Splitting Fields: Anderson and Feil, Theorem 45.5
In summary, a splitting field is a field extension that contains all the roots of a given polynomial and is necessary to solve polynomial equations. Anderson and Feil are two mathematicians who published Theorem 45.5, also known as the "Existence of Splitting Fields Theorem", which states that every polynomial has a splitting field. This theorem is significant in many areas of mathematics and is used to construct splitting fields and prove other theorems. In practice, it is used in applications of abstract algebra such as cryptography and coding theory.
Math Amateur
MHB
3,998
48
I am reading Anderson and Feil - A First Course in Abstract Algebra.
I am currently focused on Ch. 45: The Splitting Field ... ...
I need some help with some aspects of the proof of Theorem 45.5 ...
Theorem 45.5 and its proof read as follows:
View attachment 6681In the above text from Anderson and Feil we read the following:
"... ... Now \(\displaystyle \alpha\) and \(\displaystyle \beta \) are roots of irreducible polynomials \(\displaystyle f, g \in F[x]\) ... ... Now, we are just given that \(\displaystyle \alpha\) and \(\displaystyle \beta\) are algebraic elements of a field \(\displaystyle F\) ... ... how, exactly, do we know that they are roots of irreducible polynomials in \(\displaystyle F[x]\) ... .,.. ?
"( NOTE: A&F's definition of algebraic over \(\displaystyle F \) does not mention irreducible polynomials but says:
"If \(\displaystyle E\) is an extension field of a field \(\displaystyle F \) and \(\displaystyle \alpha \in E\) is a root of a polynomial in \(\displaystyle F[x]\), we say \(\displaystyle \alpha\) is algebraic over \(\displaystyle F\). ...)
Hope someone can help ...
PeterEdit: Hmm ... wonder if Kronecker's Theorem has something to do with irreducible polynomials entering this discussion ...
Hello Peter,
Thank you for reaching out for help with Theorem 45.5 in Anderson and Feil's A First Course in Abstract Algebra. The proof of this theorem relies on the fact that \alpha and \beta are roots of irreducible polynomials in F[x], and I can understand your confusion as to how we know this.
First, let's clarify the definition of an algebraic element. As you mentioned, A&F define an element \alpha \in E as algebraic over F if it is a root of a polynomial in F[x]. This means that there exists some polynomial f \in F[x] such that f(\alpha) = 0. In other words, \alpha is a solution to the polynomial equation f(x) = 0. This is what it means for an element to be algebraic over a field.
Now, let's look at the definition of a splitting field. A splitting field of a polynomial f \in F[x] is an extension field E of F such that f factors completely into linear factors in E[x]. In other words, all the roots of f are contained in E. This is where Kronecker's Theorem comes into play. This theorem states that every polynomial f \in F[x] has a splitting field. So, in our case, since \alpha and \beta are algebraic elements of F, there exists a polynomial f \in F[x] such that f(\alpha) = f(\beta) = 0. This means that both \alpha and \beta are roots of f, and therefore, they are contained in the splitting field of f. Since the splitting field is an extension of F, we can conclude that \alpha and \beta are roots of irreducible polynomials in F[x].
I hope this helps clarify your question. If you need further assistance, please don't hesitate to ask. Keep up the good work with your studies!
FAQ: Splitting Fields: Anderson and Feil, Theorem 45.5
What is a splitting field?
A splitting field is a field extension that contains all the roots of a given polynomial. It is the smallest field extension that is necessary to contain all the roots of the polynomial.
Who are Anderson and Feil?
Anderson and Feil are two mathematicians who published a theorem (Theorem 45.5) in the field of abstract algebra that provides a method for constructing splitting fields.
What is Theorem 45.5?
Theorem 45.5, also known as the "Existence of Splitting Fields Theorem", states that every polynomial with coefficients in a field has a splitting field.
What is the significance of Theorem 45.5?
Theorem 45.5 is significant because it provides a way to construct splitting fields, which are important in many areas of mathematics such as Galois theory and algebraic number theory. It also helps in solving polynomial equations, as the roots of a polynomial can be found in its splitting field.
How is Theorem 45.5 used in practice?
Theorem 45.5 is used in practice by mathematicians to construct splitting fields for polynomials and to prove other theorems related to splitting fields. It is also used in various applications of abstract algebra, such as in cryptography and coding theory.
