Splitting function into odd and even parts
In summary, the conversation discusses the process of splitting a function into its odd and even parts and expressing the result in terms of cosh x and sinh x. The resulting functions, a(x) and b(x), are shown to be even and odd respectively, and when added together, they equal the original function. The individual functions are checked for evenness and oddness by plugging in -x and simplifying.
j3dwards
32
Split the function f(x) = ex + πe−x into odd and even parts, and express your result in terms of cosh x and sinh x.
f(x) = 0.5[f(x) + f(-x)] +0.5[f(x) - f(-x)]
So i know that:
ex = 0.5[ex - e-x] + 0.5[ex + e-x] = sinh(x) + cosh(x)
So let the even part be a(x) and the odd be b(x).
a(x) = cosh(x) + πcosh(x) = (1 + π) cosh(x)
b(x) = sinh(x) - πsinh(x) = (1 - π) sinh(x)
Is this correct?
So i know that:
Is this correct?
What do YOU think? Have you made any errors?
From my workings, I believe I am correct? I can't see any errors myself, so was wondering if you could help me.
All you have to do to check it yourself is check whether a(x) is even, b(x) is odd, and they add to your original function.
Yes it does add up. So I am correct?
Why do you need to ask? Is a(x) even? Is b(x) odd? Is it true that f(x) = a(x) + b(x)?
You should get in the habit of checking these things for yourself because in many situations (such as in exams) you cannot ask anybody else! Have some confidence in your own work.
You can double check by seeing if a(-x) = a(x) or -a(x).
Same for b(x).
Make sure to go through your steps again and see if they make sense to you.
I did check originally, but I'm just quite unsure about odd and even functions so I was just asking to make sure so that for that exam, I knew the correct method.
Same for b(x).
I'm not really sure how to use a(-x) = a(x) or -a(x) to check. Do I literally just make the rhs of the equation equal to negative of what it is a see if it comes out with the same answer?
Yep, you plug in -x and simplify the function as best as you can until you get either the original function or the opposite of the function
Okay perfect, thank you so much.
Related to Splitting function into odd and even parts
1. What is the purpose of splitting a function into odd and even parts?
Splitting a function into odd and even parts allows us to separate the function into two parts that each have different properties. This can make it easier to analyze the function and understand its behavior.
2. How do you split a function into odd and even parts?
In order to split a function into odd and even parts, we first need to identify if the function is odd, even, or neither. If the function is odd, we can use the property f(-x) = -f(x) to split the function into odd and even parts. If the function is even, we can use the property f(-x) = f(x) to split the function. If the function is neither odd nor even, we cannot split it into odd and even parts.
3. What are the graphical representations of odd and even functions?
The graph of an odd function is symmetric about the origin, meaning that if we fold the graph in half along the y-axis, the two halves will be a mirror image of each other. The graph of an even function is symmetric about the y-axis, meaning that if we rotate the graph 180 degrees around the origin, it will look the same as the original graph.
4. Can all functions be split into odd and even parts?
No, not all functions can be split into odd and even parts. Only functions that satisfy the properties of odd and even functions can be split into odd and even parts. If a function does not satisfy these properties, it cannot be split into odd and even parts.
5. How can splitting a function into odd and even parts be useful in real-life applications?
Splitting a function into odd and even parts can be useful in signal processing, where odd and even parts can represent different types of signals. It can also be useful in solving differential equations, as splitting the function can simplify the equations and make them easier to solve.
