I Spin networks: what exactly is a trivalent node?
Heidi
Hi Pfs
Rovelli defines spin networks in this paper
https://arxiv.org/abs/1004.1780
for a trivalent node Vn = 0 (the volume)
nodes begin to "get" volume with the four valent case.
take a cube or a tetrahedron, each vertex is linkes to 3 nodes so they would have a null volume.
things are different if we take the reciprocal network: from a node inside a tetrahedron four edges can intersect the four faces.
then we are in the four valent case.
have we to be more precise to talk about the valence of a node?
Graph theory nomenclature can be confusing, definitions must often be given to maintain the proper content.
And believe it or not some definitions are even excluded from certain theorems.
What is a valence of a node, trivalent node.
A trivalent (3-valent) graph is often called a cubic graph.
A graph consists of a set N of items called nodes (vertices, points etc.), with a set E ⊆ the set of (unordered) pairs of nodes.
The pairs that are in E are called edges (links, arcs etc.) & an edge is said to
“run between” its two nodes, its “endpoints”.
This is an alert about a claim regarding the standard model, that got a burst of attention in the past two weeks. The original paper came out last year: "The electroweak η_W meson" by Gia Dvali, Archil Kobakhidze, Otari Sakhelashvili (2024) The recent follow-up and other responses are "η_W-meson from topological properties of the electroweak vacuum" by Dvali et al "Hiding in Plain Sight, the electroweak η_W" by Giacomo Cacciapaglia, Francesco Sannino, Jessica Turner "Astrophysical...
