I Spinors and eigenspinors confusion
happyparticle
TL;DR Summary
Spinors and eigenspinors of ##S_z## and ##S_x## for a spin 1/2
Hi,
While studying the spin 1/2, I'm facing some confusions about the spinors and the eigenspinors.
I understand that ##\chi = \begin{bmatrix}a \\ b \end{bmatrix}## is the spinor with ##\chi_+ = \begin{bmatrix}1 \\ 0 \end{bmatrix}## and ##\chi_-= \begin{bmatrix}0 \\ 1 \end{bmatrix}## the eigenspinors.
However, in my book I have ##\chi_+ = \begin{bmatrix}1 \\ 0 \end{bmatrix}, (eigenvalue + \frac{\hbar}{2})## which I'm not sure to understand.
Furthermore, to find the eigenvalue of ##S_x##, Griffith uses ##\begin{bmatrix}-\lambda & \frac{\hbar}{2}\\ \frac{\hbar}{2} & -\lambda \end{bmatrix} = 0##, but I don't see where this expression come from?
Finally, he says that ##\chi = (\frac{a+b}{\sqrt{2}} \chi_+ + \frac{a-b}{\sqrt{2}} \chi_-)##, which I suposse ##\frac{a+b}{\sqrt{2}} = a ## and ##\frac{a-b}{\sqrt{2}} = b##, again I'm not sure how he get those expressions for a and b.
happyparticle said:
TL;DR Summary: Spinors and eigenspinors of ##S_z## and ##S_x## for a spin 1/2
Hi,
You are close. To find the eigenvalues we take the determinant of ##S_x - I \lambda## and set it equal to 0:
##\left | \dfrac{\hbar}{2} \left ( \begin{matrix} 0 & 1 \\ 1 & 0 \end{matrix} \right ) - \left ( \begin{matrix} \lambda & 0 \\ 0 & \lambda \end{matrix} \right ) \right | = 0##
The last statement is going to take a bit more work and I'm going to try to be a bit psychic because you didn't say where this came from.
The +x eigenvector written in the z basis is
## \dfrac{1}{\sqrt{2}} \left ( \begin{matrix} 1 \\ 1 \end{matrix} \right )##
and the -x eigenvector is written as
## \dfrac{1}{\sqrt{2}} \left ( \begin{matrix} 1 \\ -1 \end{matrix} \right )##
So, I believe the question is: If ##\chi = \left ( \begin{matrix} a \\ b \end{matrix} \right )## is written in the x basis, how can we rewrite this in the z basis?
-Dan
I'm not totally sure, but I think ##\chi## is in x basis.
Since the expression is ##
\chi = (\frac{a+b}{\sqrt{2}} \chi_+^{x} + \frac{a-b}{\sqrt{2}} \chi_-^{x})##
I'm still not sure to understand the expression ##
Is ##\chi_+ = \begin{bmatrix}1 \\ 0 \end{bmatrix},## and/or ##(eigenvalue + \frac{\hbar}{2})## ?
Griffith says, if you mesure ##S_x##, the probability of getting ##+\hbar/2## is ##(1/2) |a+b|^2##.
There should be a link with the expression above, but I don't see why he says the probability of getting ##+ \hbar/2##
If you work in a basis of eigenvectors of ##\hat{s}_3##, ##|s_3 \rangle##, with the eigenvalues ##s_3 \in \{\hbar/2,-\hbar/2 \}##, then you can write any spin vector as
$$|\chi \rangle=a |\hbar/2 \rangle + b |\hbar/2 \rangle.$$
Then there is a one-to-one mapping between the vectors and their components wrt. that basis
$$\chi \rangle \mapsto \begin{pmatrix} a \\ b \end{pmatrix}.$$
Then the eigenvectors are orthonormal, i.e., ##a=\langle \hbar/2 |\chi \rangle=\chi_{\hbar/2}## and ##b=\langle \hbar/2|\chi \rangle=\chi_{-\hbar/2}##.
Any operator acting on the spinors then has a one-to-one map to ##2 \times 2## matrices:
$$\hat{A} |\chi \rangle=\sum_{s_{31},s_{32}} |s_{31} \rangle \langle s_{31}|\hat{A} s_{32} \rangle \langle{s_{32}}|\chi \rangle.$$
The matrix elements are
$$A_{s_{31} s_{32}}=\langle s_{31}|\hat{A} s_{32} \rangle \langle{s_{32}}$$
and the corresponding matrix
$$\hat{A}=\begin{pmatrix} A_{\hbar/2,\hbar/2} & A_{\hbar/2,-\hbar/2} \\ A_{-\hbar/2,\hbar} & A_{-\hbar/2,-\hbar/2} \end{pmatrix}.$$
And the the components of ##\hat{A} |\chi \rangle## are obviously given by ##\hat{A} \chi##.
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
