmatrix}##
##\sigma _z = \begin{pmatrix} 1 & 0\\ 0 & -1 \end{pmatrix}##
I've tried to use the 1st equation as a matrix to determine, but it clearly isn't a diagonal matrix. My guess is that I need to find the spin matrix along the direction ##\hat{n}##, but do I need to find the eigenstates of ##\sigma \cdot \hat{n}## first and check if they form a diagonal matrix or not? Can someone help me in figuring out how to proceed?
You could find the eigenvectors of that matrix, but other than that I'm not sure what the question is asking.
Likes vanhees71
The matrix you've found would then be diagonal in the basis of its eigenvectors. That might be what is intended.
Likes vanhees71
To be honest, the matrix doesn't have non-trivial solutions explicitly. It's only when one of the values is decided can the other value be determined. So, it might be diagonal only for a particular value of ##\theta## or ##\phi##. Also, ##\phi## hasn't been mentioned explicitly, so can't really proceed with that even.
It's manifestly Hermitian so must have an orthonormal eigenbasis. Moreover, it's physically identical to ##S_z## etc. So must have an eigenbasis.
Likes PhysicsTruth and vanhees71
Another way is to think about how rotations act on spinors an tgen use the rotation which maps ##\vec{e}_z## to ##\vec{n}##.
Likes PhysicsTruth
Okay, so the rotation around any unit axis ##\hat{n}## of a spinor is given by-
##Icos(\theta /2) + i(\hat{n} \cdot \sigma)sin(\theta /2)##
So here, it's getting rotated about the ##y## axis, so should I get the representation as required if I use this rotation form?
Can someone just tell me how to write a Spin Matrix along any vector rotated by an angle ##\theta## from ##z## axis in terms of the eigenbasis of ##\sigma _z## Pauli spin matrix? Is it ##cos(\theta /2) |+> + sin(\theta /2) |->##, where ##|+>, |->## are eigen vectors of ##\sigma _z## ?
In that case, I can just perform an Unitary transformation to make it diagonal. So I need to know this.
You already have the matrix in your original post. For the specific case of a direction in the x-z plane you have ##\phi =0##.
Yes, that's the eigenvector corresponding to eigenvalue ##1##. You need the second eigenvector corresponding to eigenvalue ##-1##.
You don't need to calculate the transformation to the eigenbasis, as you know it takes the matrix takes the same form as the Pauli matrix for ##S_z## in that basis.
So, would the representation just be ##\begin{pmatrix} 1 & 0\\ 0 & -1 \end{pmatrix}## in that case?
I did get this after a wholesome unitary transformation to the new eigenbasis, which is the same as the ##\sigma _z## matrix.
Likes PeroK
Yes, once you have the eigenvalues and vectors you know the matrix in that eigenbasis. Although, it can't hurt to grind out the transformation just to check!
Likes PhysicsTruth
Thanks. I have some problem to understand this intuitively. Can you just explain a bit as to why we end up getting this sole matrix when we change our basis and fix it along a direction?
The physical explanation is that the z-axis is an arbitrary choice. Any other direction is physically equivalent (and, indeed, could be chosen as the z-axis). The formalism of spin about any direction must be equivalent to the formalism about the z-axis.
Mathematically, the action of an operator is completely determined by its action on a basis. And, the action on its eigenbasis is "diagonal". You don't have to transform bases, you can study the action of the operator on that eigenbasis directly.
FAQ: Spin matrix representation in any arbitrary direction
What is a spin matrix representation?
A spin matrix representation is a mathematical tool used in quantum mechanics to describe the intrinsic angular momentum, or spin, of a particle. It is a matrix that represents the possible spin states of a particle in a particular direction.
How is a spin matrix representation calculated?
A spin matrix representation is calculated by taking the dot product of the spin operator and the spin vector in the given direction. The spin operator is a mathematical operator that represents the spin of a particle, while the spin vector represents the direction in which the spin is being measured.
What is the significance of an arbitrary direction in spin matrix representation?
An arbitrary direction in spin matrix representation means that the spin of a particle can be measured in any direction, not just the traditional x, y, or z axes. This allows for a more complete understanding of the spin of a particle, as it is not limited to a specific orientation.
Can spin matrix representation be used for all types of particles?
Yes, spin matrix representation can be used for all types of particles, including fermions and bosons. It is a fundamental concept in quantum mechanics and is applicable to all particles that possess spin.
How is spin matrix representation related to quantum entanglement?
Spin matrix representation is related to quantum entanglement because it is used to describe the spin states of particles that are entangled. Entanglement occurs when two or more particles are connected in such a way that the state of one particle is dependent on the state of the other, even when they are physically separated. Spin matrix representation helps to understand and quantify this phenomenon in quantum mechanics.
