Spin singlets and the Bell states
In summary, when considering a bipartite system of two spin-1/2 particles, the overall spin of the pair can be decomposed into a spin singlet and a spin triplet using the Clebsch-Gordon series. The spin singlet state, represented by ##|\Psi^- \rangle##, is rotationally invariant and is one of the Bell states. However, the other Bell state, ##|\Phi^+ \rangle##, also has the property of rotational invariance and can be expressed in different ways, such as in terms of an arbitrary unit vector. This may seem contradictory, but it is mathematically proven and used extensively in quantum mechanics. Additionally, it is noted that while ##|\Psi^- \
VantagePoint72
821
34
Given two spin-1/2 particles, the overall spin of the pair decomposes into a spin singlet and a spin triplet. Using the Clebsch-Gordon series and referring to the z-axis, we find the spin singlet is:
##|\Psi^- \rangle = \frac{1}{\sqrt{2}}(|\uparrow_z \downarrow_z \rangle - |\downarrow_z \uparrow_z \rangle)##
The overall state is one of the Bell states and is given the standard label. Being a spin singlet is the same thing as being rotationally invariant. However, consider another of the Bell states:
##|\Phi^+ \rangle = \frac{1}{\sqrt{2}}(|\uparrow_z \uparrow_z \rangle + |\downarrow_z \downarrow_z \rangle)##
This state has an interesting property; it may also be expressed as:
##|\Phi^+ \rangle = \frac{1}{\sqrt{2}}(|\uparrow_x \uparrow_x \rangle + |\downarrow_x \downarrow_x \rangle)##
or, indeed,
##|\Phi^+ \rangle = \frac{1}{\sqrt{2}}(|\uparrow_{\hat{n}} \uparrow_{\hat{n}} \rangle + |\downarrow_{\hat{n}} \downarrow_{\hat{n}} \rangle)##
where ##{\hat{n}}## is an arbitrary unit vector. But isn't this property just a mathematical expression of rotational invariance? So how does that square with the fact that it is ##|\Psi^- \rangle## (not ##|\Phi^+ \rangle##) that is the spin singlet for a bipartite system of two spin-1/2 particles?
It's ##|\Psi^- \rangle## that has this property, not ##|\Phi^+ \rangle##. Work it out for the x case and you'll see.
I have worked it out for the x case, and the result holds:
##| \uparrow_x \rangle = \frac{1}{\sqrt{2}}(| \uparrow_z \rangle + | \downarrow_z \rangle)##
##| \downarrow_x \rangle = \frac{1}{\sqrt{2}}(| \uparrow_z \rangle - | \downarrow_z \rangle)##
Hence:
##\frac{1}{\sqrt{2}}(| \uparrow_x \uparrow_x \rangle + | \downarrow_x \downarrow_x \rangle ##
##=\frac{1}{2\sqrt{2}}((| \uparrow_z \rangle + | \downarrow_z \rangle)(| \uparrow_z \rangle + | \downarrow_z \rangle) + (| \uparrow_z \rangle - | \downarrow_z \rangle)(| \uparrow_z \rangle - | \downarrow_z \rangle))##
##=\frac{1}{\sqrt{2}}(| \uparrow_z \uparrow_z \rangle + | \downarrow_z \downarrow_z \rangle ##
The general statement is proved (and used extensively by) Preskill in http://www.theory.caltech.edu/people/preskill/ph229/notes/chap2.pdf (p.31)
Moreover, this property does not hold for ##|\Psi^- \rangle##, it picks up an overall minus sign. This is irrelevant quantum mechanically; however, it is still odd, given it is supposed to be rotationally invariant. I'm more put off by the behaviour of ##|\Phi^+ \rangle## though, it seems like it shouldn't do this. But, as Preskill shows, it does.
Related to Spin singlets and the Bell states
1. What are spin singlets in quantum mechanics?
Spin singlets are a type of quantum state where two particles are entangled and have opposite spin states. This means that the spin of one particle is always the opposite of the other, regardless of the distance between them.
2. What are Bell states and how are they related to spin singlets?
Bell states, also known as EPR pairs, are four specific quantum states that are used to describe the entanglement between two particles. One of these states is a spin singlet, where the two particles have opposite spin states.
3. How are spin singlets and Bell states used in quantum computing?
Spin singlets and Bell states are important in quantum computing because they can be used for quantum teleportation and quantum communication. They also play a role in quantum error correction and as a resource for quantum algorithms.
4. Can spin singlets be created in a lab?
Yes, spin singlets can be created in a lab using techniques such as the controlled collapse of a quantum wave function or the use of entangling gates in a quantum computer. However, maintaining their coherence and entanglement is a challenge.
5. What is the significance of spin singlets and Bell states in quantum entanglement?
Spin singlets and Bell states are important in quantum entanglement because they demonstrate non-local correlations between two particles. This means that even when separated, the particles can still have a strong influence on each other, which goes against classical physics principles.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
