Why Do Physical Processes Favor Entropy Maximization Over Energy Minimization?
The correct information is that protein folding increases entropy. In a folded protein, the number of possible structures is limited. 4.) Enthalpy refers to the total heat content of a system, while Gibbs Free Energy takes into account both enthalpy and entropy. In a biochemical system, enthalpy is the main determinant of the direction of a process, but free energy takes into account the entropy as well.
mather
146
hello!
there is no law that says that processes occur physically towards the energy minimization of the system
however, there is a law (second thermodynamic) that says that processes occur physically towards the entropy maximization
1) so, why do we need ΔG (Gibbs free energy) to predetermine a process' direction?
2) also, why ΔG is depended to temperature?
3) I have seen in a tutorial where they said that moving from primary to secondary and to tertiary etc, protein structure, it is a increases in protein's entropy! in a textbook, I read the opposite (which is more correct imo, since a folded protein has some fixed substructures, thus the number of possible structures is limited)
which is the correct? and if folding decreases its entropy, how is this thermodynamically compliant?
4) what is the difference of enthalpy and free energy of a biochemical system?
thanks!
1) Gibbs Free Energy is a thermodynamic potential which determines the non-PV work or "useful" work in initiating and proceeding a process.
2.) Check the formula for Gibbs Free Energy. Usually, at higher temperatures, processes proceed more easily, even the non-spontaneous, difficult to get products can be formed.
Related to Why Do Physical Processes Favor Entropy Maximization Over Energy Minimization?
What is meant by the spontaneity of physical processes?
The spontaneity of physical processes refers to the tendency of a system to undergo a change or transformation without any external intervention or influence.
What factors determine the spontaneity of a physical process?
The spontaneity of a physical process is determined by the change in entropy of the system, the change in enthalpy of the system, and the temperature at which the process occurs.
How does entropy play a role in the spontaneity of physical processes?
Entropy is a measure of the disorder or randomness in a system. The spontaneity of a physical process is favored when there is an increase in entropy, as this leads to a more disordered state of the system.
Can a spontaneous physical process be reversed?
No, a spontaneous physical process is irreversible. This is because the change in entropy of the system will always lead to a more disordered state, making it energetically unfavorable to reverse the process.
Are all spontaneous physical processes beneficial?
No, not all spontaneous physical processes are beneficial. While some may be essential for the functioning of living organisms, others may lead to harmful effects such as corrosion or decay.
