MHB Split Short Exact Sequences .... Bland, Proposition 3.2.6 .... ....
The discussion centers on understanding the proof of Proposition 3.2.6 from Paul E. Bland's "Rings and Their Modules," specifically regarding the well-defined nature of the map \( g' \). It is clarified that the expression \( (x - x') - f(f'(x - x')) \) belongs to both the kernel of \( f' \) and the image of \( f \), leading to the conclusion that it must equal zero due to their intersection being trivial. This ensures that changing \( x \) to \( x' \) does not affect the value of \( g' \), confirming its well-definedness. The discussion also highlights a conceptual trick to understand the proof better, involving the isomorphism of modules and the careful definition of mappings to eliminate ambiguity in pre-images. Overall, the exchange provides clarity on the intricate details of the proof and its implications in module theory.
Math Amateur
MHB
I am reading Paul E. Bland's book "Rings and Their Modules" ...
Currently I am focused on Section 3.2 Exact Sequences in $$\text{Mod}_R$$ ... ...
I need some help in order to fully understand the proof of Proposition 3.2.6 ...
Proposition 3.2.6 and its proof read as follows:
In the above proof of Proposition 3.2.6 we read the following:"... ... Then $$x - x'\in \text{Ker } g = \text{Im } f$$, so $$(x - f( f' (x))) - (x' - f( f' (x'))) = ( x - x') - ( f ( f'(x) ) - f ( f'(x') ) )$$
$$= ( x - x') - f ( f' ( x - x') )$$
$$\in \text{Ker } f' \cap \text{Im } f = 0$$ ... ...
Thus it follows that $$g'$$ is well-defined ... ... "Can someone please explain exactly why/how $$( x - x') - f ( f' ( x - x') ) \in \text{Ker } f' \cap \text{Im } f = 0$$ ... ... Further, can someone please explain in some detail how the above working shows that $$g'$$ is well-defined ...
Help will be much appreciated ...
Peter
Hi Peter,
By a previous remark, each of $x-f(f'(x))$ and $x'-f(f'(x'))$ belongs to $\ker f'$. As $\ker f'$ is a sub-module, this shows that
$$u = (x-f(f'(x))) - (x'-f(f'(x'))) \in\ker f'$$
on the other hand, we have $x-x'\in\ker g=\mathrm{img}\:f$, and, obviously, $f(\ldots)\in\mathrm{img}\:f$. This shows that we also have $u\in\mathrm{img}\:f$, and, as $\ker f'\cap\mathrm{img}\:f=0$, $u=0$.
This shows that, if you use $x'$ instead of $x$ (subject to $g(x')=g(x)$) in the definition of $g'(y)$, the difference will be $u=0$, which means that you will get the same value for $g'(y)$; this is what "g' is well-defined" means.
This proof looks a little like black magic, but there is a trick that allows you to see what happens. You will end up proving that $M$ is isomorphic to $M_1\times M_2$. Of course, you cannot use that in the proof, but you can use it to understand what happens in the proof.
Knowing that, we can write any element of $M$ as $(a,b)$, with $a\in M_1$ and $b\in M_2$. You can define:
$$\begin{align*}
f(a) &= (a,0)\\
f'(a,b) &= a\\
g(a,b) &= b\\
\end{align*}$$
and you are trying to define $g'(b)$ as $(0,b)$. If $x$ is any element that maps to $b$, like $(c,b)$, you cannot simply define $g'(b)=(c,b)$, because there can be many possible elements $(c,b)$ in the pre-image of $b$. The trick is to use $f$ and $f'$ to get rid of $c$. Specifically, you have, using the formula in the text : $(c,b) - f(f'(c,b))= (c,b) - f(c) = (c,b) - (c,0) = (0,b)$, and this is what you want.
castor28 said:
Hi Peter,
Thanks castor28 ... most helpful ...
Most interesting and enlightening is when you write: " ... ... This proof looks a little like black magic, but there is a trick that allows you to see what happens. You will end up proving that $M$ is isomorphic to $M_1\times M_2$. Of course, you cannot use that in the proof, but you can use it to understand what happens in the proof.
$$\begin{align*}
f(a) &= (a,0)\\
f'(a,b) &= a\\
g(a,b) &= b\\
\end{align*}$$
and you are trying to define $g'(b)$ as $(0,b)$. If $x$ is any element that maps to $b$, like $(c,b)$, you cannot simply define $g'(b)=(c,b)$, because there can be many possible elements $(c,b)$ in the pre-image of $b$. The trick is to use $f$ and $f'$ to get rid of $c$. Specifically, you have, using the formula in the text : $(c,b) - f(f'(c,b))= (c,b) - f(c) = (c,b) - (c,0) = (0,b)$, and this is what you want. ... ... Still reflecting on these ideas ...
Thanks again ...
Peter
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 25 ·
