Spin-orbit Interaction & Degenerate Perturbation Theory
In summary, according to the speaker, the eigenvalue equation cannot be evaluated for the matrix element <nlm_l'sm_s'| \hat{S}\cdot\hat{L}|nlm_lsm_s> because it is not an eigenstate of \hat{S} \cdot \hat{L} .
PhysicsKin
Hello! This is my first time posting, so please correct me if I have done anything incorrectly.
There's something that I don't understand about the spin-orbit interaction.
First of all I know that
[itex][\hat{S} \cdot \hat{L}, \hat{L_z}] \ne 0[/itex]
[itex][\hat{S} \cdot \hat{L}, \hat{S_z}] \ne 0[/itex]
so this means that [itex] \hat{S} \cdot \hat{L} [/itex] doesn't share a common set of eigenstates with [itex] \hat{S_z} [/itex] and [itex] \hat{L_z} [/itex].
I know that [itex]| nlm_lsm_s>[/itex] is a common eigenstate for [itex] \hat{S_z} [/itex] and [itex] \hat{L_z} [/itex],
so that would mean it is not an eigenstate for [itex] \hat{S} \cdot \hat{L} [/itex].
However, I've read that [itex]<nlm_l'sm_s'|\hat{S}\cdot\hat{J}|nlm_lsm_s>\ne0[/itex] for all [itex] m_l \ne m_l', m_s\ne m_s' [/itex] i.e. the diagonal elements are non-zero. Surely if [itex]| nlm_lsm_s>[/itex] is not an eigenstate of [itex] \hat{S} \cdot \hat{L} [/itex], then the matrix element cannot be evaluated?
Thank you in advance!
I can't follow your conclusion.
Hiya! Thanks for the reply!
I think my thought process went like this:
Suppose I have an operator [itex] \hat{Q} [/itex], then the eigenvalue equation [itex] \hat{Q} |q>=q|q> [/itex] can only be evaluated if [itex] |q> [/itex] is an eigenstate of [itex] \hat{Q} [/itex].
Then since [itex] |nlm_lsm_s> [/itex] is not an eigenstate of [itex] \hat{S}\cdot\hat{L} [/itex], then surely the matrix element [itex] <nlm_l'sm_s'| \hat{S}\cdot\hat{L}|nlm_lsm_s>[/itex] could not be evaluated? I feel like something went wrong, because all the books I've read managed to evaluate it to be [itex] \ne 0[/itex] for [itex] m_l'\ne m_l \& m_s'\ne m_s [/itex]. Or could you shed some light into how to go about evaluating it?
Thank you so much!
Of course, |q> is only an eigenstate if it fulfills the eigenvalue equation. However, Q can act on any state within it's domain of definition, only that the resulting state will not be a multiple of the original state.
E.g. take ##Q=L_z## and ## |q\rangle =a |m>+b|m'>## where |m> and |m'> are eigenvectors of ##>L_z## with corresponding eigenvalues m and m', respectively. Then ##L_z|q\rangle=a m |m\rangle +b m' |m'\rangle##.
Ok I see you what you mean, but how could I evaluate the matrix elements [itex] <nlm_l'sm_s'|\hat{S}\cdot\hat{L}|nlm_lsm_s> [/itex] if I cannot use the eigenvalue equation?
Either you express ##| n l m_l m_s \rangle## in terms of a linear combination of eigenstates of ##\hat{S}\cdot\hat{L}## (in this particular case, using Clebsch-Gordan coefficients), or you actually calculate the integral corresponding to the bracket, as you would do to calculate ##\langle \hat{x} \rangle## or ##\langle \hat{p} \rangle## for say an eigenstate of the harmonic oscillator.
Is there a quick way to show that it is not diagonal?
[\hat{L}_z, \hat{S}\cdot\hat{L} ] \neq 0
FAQ: Spin-orbit Interaction & Degenerate Perturbation Theory
1. What is spin-orbit interaction?
Spin-orbit interaction is a phenomenon in which the spin of an electron interacts with its orbital motion around an atomic nucleus. This interaction can lead to energy shifts in the electronic energy levels, and it is responsible for some of the fine structure observed in atomic spectra.
2. How does spin-orbit interaction affect degenerate perturbation theory?
Spin-orbit interaction is considered a perturbation in degenerate perturbation theory. This means that it is a small correction to the Hamiltonian that describes the energy levels of a system. When calculating the energy shifts caused by spin-orbit interaction, this perturbation must be taken into account for accurate results.
3. What is degenerate perturbation theory?
Degenerate perturbation theory is a mathematical method used to calculate energy shifts in a system when the energy levels are degenerate, meaning they have the same energy. This method takes into account small perturbations in the system, such as spin-orbit interaction, to calculate the energy shifts.
4. How is spin-orbit interaction related to the fine structure constant?
The fine structure constant, also known as α (alpha), is a dimensionless constant that characterizes the strength of the electromagnetic interaction between elementary particles. The value of α is related to spin-orbit interaction through the Dirac equation, which describes the behavior of electrons in a relativistic quantum mechanical system.
5. What are some applications of spin-orbit interaction & degenerate perturbation theory?
Spin-orbit interaction and degenerate perturbation theory are used in various fields, including atomic and molecular physics, solid-state physics, and quantum chemistry. They help in understanding the behavior of electrons in complex systems and play a crucial role in the development of technologies such as magnetic storage devices and quantum computers.
