Spontaneous symmetry breaking scalar field masses
The discussion focuses on determining the mass of scalar fields in a model involving spontaneous symmetry breaking, specifically addressing Goldstone's theorem. The user proposes a vacuum solution that breaks symmetry, setting one scalar field to zero. They seek guidance on expanding the fields around this vacuum and rewriting the Lagrangian to identify mass terms. The response clarifies that a multidimensional Taylor series can be used for expansion, allowing the user to express the fields in terms of deviations from the vacuum solution. Ultimately, the user confirms their understanding of substituting these expressions into the potential to extract mass information.
Milsomonk
Determine the mass of the scalars and show that one remains zero in accordance with goldstones theorem.
$$L=\dfrac {1}{2} (\partial_\mu \phi_a)(\partial^\mu \phi_a)-\dfrac{1}{2} \mu^2 (\phi_a \phi_a) - \dfrac{1}{4} \lambda (\phi_a \phi_a)^2+ i\bar{\psi} \gamma^\mu \partial_\mu \psi -g\bar{\psi} (\phi_1 +i\gamma^5 \phi_2)\psi$$
I have chosen a vacuum solution that breaks the symmetry
$$\phi_1 = \sqrt{\dfrac{-\mu^2}{\lambda}}, \phi_2 =0$$
So I know that I need to expand the fields around the minimum and then write the new lagrangian, then I should be able to read the mass from the hyperbolic terms, but I'm not sure how to carry out the expansion. Any advice would be much appreciated :)
How would you usually make an expansion of any function ##f(\vec x)## about some point ##\vec x_0##?
I'd use a Mclaurin series ordinarily, I think the fact that there are two field is the part that is confusing me, but since I'm picking my vacuum solution such that Phi_2 is zero can I simply expand Phi_1 and discard all terms with Phi_2? also I'm not too sure if I need to rewrite the whole lagrangian once I've done the expansion or if just the potential would suffice. Thanks for your response :)
Just look at it as a function of two variables (that in turn happens to be functions of the space time coordinates, but that is besides the point) that you want to expand around a point which has one of the variables equal to zero. It is just a multidimensional Taylor series. In fact, you do not even need to take any derivatives, just express ##\phi## as a sum of the point you want to expand about and the deviation from that point.
Ok so if I understand you correctly I can expand \phi as follows:
$$\phi_1=v+h$$
where v is my vacuum solution and h is my deviation.
then I can expand my second field but v is zero so I just get a deviation f.
$$\phi_2=f$$
Now I can substitute this into my potential and read the mass' from the terms that are squared in h and f?
Correct. It does not need to be more difficult than that.
Ah awesome, thanks! much clearer now :)
  • · Replies 0 ·
