Spivak "root 2 is irrational number" problem
In summary, Spivak elegantly proves that √2 is irrational by taking two natural numbers, p and q, and proving that they cannot be expressed in the form m/n (where n is not zero). He defines irrational numbers as those that cannot be expressed in this form, and also defines m and n as integers. In his earlier proof, he only considers natural numbers for p and q, but this is due to the definition he previously established. Ultimately, there is no difference between looking for natural numbers or integers, as an integer can also be expressed as a negative number.
Alpharup
225
Am using Spivak. Spivak elegantly proves that √2 is irrational. The proof is convincing. For that he takes 2 natural numbers, p and q ( p, q> 0)...and proves it.
He defines irrational number which can't be expressed in m/n form (n is not zero).
Here he defines m and n as integers.
But in the earlier proof, he takes p and q as only natural numbers and not integers. Why?
Is it because of definition, he earlier defined?
ie...√((a)^2)...|a|.
ie...root of a real number a
Any rational number m/n (m, n integers, n≠0) can, by multiplying numerator and denominator by -1 if necessary, be written with n>0. If then (m/n)2=2, then also (-m/n)2=2. One of m and -m is positive. Hence, there are postive integers p,q such that (p/q)2=2, and this leads to the contradiction.
Likes Alpharup
There's essentially no difference between looking for natural numbers or integers. An integer may be negative, but that makes no difference to divisibility properties.
Likes Alpharup
Yes...got it
Related to Spivak "root 2 is irrational number" problem
1. What is the "Spivak root 2 is irrational number" problem?
The "Spivak root 2 is irrational number" problem refers to a proof that the square root of 2 (represented as √2) is an irrational number, meaning it cannot be expressed as a simple fraction of two integers. This was first proven by mathematician Michael Spivak in his book "Calculus" published in 1967.
2. How was the irrationality of root 2 proven by Spivak?
Spivak's proof involves showing that if √2 is a rational number, then it can be expressed as a fraction of two integers with no common factors. By assuming that √2 is a rational number, Spivak uses algebraic manipulation to arrive at a contradiction, thus proving that √2 is in fact irrational.
3. Why is the irrationality of root 2 important?
The irrationality of root 2 is important because it is a fundamental concept in mathematics. It helps us understand the concept of infinity and the real number system. It also has practical applications in fields such as engineering and physics.
4. Are there any other proofs of the irrationality of root 2?
Yes, there are several other proofs of the irrationality of root 2, including the well-known proof by Euclid. However, Spivak's proof is considered to be one of the most elegant and concise proofs.
5. What other irrational numbers have been proven to be irrational?
There are many other irrational numbers that have been proven to be irrational, including π (pi), e (Euler's number), and √3 (the square root of 3). In fact, most real numbers are irrational, and there are infinitely many irrational numbers between any two rational numbers.
  • Calculus
