MHB Splitting Fields - Dummit and Foote - Example - page 541 - x^p - 2, p prime
Math Amateur
MHB
I am reading Dummit and Foote Section 13.4 Splitting Fields and Algebraic Closures
In particular, I am trying to understand D&F's example on page 541 - namely "Splitting Field of x^p - 2, p a prime - see attached.
I follow the example down to the following statement:
" ... ... ... so the splitting field is precisely \mathbb{Q} ( \sqrt[p]{2}, \zeta_p )"
BUT ... then D&F write:
This field contains the cyclotomic field of p^{th} roots of unity and is generated over it by \sqrt[p]{2}, hence is an extension of at most p. It follows that the degree of this extension over \mathbb{Q} is \le p(p-1).*** Can someone please explain the above statement and show formally and explicitly (presumably using D&F ch 13 Corollary 22 - see Note 1 below) why the degree of \mathbb{Q} ( \sqrt[p]{2}, \zeta_p ) over \mathbb{Q} is \le p(p-1).
I also find it hard to follow the statement:
" ... ... ... Since both \mathbb{Q} ( \sqrt[p]{2} ) and \mathbb{Q} ( \zeta_p ) are subfields, the degree of the extension over \mathbb{Q} is divisible by p and p - 1. Since both these numbers are relatively prime, it follows that the extension degree is divisible by p(p-1) so that we must have
[\mathbb{Q} ( \sqrt[p]{2}, \zeta_p ) \ : \ \mathbb{Q}] = p(p - 1) ... ... "
*** Can someone please try to make the above clearer - why exactly is the degree of the extension over \mathbb{Q} divisible by p and p - 1. What is the importance of "relatively prime" and why does equality hold in the statement regarding the degree of the extension?'
*** Finally, we are told that p is a prime, but where does the argument in the example depend on p being prime. ["Relatively prime" is mentioned in the context of p and p-1 but they are consecutive integers and hence are coprime anyway]
I would be grateful for some clarification of the above issues.
PeterNote
1. Corollary 22 (Dummit and Foote Section 13.2 Algebraic Extensions, page 529
Suppose that [K_1 \ : \ F] = n, [ K_2 \ : \ F ] = m where m and n are relatively prime: (n, m) = 1.
Then [K_1K_2 \ : \ F] = [K_1 \ : \ F] [ K_2 \ : \ F ] = nm
2. The above has also been posted on MHF
By the so-called "tower rule" if we have a tower of field extensions:
$F < E < K$, we know that:
$[K:F] = [K:E]\ast[E:F]$
whence it follows that both $[K:E]$ and $[E:F]$ divide $[K:F]$ (this is just a simple fact about divisibility of integers).
Note that this is true of ANY subfield $E$ of the field $K$ containing $F$.
As was noted in an earlier post:
$\Bbb Q(\sqrt[p]{2},\zeta_p) = \Bbb Q(\zeta_p)(\sqrt[p]{2})$.
But $\Bbb Q(\zeta_p)$ *IS*the cyclotomic field containing the $p\ p$-th roots of unity ($\zeta_p$ is a PRIMITIVE $p$-th root of unity, and all the other $p$-th roots of unity are powers of $\zeta_p$. To see this note that since $p$ is prime, and by definition of primitive $p$-th root of unity, $\zeta_p$ is a root of:
$x^p - 1 \in \Bbb Q[x]$.
By a corollary to Lagrange's theorem, we have that every non-identity element of $\langle \zeta_p \rangle$ is of order $p$ (since this is a cyclic group of prime order in $\Bbb C^{\ast}$ under complex multiplication), which gives $p-1$ roots, and clearly 1 is also a root, giving $p$ roots. Since a polynomial of degree $p$ over a field can have at MOST $p$ roots, this is indeed ALL of them and so $x^p - 1$ splits in $\Bbb Q(\zeta_p)$).
What is the degree of this extension $\Bbb Q(\zeta_p)$? It is $p-1$, since $\zeta_p$ satisfies the (irreducible) $p$-th cyclotomic polynomial:
$x^{p-1} + \cdots + x + 1 = \dfrac{x^p - 1}{x - 1} \in \Bbb Q[x]$
The irreducibility of cyclotomic polynomials has been discussed in this thread:
http://mathhelpboards.com/linear-abstract-algebra-14/automorphisms-splitting-field-m-th-cyclotomic-polynomial-6185.html
which you might find worthwhile to read.
Now $\sqrt[p]{2}$ satisfies the degree $p$ polynomial:
$x^p - 2 \in \Bbb Q(\zeta_p)[x]$, so its minimal polynomial must be of degree $\leq p$.
I have addressed part of the divisibility question in my opening remarks. Here is the rest of what you need to know:
Suppose $a|n$ and $b|n$ with $\text{gcd}(a,b) = 1$ for $a,b,n \in \Bbb Z^{+}$.
We then know that $n$ is a common multiple of $a$ and $b$, in particular:
$\text{lcm}(a,b)|n$. Since $\text{lcm}(a,b) = \dfrac{ab}{\text{gcd}(a,b)} = ab$, we have that $ab|n$.
Therefore, we have an integer $n$ which is at MOST $p(p-1)$ and is divisible by $p(p-1)$. The latter fact implies $n = k(p)(p-1)$, and the former fact then forces $k = 1$.
The primality of $p$ enters into it at the very start: with the field $\Bbb Q(\zeta_p)$. To see this consider what field is generated by a 4-th root of unity (one of these roots is often given a "special" name), and explain why:
$x^3 + x^2 + x + 1$ is not irreducible over $\Bbb Q$
(Hint: factor $x^4 - 1$ over $\Bbb Q$).
Thanks Deveno. That has helped to clear up a number of issues for me.
However, I am still confused regarding the primality of p. I still cannot see why it is necessary. Let me explain my confusion on this matter.
You write that the prime nature of p has to do with the field $$ \mathbb{Q} ({\zeta}_p) $$ - that is, specifically, we need $$ {\zeta}_p $$ to be a primitive $$ p^{th} $$ root of unity. But surely this does not necessitate or entail p being prime?
Check D&F.
If we read D&F pages 539-540 (see attached we find the definition of a primitive $$ n^{th} $$ root of unity as follows: (see attachment - bottom of page 539)
"Definition. A generator of the cyclic group of all $$ n^{th} $$ roots of unity is called a primitive $$ n^{th} $$ root of unity
Let $$ {\zeta}_n $$ denote a primitive $$ n^{th} $$ root of unity. The other primitive $$ n^{th} $$ roots of unity are then the elements
$$ {{\zeta}_n}^a $$ where $$ 1 \le a \le n $$ is an integer relatively prime to n, since there are other generators for a cyclic group of order n. In particular there are precisely $$ \phi (n) $$ primitive $$ n^{th} $$ roots of unity, where $$ \phi (n) $$ denotes the Euler $$ \phi $$ function."
Note that the requirement is that a is relatively prime to n - not that n is prime!
On the top of page 540 D&F continue as follows:
"Over $$ \mathbb{C} $$ we can see all of this directly by setting
$$ {\zeta}_n = e^{2 \pi i /n} $$
(the first $$ n^{th} $$ root of unity counterclockwise from 1). Then all the other roots of unity are powers of $$ {\zeta}_n $$:
$$ e^{2 \pi k i /n} = {{\zeta}_n}^k $$
so that $$ {\zeta}_n $$ is one possible generator for the multiplicative group of $$ n^{th} $$ roots of unity. When we view the roots of unity in $$ \mathbb{C} $$ we shal usually use $$ {\zeta}_n $$ to denote this choice of a primitive $$ n^{th} $$ root of unity."
As an example, for the case of the polynomial $$ x^4 - 1 $$ we can use
$$ {{\zeta}_4}^1 = e^{2 \pi 1 i /4} = e^{ \pi i / 2 } = i $$ and then this generates the 4 roots.
So I still do not see the reason for the primality of p - but I feel there must be something I am missing ?
Can you please clarify this issue for me.
Peter
Yes, you are missing something...in general, the splitting field for:
$x^n - 1$ has degree $\phi(n)$ over $\Bbb Q$. It's not that we can't form this splitting field for non-prime $n$, it's just that its degree is typically much smaller than $n-1$ (the more composite $n$ is, the smaller $\phi(n)$ tends to be).
It is only when $n$ is prime that we can conclude $\phi(n) = n-1$. If you think about it, that's sort of the DEFINITION of a prime integer: every positive integer less than it, is co-prime to it (1 is a special case, and usually not counted as prime).
The whole of D&F's argument rests on proving the degree of a certain kind of extension, which they give an explicit formula for. For $n = 4$, you can see this formula fails, because:
$[\Bbb Q(i,\sqrt[4]{2}):\Bbb Q] = 8 \neq 12 = (n-1)n$, as we have seen in another thread.
The reason for this is 4 is not prime.
The motivation behind the proof is that it is a bit difficult to show DIRECTLY that:
$x^p - 2$ is irreducible over $\Bbb Q(\zeta_p)$: if $p$ is large there are a lot of possible factorizations to check. For example, for $p = 5$, we have to check:
1) that there are no roots in $\Bbb Q(\zeta_5)$ (this also eliminates the possibility of quartic factors)
2) that there are no quadratic (and hence cubic) factors.
Given that each element of $\Bbb Q(\zeta_5)$ is equivalent to solving for 5 "unknowns", this creates a system of 5 equations in 5 unknowns, which may in practice be quite difficult to solve.
When $p$ is prime we get ALL the primitive roots (any non-trivial (unity) one) by adjoining ANY root besides 1. This is not true for n = 4, for example: adjoining the root -1 does not enlarge our field: $\Bbb Q(-1) = \Bbb Q$.
Thanks Deveno, that really clarified some major issues I had!
Peter
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
